Gulf Island Building. - Project Showcase - Page 204 - DIY Chatroom Home Improvement Forum
Old 10-12-2010, 11:10 AM   #3046
jlhaslip's Avatar
Rewards Points: 1,520
Robertson are the square ones. Canadian.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
The Following User Says Thank You to jlhaslip For This Useful Post:
cocobolo (10-12-2010)
Old 10-12-2010, 11:44 AM   #3047
Ole Wood Worker
BigJim's Avatar
Rewards Points: 290
Oh, OK, I do know what they are, I didn't know they were called that. I always called them square drive screws. I hate the SS screws like that unless screwing into soft wood. I really do appreciate you taking your time to show me the screw.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 10-12-2010, 12:23 PM   #3048
cocobolo's Avatar
Rewards Points: 5,788
Everyone in the States calls them square drive screws Jim...but if they had been invented by an American instead of by a Canadian, they would no doubt have a different name.
Much like Phillips, only Robertson was the fellows name who came up with this one.
Stainless steel screws have a tendency to be soft, so you always need to pre-drill for them anyway.
From my way of thinking both Phillips and slot screws ought to be outlawed, the Robertson is 10 times better.
cocobolo is offline   Reply With Quote
Old 10-12-2010, 01:15 PM   #3049
Ole Wood Worker
BigJim's Avatar
Rewards Points: 290
There ya go, I didn't know one of your fellow countrymen invented that screw. You are right, if some fellow here had invented it it would have been named something else.
Of the three screws my least favorite is the slotted screw, I hate that thing. One thing I see that may need be done on the screw tip for the Robertson is a little more temper, most square drive tips we get here are kinda soft and don't last long at all. Another thing I have noticed with screw tips is the phillips tip, most screw suppliers give with the screws, are the wrong size tips, they are usually too large. The best tips I have found that work for me are the sheet rock screw tips, they fit good and are tempered pretty good to last for a while.
Jim
Old 10-12-2010, 01:53 PM   #3050
cocobolo's Avatar
That's very true...I remember when I was in the boat building game, we used to buy the drywall screws by the box and use them to temporarily hold the cedar strips in place on the bigger boats. As soon as the glue was set, pull the screws and re-use them. Sometimes the epoxy would hold so well on the steel that it would snap the screws off. The trick was to pull the screws just as soon as the epoxy was set and not wait overnight.
Old 10-12-2010, 02:00 PM   #3051
Dorf dude...
shumakerscott's Avatar
Rewards Points: 1,190
Ok you older guys, what about Torx screws? I have built my whole house with them, the more surface area on the inside to contact the bit the better. There is also an Assy screw here in Germany that is basically a Torx with even more surface area, like a Phillips is to a PZ. My impact driver kills PZ bits and screws. Torx rock in my book. dorf dude...
Today is only yesterdays tomorrow, Now get to work!
shumakerscott is offline   Reply With Quote
Old 10-12-2010, 02:08 PM   #3052
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I think General Motors is credited with the inventuion of the "Torx" screws. They did it just to piss a guy off back in the '60's.
XXX
Old 10-12-2010, 02:16 PM   #3053
Ole Wood Worker
BigJim's Avatar
Rewards Points: 290
I don't think I have ever seen a Torx wood screw, the only place I have seen them is in a car and machinery.
That is the truth Bud, back then no one had a Torx driver and it did make it hard to get them things out.
Jim
Old 10-12-2010, 02:28 PM   #3054
cocobolo's Avatar
...and now they seem to still use them for things like headlight and taillight covers.
The Following User Says Thank You to cocobolo For This Useful Post:
BigJim (10-12-2010)
Old 10-12-2010, 02:30 PM   #3055
Dorf dude...
Lets see if this works...
Ecofast Wood Screw: Self-Countersinking ASSY-Screw.
Allows for faster driving while still providing a 40% stronger hold!
High quality case hardened construction strongly deters head damage.
The Patented AW Drive System combines all the advantages of Phillips, Square, Torx", & Pozi Drive Bits.
Best torque transfer due to the number of contact points. Easy to insert AND extract. Self-
Centering of the bit in the screw head allows accurate screw placement.
No Come Out Drive prevents damage to screw head, enables easier driving into tough materials.
It did!
Old 10-12-2010, 02:37 PM   #3056
cocobolo's Avatar
That looks like a dandy...I haven't seen them over here. I think I will ask Slegg's if they know of them since the House of Pot most likely wouldn't have a clue.
Do you know how the price compares to a conventional screw?
Old 10-12-2010, 02:47 PM   #3057
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Taken out-of-context...that is hilarious.
I digress, just couldn't pass it up.
XXX
Old 10-12-2010, 02:48 PM   #3058
Dorf dude...
I'll let your inner psycic work on this one.....
Old 10-12-2010, 02:51 PM   #3059
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Around here we have been using Torx wood screws for a long time...
EIGHT BUCKS A POUND!!!!!!!
XXX
Old 10-12-2010, 02:58 PM   #3060
cocobolo's Avatar
Which means I can afford to buy two ounces worth!!!
glue down hardwood flooring along gulf coast sbmcclean@sbcglobal.net Flooring 6 12-21-2008 01:55 PM
