Gulf Island Building. - Project Showcase - Page 36 - DIY Chatroom Home Improvement Forum
Old 01-28-2010, 10:33 PM   #526
cocobolo's Avatar
Rewards Points: 5,788
This is the last of the three big planks for the bridge. This one is a little narrower than the other two, as it will be used as the center support and does not need to be quite as wide.
As you can see, it is still a substantial chunk of lumber.
cocobolo is offline   Reply With Quote
Old 01-28-2010, 10:38 PM   #527
cocobolo's Avatar
I was able to move those boards round to the side of the saw shed without help...although I suspect I may regret that when I wake up in the morning.
The second piece of that boomstick is now on the log deck. Note the crack at the end. I cut a 4 foot length off where it was broken (I thought it was shorter than that until I measured it) and still did not get all of the crack taken out.
Before cutting this one it will need to be turned so that the crack is either horizontal or vertical for the first cut. That will depend on what I decide to get from the log. If the crack is properly lined up, the waste from that crack will be minimal.
Old 01-28-2010, 11:41 PM   #528
jlhaslip's Avatar
Rewards Points: 1,538
coco,
do you quarter saw any of your wood to get some vertical grain pieces?
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 01-30-2010, 03:24 PM   #529
cocobolo's Avatar
Interesting that you should ask that particular question right now.
I took a slab off the most recent log, and I will be able to get 4 pieces of 2 by lumber out of the middle which will be edge grain. It might even be possible to get one extra piece out of each side of the remainder.
Bear in mind that even when one is cutting "through and through", which means you are simply slabbing the entire log, that a few of the middle pieces will be edge grain. You do need to eliminate the centre of the log, as that grain is usually much more coarse. It's the fine grain you are looking for if at all possible.
When the weather gets better (it's busy raining today) I'll show you some very tight grain wood coming up on the next log. Hopefully, I will be able to make a few doors from this one.
Old 01-30-2010, 09:41 PM   #530
cocobolo's Avatar
In the mean time, from the really wide log, I took a couple of boards out of the middle to make some stair treads from. These will go on the circular stairs out front. They are 16" wide at the fat end, 5" at the narrow end. The boards were so wide I could almost get two side by side from each piece.
Old 01-30-2010, 11:14 PM   #531
jlhaslip's Avatar
What sort of ring count to the inch?
Spiral stair case? What width is the tread 12 inches from the narrow end?
Old 01-31-2010, 11:29 AM   #532
cocobolo's Avatar
The ring count varies, due to the fact that each board is from the middle of the log. Starts at about 10 on the outside. The next log has some super fine rings.
12" in from the end? My magic tape measure reads 12 3/8". Consider that there will be a 1" overlap on the tread below, so you can consider the run to be 11 3/8" on the walking line. The rise will be 6.4166", give or take a few thousandths.
That multiplies out to about 73, a good number for outside stairs. This will be the fourth set of spirals here.
Old 01-31-2010, 11:03 PM   #533
cocobolo's Avatar
Brought up the first of 4 sections from the very tight grain log, and unfortunately, I think it will be the last.
It turned out to be extremely difficult to cut, even with a sharp blade. I did manage a 6" thick slab, which is patiently sitting there waiting for me to flip it and make door wood from.
I tried to count the rings, but as it was starting to get quite dusky at the time, I wasn't able. However, I took a couple of pics to try and do a count on the 'puter.
The nails are 1" apart as a reference. Cannot quite count the very outside, but I get 27 on the next one and 25 after that.
Now here's the thing...I don't know what kind of wood this is.
When it was floating in the chuck, I thought it was fir, as it was a very high floater. My friend came down this afternoon and has had a similar log cut on his mill. He suggested Hemlock, but they are always 95%+ in the water. The other option hereabouts could be Sitka or Engelman spruce. I have had a nice Sitka before, but it cut easily, whereas this one did not.
Old 01-31-2010, 11:06 PM   #534
cocobolo's Avatar
This is the fat end of the same log. That big black mark on the left is water stain from the hole which they bore through on the boom logs. I was only about 2" away from the hole when I chainsawed the end off.
Old 02-01-2010, 01:07 AM   #535
jlhaslip's Avatar
I thought I was the only guy that used that equation...
run times rise should aim for '75' if I recall... ie: 10 " run x 7.5 " rise
Old 02-01-2010, 02:00 PM   #536
cocobolo's Avatar
You're almost exactly right.
The number should be between 75 and 80. However, when your legs get older like mine, a lower rise is easier to walk up and down. When I first worked the steps out, it could either be exactly a 7" rise, or the 6.4".
The 6.4 requires an extra step, but considering what my wood cost is, that wasn't really a factor. The spirals inside the house are also quite low, around 6 3/8", also with a nice deep tread.
Old 02-02-2010, 01:03 AM   #537
E-lec-tri-city
Rewards Points: 150
Send a message via ICQ to brons2 Send a message via AIM to brons2 Send a message via MSN to brons2 Send a message via Yahoo to brons2
Amazing thread. What a gift for design and execution you have. The pics of your mill operating are fascinating as well. Along with many other pics.
Makes me think about home, I am from Oregon originally. I know all about rain squalls!
brons2 is offline   Reply With Quote
Old 02-03-2010, 06:23 PM   #538
cocobolo's Avatar
What part of Oregon are you from? I have exquisite memories of that fantastic drive down the Oregon coast. Just stunning.
Old 02-03-2010, 11:08 PM   #539
cocobolo's Avatar
Managed to get a fair portion of the wood cut to build the new woodshed just off the back deck. It's only going to be 10' by 12', but it's going to be somewhat up in the air on one side, as the ground slopes a fair bit. Therefore it will consume a fair amount of lumber.
About 2/3 of which is in these pics.
2 x 10's for the main beams, 2 x 8's for the floor joists, 6 x 6 support posts, 2 x 6's for the floor and then regular 2 x 4 wall construction from there.
Gulf Island Building.-sm-46.jpg   Gulf Island Building.-sm-47.jpg   Gulf Island Building.-sm-48.jpg   Gulf Island Building.-sm-49.jpg
Old 02-03-2010, 11:09 PM   #540
cocobolo's Avatar
Here's a wheel barrow load of stair treads for the front spiral stairs.
glue down hardwood flooring along gulf coast sbmcclean@sbcglobal.net Flooring 6 12-21-2008 01:55 PM
