Gulf Island Building. - Project Showcase - Page 257 - DIY Chatroom Home Improvement Forum
Old 11-11-2010, 11:16 PM   #3841
Ole Wood Worker
BigJim's Avatar
Rewards Points: 114
Originally Posted by cocobolo View Post
I have the very last of the top cedar cut for the highest part of the wall. The final three pieces are glued together due to a lack of backing.
Second coat of finish went on the wall today as well, and I think that will be enough.
It is just amazing how the finish brings out the color, but it does. Just beautiful Keith.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 11-11-2010, 11:28 PM   #3842
cocobolo's Avatar
Rewards Points: 5,456
Very true...this is a Minwax product I am using this time. It just seems to be called fast drying Polyurethane. It is a slightly hazy yellowish colour in the can, unlike the Varathane which looks decidedly white.
Thus far, it seems to go on a little easier as well. Not that the Varathane is hard to put on, this seems quicker I guess.
The two coats have got the cedar looking pretty good, whereas the Varathane takes 3 coats.
Just an old guy messin' with bits of wood...and old cars!
...the friendliest thread on the site! Come on by.
cocobolo is offline   Reply With Quote
Old 11-11-2010, 11:47 PM   #3843
Ole Wood Worker
BigJim's Avatar
Rewards Points: 114
Anything that will save you any work is a big plus with all you have to do. What kind of fast drying poly do you have, is it a water base?
Jim
Old 11-11-2010, 11:53 PM   #3844
cocobolo's Avatar
No, it's oil based Jim. The Varathane is water based, which is doubtless why it dries faster (4 hours).
I am finding that the Minwax effectively needs to be left for a day between coats. But with all I have to do elsewhere, that isn't really a concern.
Old 11-12-2010, 01:16 AM   #3845
E-lec-tri-city
Rewards Points: 150
Send a message via ICQ to brons2 Send a message via AIM to brons2 Send a message via MSN to brons2 Send a message via Yahoo to brons2
A few years back I tried to build out a 350 with the stock 10:1 comp ratio like back in the 60s, the block and heads were such sorry metal it burned the block in between two of the cylinders. The gas today isn't up to the high compression unless you buy AvGas or use a water injector to hold the ping down.
Lots of economy cars today running 10:1 or above on 87, it can be done easily with the right fuel and spark curves. You're not going to be able to stick a carburetor and points ignition on a clapped out 70s small block and run 10:1 though, that's a whole different deal.
$0.02.
brons2 is offline   Reply With Quote
Old 11-12-2010, 01:18 AM   #3846
Rewards Points: 186
Japan's Lake logs
Hi Keith. I heard quite a few years ago that they had discovered a flaw in their storage method of submersion, and had to do the logs quickly, or lose their valu AFAIK.
Cheers
Scoggy
scoggy is offline   Reply With Quote
Old 11-12-2010, 01:22 AM   #3847
cocobolo's Avatar
Cheers
Scoggy
Really? That would pose a real problem for them in that case.
The way I understand it is that they actually have several small lakes completely filled with big cants.
Some of the wood was due to be saved for temple re-construction. Haven't heard anything recently, but I guess I could check just for the heck of it.
BTW, how's the car coming?
Old 11-12-2010, 01:27 AM   #3848
cocobolo's Avatar
$0.02.
If you are referring to the modern FI system and electronic ignition, then I would have to agree with you brons.
I think most guys today who are building a SBC - while they may still use a carb - would also have long ago switched to a modern ignition. As long as the spark advance remains very mild, you'd probably be OK.
When we used to race donkey's years ago, we could get Sunoco 105 octane at the pump. Made for a great race day!
Old 11-12-2010, 01:43 AM   #3849
Rewards Points: 186
First Chev v/8
Keith, I believe it was either 1928 0r 1932, and although it was dropped from production, Henry Ford got wind of it, and that helped to spur on the development of the 'flatty' v/8, for '32! It was engineered by the same guy who eventually developed the auto matic for GM, as well as the self starter (Kittering??) I built a '66 Nova 2 door wagon, with a tricarbed , cammed, headered, 327, with a T-10 4 speed, and a 4:35 posi. It was the lowest level of could buy option,and I used to love to take my wife out on the old highway where the 4 lanes ran past the Dairy farm on the way to Chemainus, and stop on highway, rev it to red line, 'pop' the clutch, and feel the steering get way light, while her eyes got big like saucers! Guess I will be able to do same with my '38 Chev Coupe.....when I get it finished =====8^)
Cheers
Scoggy
Old 11-12-2010, 01:57 AM   #3850
cocobolo's Avatar
Cheers
Scoggy
Getting closer...but it was way before 1928!
Old 11-12-2010, 08:53 AM   #3851
Ole Wood Worker
BigJim's Avatar
Rewards Points: 114
$0.02.
I found that out the hard way. How do they cut the ping out now days running that low of octane? Today's cars and back then cars are worlds apart. I have got to put an intake gasket on our 2000 Nissan which has only 79,000 miles, man what a mess getting that thing off and back on right, nothing like the old days.
Jim
Old 11-12-2010, 08:56 AM   #3852
Ole Wood Worker
BigJim's Avatar
Rewards Points: 114
Cheers
Scoggy
You got any pictures of your 38? That has got to be a lot of fun.
Jim
Old 11-12-2010, 09:01 AM   #3853
Ole Wood Worker
BigJim's Avatar
Rewards Points: 114
Keith, have you tried the water based polyurethane? That stuff dries in just a few minutes and cleans up with water, I like it pretty good. I don't think I would use it outside though.
Jim
Old 11-12-2010, 11:59 AM   #3854
cocobolo's Avatar
What brand would that be Jim?
Varathane is a urethane of some sort, and it's water based. But still it is supposed to be 4 hours between coats. It does feel as though it is drier well before 4 hours if the temperature is up, but it's far more than a few minutes.
I don't believe that any of the water based products contain any UV inhibitors, which is why they aren't very long lasting outside.
Old 11-12-2010, 12:02 PM   #3855
cocobolo's Avatar
Chevy produced their first OHV V-8 over a two year period in - are you ready for this...
Nineteen seventeen and nineteen eighteen. You can win bets with this one.
glue down hardwood flooring along gulf coast sbmcclean@sbcglobal.net Flooring 6 12-21-2008 02:55 PM
