Gulf Island Building. - Project Showcase - Page 265 - DIY Chatroom Home Improvement Forum
Old 11-18-2010, 01:44 PM   #3961
cocobolo's Avatar
Rewards Points: 5,456
When I went to put the anchor on, the shackle bolt wouldn't quite fit through the hole, so a little filing was in order.
Now it's all ready to go, and I just need the weather to co-operate for half an hour to finish the job. Not looking any too good right now.
Just an old guy messin' with bits of wood...and old cars!
...the friendliest thread on the site! Come on by.
cocobolo is offline   Reply With Quote
Old 11-18-2010, 01:46 PM   #3962
cocobolo's Avatar
Forgot to mention the last part of the job. Take your stainless steel wire and tie it several times through the little hole in the shackle bolt. That's a safety wire to prevent the bolt from working loose.
I find that if you wind the bolt in as tightly as possible with a pair of vise grips, it never moves. But better to be safe than sorry.
Old 11-18-2010, 04:18 PM   #3963
Ole Wood Worker
BigJim's Avatar
Rewards Points: 114
When I was in the Navy they taught us how to tie all kind of knots with rope but I only remember maybe two or three, a square knot, cinch knot and a plain ole knot and that is about it. I am impressed the way you fix that up, hopefully the wind don't get too high before you can get it all fixed up.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 11-18-2010, 05:36 PM   #3964
cocobolo's Avatar
The most common knot that we use in boating is the bowline. Absolutely indispensable.
I did get out to set the safety line...the rain had stopped, so I coiled the line up, grabbed the anchor and went out to the skiff.
No sooner had I poled away from shore when it started raining again. Naturally.
Anyway, got the shackle bolted to the mooring, payed the line out and dropped the hook.
As soon as I got back and into the house, the rain quit.
However, it has been raining steadily for the past 1/2 hour or so, and now doesn't look like it's going to quit. I'm guessing it will turn into snow tonight if this keeps up.
Old 11-18-2010, 05:56 PM   #3965
Ole Wood Worker
BigJim's Avatar
Rewards Points: 114
That's the way my luck goes too. I can just feel the wood heat coming from your heater, there is just no other kind of heat that feels that good to me. Man that is making me sleepy, all raining outside and inside by a wood heater all warm and cozzzzzzzz...
Jim
Old 11-18-2010, 06:02 PM   #3966
cocobolo's Avatar
I've got both the wood stoves going in the house now. Lovely!
The Following User Says Thank You to cocobolo For This Useful Post:
BigJim (11-18-2010)
Old 11-18-2010, 06:21 PM   #3967
Ole Wood Worker
BigJim's Avatar
Rewards Points: 114
Keith, if I have asked this question before please just slap me around a little. If you don't mind me asking, how many square feet do you have in your house?
Jim
Old 11-18-2010, 07:54 PM   #3968
cocobolo's Avatar
I think it is just over 1700 square feet. But I believe I only took that from one of the original plan drawings. As built, it may be different. I suppose I should figure it out one day.
Old 11-18-2010, 08:57 PM   #3969
" Euro " electrician
frenchelectrican's Avatar
That one of few knots I used and the one I use the most often when you have semi hollow core rope what I do is burn one end to make sure they are stay in place and make a pretty big loop and in that spot where you want to the loop to meet the main rope this what I do is untwist or push it together to compressed which it will open up the centre opening and push the rope in quite a bit way once you get it in place and just pull it out and it will lock in together.
With that set up it almost impossible to have that come apart.
Merci.
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
cocobolo (11-18-2010)
Old 11-18-2010, 10:20 PM   #3970
Rewards Points: 174
Hey Jim! You have 900 posts!!
gma2rjc is online now   Reply With Quote
The Following User Says Thank You to gma2rjc For This Useful Post:
Old 11-18-2010, 11:03 PM   #3971
cocobolo's Avatar
Merci.
Marc
That's right....I had forgotten about that one. There's a fellow from Washington State that Invented a slick little tool to do that with. I think his name is Brion Toss.
He was a rigger from Port Townsend I believe. We watched him demonstrate all sorts of different knots many years ago.
frenchelectrican (11-18-2010)
Old 11-18-2010, 11:05 PM   #3972
cocobolo's Avatar
Now here's the deal...how quickly can you get to 1,000?
Old 11-18-2010, 11:11 PM   #3973
Ole Wood Worker
BigJim's Avatar
Rewards Points: 114
Buddy, your home is almost twice the size as ours is (heated). We are empty nesters so we just don't need much room, easier on the shoctrisity and water bill. You have a really nice size home, that is the size most folks want to buy.
Jim
Old 11-18-2010, 11:15 PM   #3974
Ole Wood Worker
BigJim's Avatar
Rewards Points: 114
Thank you, thank you very much (my Elvis imitation) just call me ole rubber lips Jim. Come to think about it, I went to the same school Elvis did and had the same English teacher, didn't do me any good though.
Jim
Old 11-18-2010, 11:17 PM   #3975
The second strongest splices I do make from time to time is Western Union splice you can use either rope even cable if they are flexiable engough and when you get this done right it almost impossible to see the spice come apart and I have used few time in Marine useage.
As far for the number of posting IDK how fast if that person want to reach the goal.
I allready have over 15,000 posing in one of the French fourm { don't ask me how many keyboard I went thru on this one }
Merci.
Marc
The Following 2 Users Say Thank You to frenchelectrican For This Useful Post:
BigJim (11-18-2010), cocobolo (11-18-2010)
glue down hardwood flooring along gulf coast sbmcclean@sbcglobal.net Flooring 6 12-21-2008 02:55 PM
