Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > Project Showcase
Old 09-01-2011, 02:16 AM   #5431
STAFF
BigJim's Avatar
Gulf Island Building.
Originally Posted by cocobolo View Post
True enough. In fact I was even going to see if I could find an old pair of runners that I could swipe one aglet from.
I sure am glad ya'll said shoe lace cause I didn't know what a aglet was there for a second. Would soldering the end of the wire work, or heat shrink?
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is offline   Reply With Quote
Old 09-01-2011, 09:53 AM   #5432
cocobolo's Avatar
Either one might work Jim. I thought of trying to solder the end of the wire, but I don't know how well solder works with stainless, it might. Heat shrink might well do the trick as well...except I don't have any.
I'll try the foil this morning, and if that doesn't help, I'll get some heat shrink next trip to town.
Just an old guy messin' with bits of wood...
...the friendliest thread on the site! Come on by.
cocobolo is online now   Reply With Quote
Old 09-01-2011, 10:19 AM   #5433
Would dipping it in melted wax work?
"The problem with quotes on the Internet is that it is often difficult to verify their authenticity." - Abraham Lincoln
The economy is so bad, Exxon-Mobil laid-off 25 congressmen --- Maxine
gma2rjc is offline   Reply With Quote
Old 09-01-2011, 11:50 AM   #5434
howza about slightly opening the feed side with a counter sink
The older I get the better I was
Old 09-01-2011, 12:04 PM   #5435
cocobolo's Avatar
If anything Tim, it would need the entire hole made larger. If it ever warms up here, I will try the tinfoil first.
So much for the summer we never had.
Old 09-01-2011, 12:07 PM   #5436
cocobolo's Avatar
Don't know if it would be strong enough...although lubricating the tip could help.
It's just that with a 1/8" cable of 7 x 19 with a single strand core, there are 133 extremely fine wires with a larger core piece. And they are sharp little so and so's.
Old 09-01-2011, 12:10 PM   #5437
you know better than to push your large wire into a small hole, silly wabbit
Old 09-01-2011, 12:19 PM   #5438
cocobolo's Avatar
...it's not that big.
Old 09-01-2011, 01:22 PM   #5439
cocobolo's Avatar
OK, so I tried the aluminum foil...
First pic is the wire end when you only think it's good.
Second one is a fresh cut with the special wire cutters...and third is wrapped in foil.
Old 09-01-2011, 01:24 PM   #5440
cocobolo's Avatar
...and it works like a charm!
Now have the first 6 rows done, and no trouble at all with the foil...just zips right through.
It looks like I am going to have enough wire to finish the whole thing, but I need to get another coat or two of the urethane on the underside of the railing before I finish running the rest of the wire through.
It needs to warm up another few º before I do that.
Last edited by cocobolo; 09-01-2011 at 01:43 PM. Reason: another splellingg goofuss
The Following User Says Thank You to cocobolo For This Useful Post:
BigJim (09-01-2011)
Old 09-01-2011, 01:27 PM   #5441
Old 09-01-2011, 01:31 PM   #5442
STAFF
BigJim's Avatar
Me too
Jim
Old 09-02-2011, 01:42 AM   #5443
cocobolo's Avatar
Something I don't see very often...a great blue heron flew over and stopped at the very top of a fir tree. About 90 feet up in the air. He's here all the time...just not up the tree.
Old 09-02-2011, 01:43 AM   #5444
cocobolo's Avatar
Tonight's sunset, not that great.
Good news from the foamies, my stuff is in and I can pick it up tomorrow. Looks like I will be going to town.
Old 09-02-2011, 08:04 AM   #5445
STAFF
BigJim's Avatar
Keith, I am sure you get to see many beautiful sunsets but down this way they are kinda rare or either I am at the wrong place at the right time. That sunset is so comforting to me, it says crank up a camp fire and kick back with a good cup of mud.
I hope that earth quake above you don't cause and waves down your way while going over to get your foam. By the way are you going to suggest that they reimburse you for the trouble and gas for the unnecessary trip over? The wall eyed bean heads. (bettern cussin I guess)
Jim
glue down hardwood flooring along gulf coast sbmcclean@sbcglobal.net Flooring 6 12-21-2008 02:55 PM
