Gulf Island Building. - Project Showcase - Page 242 - DIY Chatroom Home Improvement Forum
Old 10-31-2010, 06:31 PM   #3616
Ole Wood Worker
BigJim's Avatar
Rewards Points: 288
Originally Posted by cocobolo View Post
Thanks...I sure hope it is!
Incidentally, on those diamond hones...all mine came away from the backing when they were cold.
I haven't actually re-fixed them yet, but perhaps a few dots of silicone around the outside would hold them.
You mentioned rubber with yours...Is there a rubber backing? I don't have that on mine.
I was just the opposite, my diamonds were mounted on a block of walnut and I like to have never got them off, I didn't like them mounted.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 10-31-2010, 06:48 PM   #3617
cocobolo's Avatar
Rewards Points: 5,786
Originally Posted by jlhaslip View Post
Maybe you should burn a bale of that green stuff to keep those diamond hones together...
Yup, cold weather did it here, too. They were so cheap I didn't worry about fixing it.
Silicone *might* work, but I've spilled 3-in-1 oil over mine, so it might not work for me.
Green stuff.....green stuff.....what green stuff are we talking about this time...
I might have got mine from Lee Valley ages ago, or maybe Midland over in Nanaimo. Either way, they fell apart the first time I used them.
Now if I use them, I put them on a workbench and run the tool over the top.
Just an old guy messin' with bits of wood...and old cars!
...the friendliest thread on the site! Come on by.
cocobolo is offline   Reply With Quote
Old 10-31-2010, 09:24 PM   #3618
jlhaslip's Avatar
Rewards Points: 1,494
Oregano Hay... What were you thinking???
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 10-31-2010, 09:50 PM   #3619
cocobolo's Avatar
That's it...just couldn't remember the name!
Old 10-31-2010, 10:20 PM   #3620
cocobolo's Avatar
Almost done. There are a couple of narrow trims I need to make up to finish, but the appearance won't change much. Better in daylight for that.
The photo is without flash, which let the colour on the ceiling show from the light on the other side of the window.
The Following User Says Thank You to cocobolo For This Useful Post:
avengerki (11-08-2013)
Old 10-31-2010, 10:25 PM   #3621
cocobolo's Avatar
This one is much more awkward to get at. Most of the bottom wood is on, none of the top.
It needs backing and a few fancy cuts, another daylight job.
Old 10-31-2010, 11:09 PM   #3622
Rewards Points: 504
WOW! That is absolutely beautiful Keith.
gma2rjc is offline   Reply With Quote
The Following User Says Thank You to gma2rjc For This Useful Post:
cocobolo (10-31-2010)
Old 10-31-2010, 11:23 PM   #3623
cocobolo's Avatar
Merci beaucoup...it's starting to come together now.
The missus wanted to PAINT some of the walls in the guest room...
...and without me saying a word, she has magically changed her mind. This is one of those times I'm only too happy that she has!
It seems that I can no longer find any excuse not to do the floor in there now.
Old 10-31-2010, 11:46 PM   #3624
Rewards Points: 504
Here's one you can use -
"I'll wait and do this floor the same time I do the rest of the floors upstairs."
or
"This floor can be a winter project. I better get other things done while it's still fairly nice outside."
Let me know if you need any more excuses. I have a million of 'em.
Old 11-01-2010, 12:06 AM   #3625
cocobolo's Avatar
or
I came up with another one.
"How do you expect me to lay a floor when there is a bed in there?"
Old 11-01-2010, 12:32 AM   #3626
Rewards Points: 504
She'll say, "Take the bed apart and move it out of there".
Old 11-01-2010, 09:44 AM   #3627
Now both the end hand rail and the post are glued up, and will stay clamped until tomorrow.
One thing to remember when clamping up something with many layers of wood - once you have it clamped tightly...wait about 5 minutes and re-check the clamps. There's a good chance that some of them will tighten a little more.
It's also good to remove excess glue to avoid chips in planer blades etc after hardening. Also good to not wipe glue off with wet rag as this can smear glue into wood fibers and cause problems with stain not absorbing correctly in these areas. just a thought. timothy
The older I get the better I was
The Following User Says Thank You to tpolk For This Useful Post:
cocobolo (11-01-2010)
Old 11-01-2010, 12:48 PM   #3628
cocobolo's Avatar
Once again you are 100% correct!
Just let the glue set up until it is hard, and use a chisel or scraper to knock any of the small lumps off.
Using the damp rag makes an awful mess. You get a big area covered with a film of glue, and if it doesn't get planed off you're in trouble.
It won't take stain - or any other finish properly for that matter.
I use a brush for glue application and the two part glue I use mixes up quite thin. It's easy to spread and get a nice even layer. Usually not that much squeeze out - although when I made the workbench I went a bit overboard on the glue.
Old 11-01-2010, 12:49 PM   #3629
cocobolo's Avatar
Originally Posted by anna38 View Post
The original pictures you posted are beautiful!! Great views!!
Thank you anna, and welcome to the thread. I hope you enjoy!
Old 11-01-2010, 12:52 PM   #3630
cocobolo's Avatar
It's on wheels, so I think we can get away with putting the floor down on one side of the room and then shifting the bed over.
And I can't use the winter excuse, as that seems to be upon us today. We had big winds and loads of rain last night. The rain has quit, but the wind is showing us no mercy at all.
glue down hardwood flooring along gulf coast sbmcclean@sbcglobal.net Flooring 6 12-21-2008 01:55 PM
