Gulf Island Building. - Project Showcase - Page 261 - DIY Chatroom Home Improvement Forum
Old 11-14-2010, 05:23 PM   #3901
Home owner
Bootz's Avatar
Rewards Points: 150
Send a message via AIM to Bootz
the lady and I are doing the kitchen cabinets the same way.. inlaying the glass into the door and stuff... any suggestions?
Bootz is offline   Reply With Quote
Old 11-14-2010, 05:31 PM   #3902
cocobolo's Avatar
Rewards Points: 6,114
If you can post a pic of what you are starting with and the materials...I'll give it my best shot.
Just an old guy messin' with bits of wood...and old cars!
...the friendliest thread on the site! Come on by.
cocobolo is offline   Reply With Quote
The Following User Says Thank You to cocobolo For This Useful Post:
BigJim (11-14-2010)
Old 11-14-2010, 05:33 PM   #3903
cocobolo's Avatar
Time for coffee break...I'll have one or two pics a little later.
Almost done on the basic coverage, just some of the awkward bits and pieces to finish. But at least it looks as though I won't need to cut any more cedar - at least for the stairwell!
Old 11-14-2010, 06:15 PM   #3904
cocobolo's Avatar
This is the end of the continuous run of cedar on the top stairwell.
Last section - the ninth - this is below the window and now that's done.
Just on top of the window to finish, all tapered cuts...
Old 11-14-2010, 06:34 PM   #3905
Home owner
Bootz's Avatar
Rewards Points: 150
here are the cabinets that i and the miss are working on right now ... and no we did not put the handles on the cabinets... they are so plain and .. well.. ugly lol
and these....
and last one
That is the 3d view ... so I want to take out the middle and replace it with glass.. we are thinking the rice paper glass and painting the cabinets black... I know once that we get the glass in the cabinets we need to start keeping things "neat" in the cabinets but we think it will give the kitchen more of a modern look... btw I was really floored by the craftsmanship and the beauty of the glass that you put in with the flowing scene...
any suggestions? The middle of the cabinet looks like it is not part of the cabinet at all but loose almost...
Old 11-14-2010, 07:05 PM   #3906
cocobolo's Avatar
and these....
and last one
You're probably right about the panels being loose, but that's perfectly normal.
It wouldn't be hard to get the panels out, but the trick is going to be to be able to do it without destroying the door frames.
The first thing that comes to mind is that you might be able to cut around the edge of the panel, but leave an extra 1/2" or so protruding from the frames. Then you could add your glass - stained glass - or whatever you have, and fit that to the size of the frame. There should be enough room behind the glass to add a piece of trim to keep the glass in.
If that doesn't appeal, try using a couple of clamps to pull one of the door frames apart at the top or bottom. See what happens. If you can get one end of the frame out, then you can slide the panel out and replace it with your glass.
I'm sure there are other things, but see if that works first.
Bootz (11-15-2010)
Old 11-14-2010, 10:09 PM   #3907
Ole Wood Worker
BigJim's Avatar
Rewards Points: 798
Man I would have loved to have you do my bidding for me when I was in business. You said you would finish Sunday and by ned you did. I am happy for you Keith, I bet you are wore out tonight though. It sure does look good buddy.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 11-14-2010, 10:37 PM   #3908
cocobolo's Avatar
Thanks Jim...Just got some more finish on the wall, to the point where I ran out. So, next trip to town I'll need some more.
Couple of pics to d/l and I'll post in a few minutes.
Old 11-14-2010, 10:43 PM   #3909
cocobolo's Avatar
Here's what the finish looks like around the windows. The Minwax really does make the colour come up on the cedar. The missus thinks it's a bit too much, but it settles down somewhat when it dries - and it is only the satin finish.
Old 11-14-2010, 10:45 PM   #3910
cocobolo's Avatar
Taken from the bottom of the top stairs...the scaffold plank is still in the way, but I think you can see that all the fiddley bits are in up top.
I will finish the second coat of urethane up top before I pull the plank. There are a few boards to go on the wall where the plank support is, but they are all set to go.
Old 11-14-2010, 11:26 PM   #3911
jlhaslip's Avatar
Rewards Points: 2,884
How are you going to get the plank out of there?
Shinney up the chandelier chain???
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 11-14-2010, 11:45 PM   #3912
cocobolo's Avatar
Nah...I'll probably do something really silly...like stand on the stairs and yank it out.
Old 11-15-2010, 12:01 AM   #3913
Rewards Points: 780
My goodness, that is absolutely gorgeous Keith.
Is the ceiling on an angle - higher on one side?
Whew! That sure was a lot of work! But you probably already know that....
Thanks for posting the pictures.
gma2rjc is offline   Reply With Quote
The Following User Says Thank You to gma2rjc For This Useful Post:
cocobolo (11-15-2010)
Old 11-15-2010, 12:04 AM   #3914
Ole Wood Worker
BigJim's Avatar
Rewards Points: 798
My stars, that sure does make a difference, you saved the best for last. Just stunning Keith. That was a big project that you don't have to do again. Just think tomorrow you won't have to get up to the stair well.
Jim
The Following User Says Thank You to BigJim For This Useful Post:
Old 11-15-2010, 12:06 AM   #3915
cocobolo's Avatar
Indeed it is. I think the pitch of that roof is around 3 1/2 or 4/12.
I can tell you I'm glad that's over with. Just a bit more finish to apply and fill in the holes where the scaffold rests...and that's it.
glue down hardwood flooring along gulf coast sbmcclean@sbcglobal.net Flooring 6 12-21-2008 01:55 PM
