Gulf Island Building. - Project Showcase - Page 300 - DIY Chatroom Home Improvement Forum
Old 02-24-2011, 07:16 PM   #4486
Tileguy
Bud Cline's Avatar
Rewards Points: 558
JiMell: "How do I cut an oval in 18" x 18" travertine tile?"
cocobolo has asked the following questions and offered the following advice:
Do you wish to make an oval from the tile? Or do you wish to remove an oval from inside the tile?
The first would be relatively easy. I would draw the oval, or ellipse shape on a piece of thin cardboard, and transfer that to the tile. Then I would cut as much tile off on the tile saw as possible, by making repeated cuts around the outside of the oval. Then I would grind the remaining segments off with a diamond blade on a hand held grinder.
Having said all that, I really don't know if travertine would lend itself to such treatment. It might be OK with the filled and polished travertine, but I must defer to Bud's immense experience for the final word.
Until the above questions are answered there is really no place to go from here.
Except to say that travertine should afford you the opportunity to do either procedure. Handle it gently and remember it is full of natural fissures and veins that could easy break without warning.
XXX
Old 02-24-2011, 08:03 PM   #4487
Ole Wood Worker
BigJim's Avatar
Rewards Points: 288
Originally Posted by cocobolo View Post
Sorry about the table Jim. Not much we could do about the very late snow.
My table, my table, oh my table.hehehe Buddy, it was cool before but now it is really cool. Sorry, I couldn't help myself. I have all the confidence in the world in you Keith, I know the finish you put on it will withstand anything nature can dish out. It does kinda hurt to see such a beautiful piece of art exposed to the elements, but that is what you created it for.
Keith, the flowers are so beautiful, I am amazed that they would grow in that kind of cold. Thanks for sharing the great photos.
Now for desert, your 35, you would have to keep me away from it cause I heard folks drooling on a cars finish will ruin it. That is going to be some serious fun, I know for sure you will do it justice. I can't wait til you start restoring it.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 02-24-2011, 08:39 PM   #4488
Rewards Points: 22
Talking
Good to see some pics again, I was going into some very serious withdrawls! Hopefully as the weather improves they will again appear more often... if only to keep that crazy Coco monkey off my back!
Lager
Lager is offline   Reply With Quote
The Following User Says Thank You to Lager For This Useful Post:
tpolk (02-25-2011)
Old 02-25-2011, 01:54 PM   #4489
cocobolo's Avatar
Rewards Points: 5,786
Here's a shot of how the steel rod was set into the upper stair posts. I dug out the space for the rod using the Fein tool, which made the job pretty easy. Then added a couple of screws to prevent the rod from shifting.
Just an old guy messin' with bits of wood...and old cars!
...the friendliest thread on the site! Come on by.
cocobolo is offline   Reply With Quote
Old 02-25-2011, 01:56 PM   #4490
cocobolo's Avatar
This is just a longer shot of the posts showing the steel rod in place again.
Old 02-25-2011, 02:00 PM   #4491
cocobolo's Avatar
The hand rail itself will need to be built up from short pieces of cedar, about 1 1/2" x 3" or so.
I haven't yet decided how these pieces will be fixed to the posts. Possibly by drilling and countersinking screws from below, or the same idea from above.
This first piece is temporarily held in place with a clamp.
Old 02-25-2011, 02:03 PM   #4492
cocobolo's Avatar
Currently - as anyone who lives near here will attest - we are experiencing unseasonably cold temperatures. I tried putting up some more boards at the top of the ensuite wall, but the hands only lasted about 10 minutes. Maybe later on when the sun has had a chance to work its' magic...
Old 02-25-2011, 02:53 PM   #4493
Rewards Points: 506
It's all looking great Keith! Especially that stairwell.
What is the darker trim above the ensuite window?
That's a nice color on the boards you're putting up.
Barb
gma2rjc is offline   Reply With Quote
Old 02-25-2011, 03:00 PM   #4494
cocobolo's Avatar
Barb
That is a row of 4" x 4" porcelain tiles.
The Following User Says Thank You to cocobolo For This Useful Post:
gma2rjc (02-25-2011)
Old 02-25-2011, 03:54 PM   #4495
Rewards Points: 186
You create...magic!
Keith, I have been 'dormant'..but..'lurking'..and I ...'found' a '37 Chev "flatback', enclosed in a barn, ..built around it! Tons of pigeon 'droppings' on it, but...it is in almost the same condition, as 'yours', but I have a wife, who is Scottish,and she says ..."nothing until the '38 Coupe is done", so the guy who owns it is about my age (64), and since 'no one' can see it, where it is, I have a (window of time) to get it!
Just love what you are doing with the wood...like a wizard!
Scoggy:thu mbsup:
scoggy is offline   Reply With Quote
Old 02-25-2011, 04:39 PM   #4496
cocobolo's Avatar
Scoggy:thu mbsup:
In that case...given that it will be some before I'm actually able to get started on my build...perhaps we will end up having a set of near twins.
Wouldn't that be cool!
BigJim (02-25-2011)
Old 02-25-2011, 07:10 PM   #4497
cocobolo's Avatar
I made an attempt to mock up a few pieces for the top railing. These test pieces are only 1 x 4's to try and establish the correct cutting angles.
Old 02-25-2011, 08:56 PM   #4498
cocobolo's Avatar
In somewhat of a stark contrast to the weather of the past week or more, here is tonight's sunset.
Old 02-25-2011, 09:02 PM   #4499
Rewards Points: 506
It's mother nature's way of saying she's sorry for the bad weather.
Old 02-25-2011, 09:28 PM   #4500
Ole Wood Worker
BigJim's Avatar
Rewards Points: 288
Keith, have you considered a bending rail type? For a couple of rails I made that bending rail just wouldn't work, I horizontally laminated the rail instead of vertical laminating. For a horizontal laminate I used 3/16 inch thick strips and heated the wood where there was a tough twist or bend, I used a heat gun but that might put too much strain on your electrical system, at times I used a small torch that worked well.
Your picture is just beautiful buddy, it looks like it belongs on a wall with a frame around it. Thanks for sharing Keith.
Jim
glue down hardwood flooring along gulf coast sbmcclean@sbcglobal.net Flooring 6 12-21-2008 01:55 PM
