Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > Project Showcase
Old 07-28-2011, 09:29 PM   #5146
cocobolo's Avatar
Gulf Island Building.
Thanks Barb...it's hard to believe what a difference finishing just that top corner has made.
So, other than getting some Varathane on it, that's it. I will get one coat on this evening. Had to go over the water again, as we ran out of gas.
This weekend is a long weekend up here, so the weekenders are all arriving. The bay is already quite full of boats, but I didn't see a decent bikini anywhere when I just came back in.
Just an old guy messin' with bits of wood...
...the friendliest thread on the site! Come on by.
cocobolo is offline   Reply With Quote
Old 07-28-2011, 09:46 PM   #5147
Tileguy
Bud Cline's Avatar
I'll chime-in again at this point to say that you Keith are some kind of a great craftsman. Very very impressive stuff my man, beautiful work.
The Following User Says Thank You to Bud Cline For This Useful Post:
cocobolo (07-28-2011)
Old 07-29-2011, 11:14 AM   #5148
does your house smell as good as it looks? I have found using a wooden caul with the clamps gives me something to screw down while clamping to eliminate lift and marring of the edge from the steel clamp
The older I get the better I was
Old 07-29-2011, 02:53 PM   #5149
cocobolo's Avatar
It often smells like cedar, which visitors frequently comment on.
The lift wasn't as bad as perhaps I suggested, but it was annoying. I clamped the ends down but not the middle. That raised up about 3/16" or so. Since I shifted the work bench right against the wall, I don't have room to put a clamp on the back side, as I would need to do with a caul - which I too often use. I suppose I could add 100 lbs. of tiles...never thought of that until right now.
I planed the first shelf this morning, and it came out not too badly. As soon as I get it sanded I'll get a picture.
The Following User Says Thank You to cocobolo For This Useful Post:
BigJim (07-29-2011)
Old 07-29-2011, 03:56 PM   #5150
Awesome work Keith. I got the latest issue of Fine Home building (I subscribed upon hearing your recommendation of it, and its a great mag) and the front cover has a picture of a kitchen, with curved wooden walls. I thought it may have been your place for a second there. The article has a shot of the plans, and there's only one rounded wall it seems. Your place is definitely one of a kind!!!
sbmfj is offline   Reply With Quote
The Following User Says Thank You to sbmfj For This Useful Post:
cocobolo (07-30-2011)
Old 07-29-2011, 05:31 PM   #5151
There's an idea! Maybe you should contact the good folks at Fine Homebuilding magazine. I bet they would jump at the chance to feature your house in an upcoming issue.
gma2rjc is offline   Reply With Quote
Old 07-29-2011, 08:30 PM   #5152
cocobolo's Avatar
Ah, the cheapskates couldn't put more than one curve in eh?
Haven't seen it yet, I'll pick it up next trip to town, which looks like Monday.
Old 07-29-2011, 08:32 PM   #5153
cocobolo's Avatar
Barb, I don't think they can afford my rates!
Unless, of course, they want to buy the house, then that's an entirely different matter.
Old 07-29-2011, 10:09 PM   #5154
Tileguy
Bud Cline's Avatar
Keith you could probably teach them all a thing or three.
gma2rjc (07-29-2011)
Old 07-30-2011, 12:16 AM   #5155
cocobolo's Avatar
Bud! Just the man I need to talk to!
When grouting the Saltillo tiles, and you are at the sponging off stage, what nifty little hints can you pass along?
The first batch I did, the grout was mixed too thin, and I had an awful time trying to clean up, as you can imagine.
I did another couple of batches this afternoon with far better luck.
Now I know to only make one pass with the sponge and then rinse. I was experimenting with different pressures and speeds with the sponge. I found that slower with more pressure seemed to work best. Do you use one or both hands when sponging?
Thanks...
Old 07-30-2011, 12:41 AM   #5156
cocobolo's Avatar
The bottom shelf of the future bookshelf looks like this. It needs more sanding and shaping, but you get the idea.
In the past I have always used thinner cedar strips...and in future I will go back to that again. Too much pressure required to get several boards all clamped up at the same time. If you were just doing three to start (which I did on the second shelf) and then two at a time after that, it's not so bad.
Old 07-30-2011, 12:42 AM   #5157
cocobolo's Avatar
Oh no! Not another one!
gma2rjc (07-30-2011)
Old 07-30-2011, 12:45 AM   #5158
cocobolo's Avatar
Second shelf all glued up.
I'm not taking any chances with this one raising itself up in the middle, no matter how little. That's 125 pounds of tiles sitting on there. It was actually flat by the time I got to 35 pounds. Nothing like a little extra insurance.
Old 07-30-2011, 01:43 AM   #5159
Dorf dude...
shumakerscott's Avatar
I could have sent you my "Calibrated Rock" dorf dude...
Today is only yesterdays tomorrow, Now get to work!
shumakerscott is offline   Reply With Quote
Old 07-30-2011, 09:57 AM   #5160
cocobolo's Avatar
Hmmm...let's see now...cost of transportation from Germany to here...about $269.53...ahhhh, but it isn't adjustable like mine!
glue down hardwood flooring along gulf coast sbmcclean@sbcglobal.net Flooring 6 12-21-2008 02:55 PM
