Gulf Island Building. - Project Showcase - Page 315 - DIY Chatroom Home Improvement Forum
Old 05-31-2011, 07:43 PM   #4711
Rewards Points: 212
Originally Posted by jiju1943 View Post
I heard that Japan use to come over here with huge ships and buy a lot of lumber. They would pull out beyond the line and process the lumber and bring it right back and sell it to us.
I've heard that too. I always thought it was bullshirt. When you start thinking about the expanse required to house, power and provide labor for an industrial operation on shipboard, it's starts to seem pretty improbable.
A Squared is offline   Reply With Quote
Old 05-31-2011, 09:54 PM   #4712
Ole Wood Worker
BigJim's Avatar
Rewards Points: 192
Now you got me to thinking, you are probably right, the labor and housing alone would be out of sight. The thing that had me to thinking it probably wasn't correct in the past is how would they kiln the wood quickly, not to mention the space it would take up. Well so much for that.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 05-31-2011, 09:57 PM   #4713
Ole Wood Worker
BigJim's Avatar
Rewards Points: 192
Originally Posted by cocobolo View Post
Jim:
More than 50 years ago when I was working for a shipping company in Vancouver, we used to send boatloads of prime Douglas fir cants, 24" by 24" by 42' long over to Japan. They didn't process it offshore and bring it back...they stored it in freshwater lakes in Japan, and much of it was earmarked for rebuilding their old temples.
All the best wood cut here in British Columbia goes out of the country. We only consume about 5% of our annual production within the province.
We are about 15 miles from Nanaimo here (south east) and while our weather is very similar, it isn't always the same. Temperatures are always close, but they usually get more rain than we do.
Keith, that would take some big trees for sure. Is there a reason they keep the trees in fresh water?
It is hard for me to imagine all that many big trees. I was impressed to see 14"X14" 40 foot ceils in an home we restored built back in 1822. We don't have trees anywhere the size ya'll do.
Jim
Old 06-01-2011, 12:49 AM   #4714
cocobolo's Avatar
Rewards Points: 5,664
The vessels that were used to transport this superb lumber were originally built in Canada, and after the war were sold to the Union Steam Ship Company of New Zealand.
If I remember rightly, some of the names were "Waitomo", Waitemata", "Waikawa", can't remember the others (it's the old timers...), but these were Maori names.
They used to go into Kobe and Yokohama to offload. Most of the "Wai" boats were scrapped by about 1963 or so. Actually sold to Japanese interests for scrap.
The vessels were originally built to transport aircraft across the north Atlantic during WWII.
Just an old guy messin' with bits of wood...and old cars!
...the friendliest thread on the site! Come on by.
cocobolo is online now   Reply With Quote
Old 06-01-2011, 12:56 AM   #4715
cocobolo's Avatar
Jim, the trees don't rot in fresh water.
I have a book here somewhere which discusses the Douglas fir storage in the lakes over in Japan. Apparently, there are several lakes which were (or still are) used for the purpose.
Many of the Japanese temples get 25% of the structure rebuilt after 5 years, thus they are completely renewed every 20 years. They do this so that the kids today are able to learn from the old Japanese master carpenters as to how the buildings were originally done.
Many of the very old buildings, the one at Nagano for example, are many centuries old and still have the original wood.
Old 06-01-2011, 01:14 AM   #4716
cocobolo's Avatar
Early start this morning to get the woodworking done on the top of the walls which go around the windows overlooking the bay in the ensuite.
The first part was done a few days ago, but the rest were all completed today. Here's the second and third parts.
Old 06-01-2011, 01:18 AM   #4717
cocobolo's Avatar
When doing corners of this nature, it's a good idea if you can lap the corners in such a fashion that you do not see the open part of the wood joint from where you would normally look at it. Sort of like doing vinyl siding, you make the overlap face away from you so you don't normally see an open joint.
The corners invariably require that one of the boards has to be cut to fit, and for this I use the Japanese saw. Then I sand the edge smooth.
Rather than use the sandpaper on the wood, I use the wood on the sandpaper. This will give you a very flat and square edge. Like so.
Old 06-01-2011, 01:19 AM   #4718
cocobolo's Avatar
The last two high wall sections...
Old 06-01-2011, 01:21 AM   #4719
cocobolo's Avatar
Then it was on to the tiling, and here is the morning's efforts.
Old 06-01-2011, 01:23 AM   #4720
cocobolo's Avatar
By suppertime I had got this far. There are still about 20 pieces to cut and fit on each side of the door, which I'll have a crack at tomorrow.
The Following User Says Thank You to cocobolo For This Useful Post:
frenchelectrican (06-01-2011)
Old 06-01-2011, 09:26 AM   #4721
Rewards Points: 342
Thanks Keith, this is a great tip.
The tile is coming along nicely. I really like the dark tile boarder and dark grout around the light tiles.
Barb
gma2rjc is offline   Reply With Quote
Old 06-01-2011, 09:39 AM   #4722
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Slow down a little Keith...you are making me look bad.
XXX
Old 06-01-2011, 09:45 AM   #4723
Rewards Points: 342
Here's something that tells a little bit about it. Scroll down to the info by the spinning globe.
http://www1.american.edu/ted/sunkwood.htm#r1
Barb
The Following User Says Thank You to gma2rjc For This Useful Post:
cocobolo (06-02-2011)
Old 06-02-2011, 12:13 AM   #4724
Ole Wood Worker
BigJim's Avatar
Rewards Points: 192
Keith, you aren't letting any grass grow under your feet, that is really looking good buddy. Thanks for the explaining to me about the lumber under water, that does make sense.
Thanks Barb for the link, that is some good reading. I have seen pictures of some of the wood they brought up and milled out, it was beautiful wood to say the least.
Jim
Old 06-02-2011, 12:54 AM   #4725
cocobolo's Avatar
Hi Jim:
I got the tiling finished on the big ensuite wall this afternoon, so that's one more thing out of the way.
Now I still have to tile the two triangular shaped counter sections. Almost got all the tile cut for that this evening, but ran out of daylight. That will be the end of the tiling in there.
glue down hardwood flooring along gulf coast sbmcclean@sbcglobal.net Flooring 6 12-21-2008 02:55 PM
