Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > Project Showcase
Old 10-30-2010, 08:44 PM   #3571
STAFF
BigJim's Avatar
Gulf Island Building.
I use some of the jeweler's rouge on the hand held on one side and tooth paste on the other. Tooth paste is about 8,000 grit and does a great job polishing tools.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is online now   Reply With Quote
Old 10-30-2010, 08:53 PM   #3572
cocobolo's Avatar
Originally Posted by jiju1943 View Post
$20.00 is a bargain for a tool like that. Can you resharpen the blades? Do they come off so they can be honed?
I just looked at that Jim...and yes, the blade comes off. So you could definitely re-sharpen it.
Plus, of course, they will be happy to sell you a replacement blade!
Just an old guy messin' with bits of wood...
...the friendliest thread on the site! Come on by.
cocobolo is offline   Reply With Quote
Old 10-30-2010, 08:56 PM   #3573
cocobolo's Avatar
Hey buddy, what kind of sharpening system do you have for sharpening your chisels and blades?
I prefer to use the Japanese water stones, Jim. I find that they cut quickly and easily. I have a number of the very small stones as well, which can be used for gouges and the like.
I haven't used them in awhile (the small ones) so maybe I should dig them out to remind myself what I have!
Old 10-30-2010, 08:58 PM   #3574
cocobolo's Avatar
I have a hard felt wheel with jewelers polishing compound to sharpen my carving knives. I have to sharpen my planer blades by hand.
I have the felt wheel as well. I believe I have two compounds for that, the one I seem to use most often is the green one. Not sure what they call that...again, it's something I got from Lee Valley.
Old 10-30-2010, 09:00 PM   #3575
cocobolo's Avatar
Remember when you were a kid...did you ever make any of those plastic car models and then spray paint them?
I used to use toothpaste for a cut polish way back then. I had no idea at all what the grit was, but I wouldn't doubt in the least that it's about 8,000.
Old 10-30-2010, 09:01 PM   #3576
STAFF
BigJim's Avatar
I didn't get mine from Lee Valley, was your out of round pretty bad when you first put it on your grinder?
Jim
Old 10-30-2010, 09:04 PM   #3577
STAFF
BigJim's Avatar
Buddy, I didn't think about using tooth paste as a polishing compound on paint but I know it would work.
Jim
Old 10-30-2010, 09:07 PM   #3578
STAFF
BigJim's Avatar
Keith, when I was a kid I did paint a bunch of cars but I didn't really didn't know how to make the paint look better by polishing it.
Jim
Old 10-30-2010, 09:08 PM   #3579
cocobolo's Avatar
I think it was probably OK, but it has been on there so long I don't remember.
I believe you need to make sure it is well centered on the arbor if it isn't a snug fit. Either that, or you need to use a bushing.
Old 10-30-2010, 09:11 PM   #3580
STAFF
BigJim's Avatar
My felt wheel was so out of balance I had to screw the grinder down to keep it still. I finally got it balanced a little where I can use it now.
Jim
Old 10-30-2010, 09:26 PM   #3581
STAFF
BigJim's Avatar
I had the bushing and did what the fellow who sold them told me to do but it was really out of hoodoo bad. I have my felt wheel where it will rotate upward instead of downward like they normally run.
Jim
Old 10-30-2010, 09:28 PM   #3582
STAFF
BigJim's Avatar
The reason I have my felt wheel running backwards is so I can see the edge of my knives. If the wheel is running like it normally would the knife blade edge would have to be on the bottom and wouldn't be able to see the edge.
Jim
Old 10-30-2010, 09:37 PM   #3583
STAFF
BigJim's Avatar
With a carving knife being sharpened on such a steep angle the edge is very thin and will over heat quickly, if the metal ever changes color the metal in the knife is shot.
Jim
Old 10-30-2010, 09:45 PM   #3584
STAFF
BigJim's Avatar
I have made several caving knives and they turned out fairly well. One thing to make a good knife out of is an old file. The file is very hard and will hold a great edge for a good while. The down side is it is very brittle and has no flex at all so beware it will snap easily.
Jim
Old 10-30-2010, 09:49 PM   #3585
STAFF
BigJim's Avatar
Speaking of brittle, notice how well your pocket knife holds up and will not snap the end off easily. That is because a pocket knife is not tempered that well to hold an edge so the blade will flex. The knife folks know that no one wants a knife if the blade breaks easily but they will buy a knife even if it dulls easily so they make the pocket knives with less temper and the blade won't stay sharp long.
Jim
The Following User Says Thank You to BigJim For This Useful Post:
gma2rjc (10-31-2010)
glue down hardwood flooring along gulf coast sbmcclean@sbcglobal.net Flooring 6 12-21-2008 02:55 PM
