Gulf Island Building. - Project Showcase - Page 110 - DIY Chatroom Home Improvement Forum
Old 07-09-2010, 05:09 PM   #1636
cocobolo's Avatar
Rewards Points: 6,098
Shedua left...lacewood right
cocobolo is online now   Reply With Quote
Old 07-09-2010, 05:11 PM   #1637
cocobolo's Avatar
Bubinga left...bird's eye maple right...
Anyone have a preference?
Old 07-09-2010, 05:30 PM   #1638
Newbie Bill
Rewards Points: 522
Bubinga is my preference.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 07-09-2010, 05:39 PM   #1639
cocobolo's Avatar
Thanks...I like that one too.
Old 07-09-2010, 06:35 PM   #1640
Rewards Points: 656
There's a place up in Northern Michigan where they grow Birdseye Maple's. A gentleman told me just a few weeks ago that when they load the trucks with these maples and haul them out of the woods, they have to have a police escort until the truck reaches it's destination. The wood is so valuable that people will hijack the truck otherwise.
I'll have to wait to pick which kind of wood to use until I see what the table top looks like when it has a few coats of varathane. They're all very pretty, but the canary caught my eye.
Which one holds up best out in the weather?
gma2rjc is offline   Reply With Quote
Old 07-09-2010, 09:33 PM   #1641
cocobolo's Avatar
I have heard that about several kinds of trees. Whether or not it's true I don't know. Birdseye isn't that uncommon, and actually whether or not a maple has the birdseye feature or not depends on a number of factors. As much luck as anything.
OK, the boards will have the butterfly joints installed before any varnishing gets done. The butterfly becomes part and parcel of the board at that point...you'll see.
As for weathering, I'll check on that, but I suspect that all of them would outlast the arbutus.
Old 07-09-2010, 10:43 PM   #1642
cocobolo's Avatar
First up, almost all these woods have a variety of different names, with the exception of birdseye maple. Everyone seems to agree on that. I doubt the maple would be durable outside.
The canarywood is not durable.
The zebrawood is termite resistant, but not durable as well as being unstable.
Shedua, or amazakoue, or gabon ovanko, or mozambique, or ovengkol is moderately durable.
Lacewood has fair resistance to decay, but has other problems.
Bubinga, also known by a variety of other names is moderately durable, takes finishes well and is moderately easy to work.
None of these woods is what you could call "easy" to work.
It appears that Bubinga may win by default. It is also an exceptionally strong wood.
Old 07-09-2010, 11:38 PM   #1643
cocobolo's Avatar
More shiny things...got the hinges screwed on to the bits of plywood this afternoon. Now I have a cover...of sorts.
Old 07-10-2010, 12:15 AM   #1644
Rewards Points: 656
Did you bring the different varieties of wood with you to the island, or did you find the trees in the bay?
The lid looks nice. I was wondering though, how deep is the hot tub and what else do you have to do to it before you can start using it?
Old 07-10-2010, 12:24 AM   #1645
cocobolo's Avatar
Not much chance of finding trees like these here! With the possible exception of the maple. The rest are from central Africa or central or south America.
These particular pieces I got from a Canadian supplier, intended for fingerboards for bass guitars.
Tub is just under 4' deep. Still have to make a setup for the plumbing, and a seat or two inside the tub.
Old 07-10-2010, 10:05 PM   #1646
Rewards Points: 656
The spot that had the deterioration doesn't look bad at all now.
Old 07-10-2010, 10:20 PM   #1647
jlhaslip's Avatar
Rewards Points: 2,666
Don't forget a hook to hang your trunks / towel on.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 07-11-2010, 01:05 AM   #1648
cocobolo's Avatar
The towel I understand, but the trunks...???
Old 07-11-2010, 01:10 AM   #1649
cocobolo's Avatar
It might be a case of looks being a bit deceiving. The wood itself has lost some of its' density there.
Unprotected arbutus is subject to getting a fungal growth if it stays damp for too long. Even though the wood was covered, I think this is what happened.
It hasn't gone punky or anything like that, but it is definitely not the same as nice new wood.
Old 07-11-2010, 01:13 AM   #1650
cocobolo's Avatar
The two halves are being glued up here. You can't see much, but they came together quite well. Gluing up curves is a bit tricky sometimes.
glue down hardwood flooring along gulf coast sbmcclean@sbcglobal.net Flooring 6 12-21-2008 01:55 PM
