Gulf Island Building. - Project Showcase - Page 241 - DIY Chatroom Home Improvement Forum
Old 10-31-2010, 03:03 PM   #3601
cocobolo's Avatar
Rewards Points: 5,458
Well, these custom things always seem to take longer than we plan...but it all went well.
I couldn't find a piece of Douglas fir that was good enough to make the mould from, so I ended up wasting a perfectly good piece of yellow cedar. I know I should be hung for that, but whattareyagonnado?
Here I had it planed to thickness, and it has just come off the table saw after being ripped.
Just an old guy messin' with bits of wood...and old cars!
...the friendliest thread on the site! Come on by.
cocobolo is offline   Reply With Quote
Old 10-31-2010, 03:04 PM   #3602
cocobolo's Avatar
You can see here the original mould shape, which has to be modified for the corner post.
Old 10-31-2010, 03:07 PM   #3603
cocobolo's Avatar
It's quite straight forward as to how this is calculated...just draw the line from the original first.
Then I marked off lines at every 3". Drew a straight line in front of the curve.
Then measured the distance between the two lines at each of the cross lines - every 3". Added 40% to that on the outside of the curve. Then put some small nails on the intersecting lines.
Old 10-31-2010, 03:09 PM   #3604
cocobolo's Avatar
Using that thin batten in the above photo, I pushed the batten against the nails and drew the line to follow the new curve. It should show easily here.
Old 10-31-2010, 03:10 PM   #3605
cocobolo's Avatar
Remove the nails and cut the new shape out on the line.
Old 10-31-2010, 03:11 PM   #3606
cocobolo's Avatar
Following the completion of the cut, I did a dry test with the cedar strips - ALWAYS do a dry run first - you never know what might crop up.
Old 10-31-2010, 03:14 PM   #3607
cocobolo's Avatar
Now both the end hand rail and the post are glued up, and will stay clamped until tomorrow.
One thing to remember when clamping up something with many layers of wood - once you have it clamped tightly...wait about 5 minutes and re-check the clamps. There's a good chance that some of them will tighten a little more.
Old 10-31-2010, 03:23 PM   #3608
jlhaslip's Avatar
Rewards Points: 390
Good method on the post layout... should be WAYYYYYYYYYYYYYYYYYY within tolerance.
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Old 10-31-2010, 03:46 PM   #3609
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
Good gravy, you don't let any grass grow under your feet. Thanks for the explanation buddy.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 10-31-2010, 05:02 PM   #3610
cocobolo's Avatar
Thanks...I sure hope it is!
Incidentally, on those diamond hones...all mine came away from the backing when they were cold.
I haven't actually re-fixed them yet, but perhaps a few dots of silicone around the outside would hold them.
You mentioned rubber with yours...Is there a rubber backing? I don't have that on mine.
Old 10-31-2010, 05:03 PM   #3611
cocobolo's Avatar
Hmmmm...just exackly what kinda grass we talkin' 'bout here...
Old 10-31-2010, 05:24 PM   #3612
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
I was just talkin about regular grass, not that left handed kind.
Jim
Old 10-31-2010, 05:32 PM   #3613
cocobolo's Avatar
Gotcha!
Old 10-31-2010, 06:32 PM   #3614
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
Originally Posted by cocobolo View Post
Gotcha!
Jim
Old 10-31-2010, 06:38 PM   #3615
jlhaslip's Avatar
Rewards Points: 390
Maybe you should burn a bale of that green stuff to keep those diamond hones together...
Yup, cold weather did it here, too. They were so cheap I didn't worry about fixing it.
Silicone *might* work, but I've spilled 3-in-1 oil over mine, so it might not work for me.
glue down hardwood flooring along gulf coast sbmcclean@sbcglobal.net Flooring 6 12-21-2008 02:55 PM
