Gulf Island Building. - Project Showcase - Page 352 - DIY Chatroom Home Improvement Forum
Old 08-14-2011, 10:56 PM   #5266
cocobolo's Avatar
Rewards Points: 5,956
After that I shaped them up somewhat on the 12" miter saw. This pair is rough sanded...much more to go yet.
Just an old guy messin' with bits of wood...and old cars!
...the friendliest thread on the site! Come on by.
cocobolo is offline   Reply With Quote
Old 08-14-2011, 10:58 PM   #5267
cocobolo's Avatar
Earlier today a friend of mine from the B. C. Multihull Society came speeding by in his cat. I barely had time to get a pic.
Old 08-14-2011, 11:06 PM   #5268
cocobolo's Avatar
Tonight's sunset...
The Following 2 Users Say Thank You to cocobolo For This Useful Post:
BigJim (08-14-2011), sbmfj (08-16-2011)
Old 08-17-2011, 12:48 AM   #5269
cocobolo's Avatar
OK, this morning, I took a shot at attaching the four lower frame boards together. I used the aluminum angle for that and it seemed to work OK.
There will be a plywood base for the mattress going on top of that lower frame - and of course I didn't take a pic. I'll get that in the morning.
Plus tomorrow I hope to be able to cut the big dovetails for the stretchers as well as do the final cutting to length and so on for the top platform boards.
They are already planed and so forth.
Old 08-17-2011, 03:57 PM   #5270
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Messin' around on un-grouted floor tile is risky business. The corners of the tiles don't always have enough support until a little grout is squeezed in under them.
Just sayin'
XXX
Old 08-17-2011, 04:30 PM   #5271
cocobolo's Avatar
Just sayin'
Messin' around? Who's messin' around? I'm still building the bed!
Promise I will be careful and get the grout in there very shortly.
Old 08-17-2011, 05:35 PM   #5272
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Yow okay. I suppose that may have been a suppository remark. Consider yourself duly scolded...and carry on.
XXX
Old 08-17-2011, 06:13 PM   #5273
cocobolo's Avatar
Yes sir!!!
The Following User Says Thank You to cocobolo For This Useful Post:
Bud Cline (08-17-2011)
Old 08-18-2011, 01:35 AM   #5274
cocobolo's Avatar
I made a couple of big dovetails at each end of the stretchers. They are left unglued for future dis-assembly for moving.
BigJim (08-18-2011)
Old 08-18-2011, 01:37 AM   #5275
cocobolo's Avatar
Here the platform is upside down.
The plywood strips are for re-inforcing purposes. I think I will need to make some sort of central support to minimize any potential sag.
Old 08-18-2011, 01:39 AM   #5276
cocobolo's Avatar
When the platform is turned upside down, the plywood will just fit inside the edges of the frame - loosely - which will properly locate the platform.
Once in its' final resting place, I will screw it down.
Old 08-22-2011, 12:43 AM   #5277
cocobolo's Avatar
This morning I added some tarpaper to the light/plant holder thing at the top of the stairs. And nailed on the plywood top as well.
Old 08-22-2011, 12:46 AM   #5278
cocobolo's Avatar
I might have commented before about sticking with one tape measure when you are doing precise measuring and cutting.
I still don't know whether or not I goofed this morning and used two tapes...one thing I do know, is that they don't read the same.
Old 08-22-2011, 12:49 AM   #5279
cocobolo's Avatar
Bud will be glad to know that I abandoned the unfinished living room tile area as a work station.
I dis-assembled the bed and took it upstairs piece by piece.
Here is the re-assembled frame.
Old 08-22-2011, 12:52 AM   #5280
cocobolo's Avatar
Later on I put the plywood platform together - upside down.
There will be about twelve dozen screws keeping the arbutus platform pieces firmly in place, and it is really only practical to drill the holes while this assembly is downside up.
glue down hardwood flooring along gulf coast sbmcclean@sbcglobal.net Flooring 6 12-21-2008 01:55 PM
