Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > Project Showcase
Old 11-13-2010, 07:19 PM   #3886
cocobolo's Avatar
Gulf Island Building.
Originally Posted by jiju1943 View Post
Keith, are you talking about the 1923 C-cab pickup? or
Man I done got my key board wet from droolin.
Buddy, when you do sell your home and move back over to the main land it is going to feel like a vacation with all the conveniences close at hand, you are going to be a city slicker again.
I never was much of a city slicker Jim...tried to keep away from there as much as possible.
Here's what I had in mind.
http://bellsouthpwp.net/g/o/gottac/index.htm
I hope that works, it's an old site showing a car which a young chap down in Florida re-did several years ago.
Just an old guy messin' with bits of wood...
...the friendliest thread on the site! Come on by.
cocobolo is offline   Reply With Quote
Old 11-13-2010, 07:20 PM   #3887
cocobolo's Avatar
Yep...just tested it and it seems to work fine.
Old 11-13-2010, 07:46 PM   #3888
STAFF
BigJim's Avatar
Oh my stars, that is totally beautiful Keith, man o man what a ride.
What motor would you build out for it. That would be the ultimate for me except for a 32 Ford coup.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is offline   Reply With Quote
Old 11-13-2010, 08:02 PM   #3889
cocobolo's Avatar
Most likely a small block Chevy. Possibly a big block. Although you wouldn't really need that much torque to move that guy out.
I'm more partial to the sound of a small block at 7500 than anything else. It would probably be able to break the speed limit on the highway in low gear anyway, so how much do you really need?
Old 11-13-2010, 08:18 PM   #3890
STAFF
BigJim's Avatar
Have you noticed how different the small block Chevys sound today compared to the 283-327s. I love the sound of a bad cam sitting there loping. I remember when the law would pull me over for something I would shut my car down and coast to the curb, I didn't want them to hear my engine or they really would get tough.
Did you like the dual line Holly carbs or the Quadrajet? Or did you like the gang deuces?
I was so disappointed in the 301 I built out, that I did my best to blow it, it just wouldn't blow. I sold it to a buddy of mine and he put it in a 55 Chevy two door post and they clocked him running around 135 MPH. That was saying something for a stock 55 body back then.
Jim
Old 11-13-2010, 08:29 PM   #3891
cocobolo's Avatar
Always preferred the Q Jet, although a lot of guys couldn't get along with them.
Once you knew them, they were terrific carbs. Great mileage on the front two barrels, but when you needed the afterburners to kick in, crank open the secondaries and you're gone.
Old 11-13-2010, 10:40 PM   #3892
cocobolo's Avatar
Quick update on the stairwell.
This is the 6th of 9 sections about 3/4 done.
Old 11-13-2010, 10:41 PM   #3893
cocobolo's Avatar
The start of the 7th section....more later.
Old 11-13-2010, 11:40 PM   #3894
cocobolo's Avatar
A good chunk of the 7th section done...
Old 11-13-2010, 11:41 PM   #3895
cocobolo's Avatar
This is the last section before the three windows at the top of the stairwell.
Old 11-13-2010, 11:44 PM   #3896
STAFF
BigJim's Avatar
I was partial to the Qjets also, I didn't have a problem with building them either. I tried to keep the back two ports closed as much as I could, when they were open it flew but so did the gas.
Jim
Old 11-13-2010, 11:50 PM   #3897
STAFF
BigJim's Avatar
You are getting closer Keith, I don't think I could ever get tired of looking at that beautiful wood. That is going to be one sharp stair well and stairs. I like the contrast of the different colors. Beautiful buddy!!!
Jim
Old 11-13-2010, 11:55 PM   #3898
cocobolo's Avatar
I'm going to need to put a finish on it as well. The sun will get to some of this wood, and I would rather that it retained its' colour - at least as long as we are here.
Which is why the scaffold plank is still up top.
With a lot of luck I hope the wall will be done tomorrow. If I can muster the energy I may try for the first finish coat tonight.
Old 11-14-2010, 09:30 AM   #3899
suprised you did'nt get one coat on before install. had a q-jet in my 69 camaro ss great carb for use at both ends of spectrum
The older I get the better I was
The Following User Says Thank You to tpolk For This Useful Post:
BigJim (11-14-2010)
Old 11-14-2010, 11:04 AM   #3900
cocobolo's Avatar
The reason I didn't do that was simply because when I am making up all the strips, they are all of varied lengths as they come off the saw. As they get applied, much of the wood ends up getting wasted. So they couldn't be done at that point.
Once the pieces are cut to length for any given section then they could have been coated, but it would have taken a huge amount of room which I don't have. Plus I would have needed to wait another 24 hours after coating to get them up.
So the best thing was to nail them all up and coat once that was done. The first coat did get put on about 80% of the boards last night.
Another very poor weather day here this morning, so hopefully - since I will be inside all day - I can get the last of the cedar up in the stairwell.
You had a '69 Camaro? Droooooooooll!
glue down hardwood flooring along gulf coast sbmcclean@sbcglobal.net Flooring 6 12-21-2008 02:55 PM
