Gulf Island Building. - Project Showcase - Page 355 - DIY Chatroom Home Improvement Forum
Old 08-23-2011, 12:17 PM   #5311
cocobolo's Avatar
Rewards Points: 6,098
Originally Posted by jiju1943 View Post
I could just feel the bed balanced as you went to the other side to let it down when you turned it over. I hadn't thought about trying to bring a bed that size over from the main land. I bet that mattress was a bear to handle alone.
I cheated on the mattress Jim...it came over in four different bags.
We got the thick foam for the bottom in two pieces, then the memory foam and the latex in another two bags. The guys at the store double bagged everything for me.
It all made it quite intact. I don't see any way we could bring over a one piece K.S. mattress, just too big.
Just an old guy messin' with bits of wood...and old cars!
...the friendliest thread on the site! Come on by.
cocobolo is offline   Reply With Quote
Old 08-23-2011, 12:42 PM   #5312
cocobolo's Avatar
Jim, here's the support I rigged up to go under the center of the platform.
Old 08-23-2011, 12:45 PM   #5313
cocobolo's Avatar
A second coat of varnish this morning has improved the appearance of the wood. Still blotchy which is characteristic of arbutus.
Old 08-23-2011, 01:08 PM   #5314
Ole Wood Worker
BigJim's Avatar
Rewards Points: 484
Wow, that is beautiful. When a shiny finish is used you can see all imperfections or the lack of imperfections and I don't see a single one anywhere, you are good buddy. I like your support, that will work great.
4 Bags is for sure easier to handle, we have a KS and it takes an act of congress to move that bad boy. (hmmm maybe act of congress is a bad choice of words) If your memory foam is like the one we have in out little camper you won't get cold this winter, that thing gets hot in the summer also.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 08-23-2011, 01:08 PM   #5315
Tileguy
Bud Cline's Avatar
Rewards Points: 558
If (God Forbid) your boat ever sunk to the bottom of the bay you could paddle that mattress across the water if need be.
XXX
Old 08-23-2011, 01:14 PM   #5316
Tileguy
Bud Cline's Avatar
Rewards Points: 558
If it took an act of congress to move that bad boy, it would never get moved.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
BigJim (08-23-2011)
Old 08-23-2011, 01:15 PM   #5317
cocobolo's Avatar
Old 08-23-2011, 01:21 PM   #5318
cocobolo's Avatar
4 Bags is for sure easier to handle, we have a KS and it takes an act of congress to move that bad boy. (hmmm maybe act of congress is a bad choice of words) If your memory foam is like the one we have in our little camper you won't get cold this winter, that thing gets hot in the summer also.
Jim:
The additional layer of perforated latex foam which goes on top of the memory foam is supposed to moderate the temperature. Warmer in winter and cooler in summer.
I guess when I have a few more coats of varnish on I can put the mattress together and let you know if they were kidding me or not.
For the price, it had better be "NOT".
Old 08-23-2011, 03:38 PM   #5319
Ole Wood Worker
BigJim's Avatar
Rewards Points: 484
Ours don't have the latex foam rubber on top, I can see where that would make the difference. Even without the latex they are proud of their mattresses.
Bud, you got that right about the congress, the low down sorry bunch of ...
Jim
Old 08-23-2011, 07:52 PM   #5320
jules4's Avatar
This bed is starting to sound dangerous - once you sink down into that mattress you may lose the will to ever get up again.
Email: the to-do list anyone in the world can add items too.
jules4 is offline   Reply With Quote
Old 08-23-2011, 08:01 PM   #5321
jules4's Avatar
Of course, the alternative to politicians getting nothing done is for them to start actually DOING STUFF, and that rarely turns out well either.
The Following 2 Users Say Thank You to jules4 For This Useful Post:
BigJim (08-23-2011), cocobolo (08-23-2011)
Old 08-23-2011, 08:02 PM   #5322
Rewards Points: 658
I love the look of the wood grain and the finish is beautiful. Keep up the good work! Thanks for posting the pics.
gma2rjc is online now   Reply With Quote
The Following User Says Thank You to gma2rjc For This Useful Post:
Old 08-23-2011, 09:33 PM   #5323
cocobolo's Avatar
Dammit...I was hoping nobody would catch on to my plan...
Old 08-23-2011, 09:45 PM   #5324
cocobolo's Avatar
Thanks Barb: I'm using Helmsman Spar Urethane, please note they don't have the word "varnish" in the product name.
Remember the Behr varnish story awhile ago - not being made any more.
When I first dipped a brush into this stuff, it had all the viscosity of water, so I thought how good could this possibly be?
Well, I still don't have the answer to that, but I have found one positive side effect and that is the drying time. Four hours to touch and 6 hours to re-coat. Gotta like that.
I did the third coat this afternoon and I can get one more on around 10 tonight. So, when I get up in the morning it might be in useable shape. Surprisingly, the third coat has eliminated all the dry spots on the arbutus. It has a habit of doing that due to the crazy grain directions in the wood.
I will say that the Behr varnish would sometimes take 4 or 5 coats to get rid of the end grain problem.
Old 08-24-2011, 11:31 PM   #5325
cocobolo's Avatar
It is high time that the corner post and end railing got finished, sooo....
In order to mark the locations for the holes in the corner post - I needed some solid rod so I could find the exact points to drill.
I'm not sure if the photo is self explanatory or not, but I used two pieces of stainless steel welding rod (gotta be stainless, nothing else could possibly work!) and pushed the business end up against the corner post to locate the precise point.
glue down hardwood flooring along gulf coast sbmcclean@sbcglobal.net Flooring 6 12-21-2008 01:55 PM
