Gulf Island Building. - Project Showcase - Page 249 - DIY Chatroom Home Improvement Forum
Old 11-06-2010, 03:06 PM   #3721
cocobolo's Avatar
Rewards Points: 6,098
Originally Posted by jiju1943 View Post
Keith, is there a picture of your curved door back a ways in your thread? You know how my mind is, memory it's another thing I am short on.
Probably somewhere, but my memory is no better than yours.
So the easy solution was to click a pic.
Just an old guy messin' with bits of wood...and old cars!
...the friendliest thread on the site! Come on by.
cocobolo is offline   Reply With Quote
Old 11-06-2010, 03:14 PM   #3722
cocobolo's Avatar
The next thing that needs to be got out of the way is the cedar on the top stairwell. I estimate it's going to take me at least 50 hours...and that is as long as there is enough cedar already cut to cover it.
The ceiling reaches up just over 17 feet from the hallway floor, and the curved wall is 25' 8" long.
Being able to reach the top is half the battle.
This is the first of the bottom part.
Old 11-06-2010, 03:15 PM   #3723
cocobolo's Avatar
Got another shot of the light this morning in daylight.
Old 11-06-2010, 05:21 PM   #3724
Ole Wood Worker
BigJim's Avatar
Rewards Points: 540
In looking up at your light I see a lot of work you have done, that had to be tough to be done alone. Your door is beautiful, it reminds me of some of the glorious work on some high end yacht. My hat is off to you buddy.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
cocobolo (11-06-2010)
Old 11-06-2010, 05:38 PM   #3725
Ole Wood Worker
BigJim's Avatar
Rewards Points: 540
Originally Posted by cocobolo View Post
Indeed there is. Every month the major astronomy magazines will tell you where to look for any of our planets. Some of them have a two page spread with a pic of the night sky listing all sorts of objects. Once you get used to using it - like anything else it becomes second nature.
A dew shield is helpful to prevent dew building up on your objective lens or mirror.
If you take a look at most refractors (that's the one with the lens in front of the telescope) you will usually see a hood which projects out several inches beyond the lens. This helps to keep the dew away.
If you have a reflector, that's the one with a mirror at the bottom of the tube, the whole tube length is doing that job for you.
If you have Cassegrain type, they have the mirror at the back of the (usually short) scope, and a correcting lens in front. There is often no hood over the front. Frequently, these scopes will be fitted with a dew removal accessory system.
If you are in an area which experiences very little dew, in a dry desert for example, then the dew shield may not be necessary.
Thanks Keith, I appreciate that information.
Jim
Old 11-06-2010, 10:46 PM   #3726
Ole Wood Worker
BigJim's Avatar
Rewards Points: 540
Don't forget to set your clocks back tonight.
Jim
Old 11-06-2010, 11:07 PM   #3727
Rewards Points: 676
And check the batteries in your smoke detectors.
I once thought I had a flock of birds in my house. For several months I couldn't find them. When it was time to turn the clocks back, I changed the batteries in 10 of my detectors and wouldn't you know it, the birds left and there was no more chirping! -just kidding.
gma2rjc is offline   Reply With Quote
The Following User Says Thank You to gma2rjc For This Useful Post:
BigJim (11-06-2010)
Old 11-06-2010, 11:09 PM   #3728
cocobolo's Avatar
The good thing is I can see an hour earlier tomorrow...of course we get ripped off at the other end of the day.
Old 11-06-2010, 11:11 PM   #3729
cocobolo's Avatar
...and if you have fire extinguishers in your house...take them off their mounts, turn them upside down and give them a damn good shake. The dry powder inside often sticks together and then when you need them to work...!!!!!!!
The Following User Says Thank You to cocobolo For This Useful Post:
gma2rjc (12-22-2011)
Old 11-06-2010, 11:21 PM   #3730
Ole Wood Worker
BigJim's Avatar
Rewards Points: 540
I forgot about the smoke detectors and fire extinguishers, I don't need any of them birds chirpin around here. Thanks Barb and Keith.
Jim
Old 11-06-2010, 11:35 PM   #3731
Ole Wood Worker
BigJim's Avatar
Rewards Points: 540
Keith, it is 35F here right now and will hit 28 after while. It looks like ya'll will hit around 42F, I am glad the hot weather is finally gone, it was a rough one.
Jim
Old 11-07-2010, 12:06 AM   #3732
cocobolo's Avatar
Amazing...I just checked the Nanaimo temp on Accuweather and it is 11C (about 52F). The real feel is 4C, about 39F.
Raining like gangbusters here and has been most of the day.
I'm going to try and work out how many square feet of cedar it's going to take for the top stairwell tomorrow. I got up to about the 10 foot level on the second row today...I know it doesn't sound like a lot, but believe me, I had to work at it all day to get there.
I'm nearly out of the pre-cut stuff, so tomorrow will be at least half a day of machining. Might as well get it all done in one go.
Old 11-07-2010, 07:02 AM   #3733
Ole Wood Worker
BigJim's Avatar
Rewards Points: 540
It sounds like a lot to me and would sound like a lot more if I were doing it. That is really time consuming, there is no way to make that type of work faster by yourself. It will be a master piece when you are finished buddy and that is one less thing you will have to do.
It is 30F here right now and a pretty big frost, I may have to paint a fireplace on the wall with a fire so we can get warm.
Jim
Old 11-07-2010, 10:33 AM   #3734
jlhaslip's Avatar
Rewards Points: 2,792
High of the day is 8 deg C (41 deg F) and white stuff overnight.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 11-07-2010, 11:08 AM   #3735
cocobolo's Avatar
Won't your paint freeze before you get the job done?
glue down hardwood flooring along gulf coast sbmcclean@sbcglobal.net Flooring 6 12-21-2008 01:55 PM
