Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > Project Showcase
Old 10-22-2009, 07:14 AM   #1
Tool Geek
PaliBob's Avatar
Default GFCI Tester
This is my design for a GFCI Tester to check the current leakage margin to help analyze nuisance trips.
The box is a Carlon Handy Box
http://www.carlon.com/Brochures/2B1-Handy-Low.pdf
S1 is a C&K miniature Toggle model E107 which is center OFF and momentary in the spring loaded up or down position.
DS1 is a green neon which pulls 1.3 mA. Any color neon can be used but there is variance among colors and models. I tuned my Neon circuit with a bleeder resistor to pull a measured 2.01mA @ 119.5V.
gfci-tester-gfci-b0b-test2.jpg   gfci-tester-gfci-b0b-test1.jpg   gfci-tester-gfci-test-ckt1.jpg   gfci-tester-gfci-test-table1a-jpg.jpg
Disclaimer
& Stay Safe
.....Bob
Last edited by PaliBob; 10-26-2009 at 04:41 PM. Reason: rev Test Table Conditions for clarity
More On This Topic
Neon-Geek Mixed Drink
Neon-Geek Mixed Drink by Expert Village
Alright, the drink we're about to make is called Neon Geek. We're going to serve this up in a Martini glass. You can also serve it in a Margarita glass, if you like. Put some water and ice in there, get it nice and chilled so that when you're done making... Read More »
Part 2 - Learn how to string a fender stratocaster electric guitar in this diy guitar setup video. Read More »
One type of body fat tester utilizes a caliper system that squeezes certain areas of the body's skin. These testers rank high in popularity. They calculate the amount of fat a person has with the use of an equation. Some have digital readouts, while... Read More »
How to Use a Plug Tester
How to Use a Plug Tester by Expert Village
This is a plug tester, these lights light up when there's power to the plug. It tells you what the problem is if there's a problem. It shows you what's correct, they have a little code on there a little legend and it'll tell you if the hot and ground are... Read More »
Learn how to clean a fender stratocaster electric guitar in this diy guitar tech video. Read More »
Gfci Circuit howard.wheaton Electrical 10 01-29-2009 07:14 PM
Freezer tripping GFCI davidclements Appliances 29 01-14-2009 07:32 AM
On one outlet my GFCI tester has all three lights lit. What does it mean? Deck Electrical 6 07-09-2008 11:18 PM
GFCI Question Mdbuilder Electrical 6 06-19-2008 05:15 PM
GFCI questions 5circles Electrical 4 11-05-2007 10:24 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
