German House Rebuild - Project Showcase - Page 90 - DIY Chatroom Home Improvement Forum
Like Tree11Likes
Old 11-09-2010, 09:36 PM   #1336
Woodtick
Dorf Dude! WOW! I stumbled across your project last week and just finished going thru the entire thing last nite around 11:00. What a job! I have to salute your determination and perseverance. You stuck to your vision despite the naysayers, and the budgetary constraints. Your home is outstanding! You have a real good 'art chip' in that noggin of yours. You did a good job of keeping the existing and traditional while bringing in the modern. And the sandstone wrap on the window holes with the stuccoed interior? Way cool! I also enjoyed the comments from your DIY'er friends. As long as there are smart @ss's in the world there will be hope for humanity. Keep up the good wok. I look forward to seeing what you have planned for the upstairs.
ccnvchris is offline   Reply With Quote
Old 11-10-2010, 12:49 AM   #1337
Dorf dude...
shumakerscott's Avatar
Rewards Points: 1,190
The lights are from a chain store called Lidl. They were 5.99 each. Here is one guys review. I'm going to try and get more of them. dorf dude...
Lidl Offer Livarno 3W GU10 Spotlight
On 2010/09/02 Lidl had an offer of 5.99 for 3W LED lamps, in various fittings including GU10, Livarno brand (EDI Light GmbH), and claiming ~60lm/W on the box, ie about 180lm total. This lamp certainly seems less bright than the Econic at ~250lm, but the beam angle of 90 of this lamp cf the Econic 25 confounds easy comparisons.
If the lumen values are correct then this Lidl lamp is less good efficiency (ie lm/W) but much better value (lm/)! Both of them however do well in efficiency terms compared to CFL (at least as good) especially given the GU10 fitting.
The light is a pleasant colour, and the multiple (15) emitters/chips make for a less harsh 'point-source' feel.
My daughter preferred this to her current (6000K) bedside lamp, primarily because this illuminates the far end of her bed better given its broader beam; it seems to throw significant useful light beyond the 90 stated, possibly in part because of its slightly domed front.
This comes on quickly, faster than the V3 for example.
Like the Econic, this claims a 25,000 hour life.
Today is only yesterdays tomorrow, Now get to work!
shumakerscott is offline   Reply With Quote
The Following 3 Users Say Thank You to shumakerscott For This Useful Post:
cocobolo (11-10-2010), frenchelectrican (11-10-2010), scoggy (11-12-2010)
Old 11-10-2010, 01:27 AM   #1338
Dorf dude...
The door is temp because I will add a mud room with about 200sq ft in the spring. The door will be reused. The original door is still mounted inside. dorf dude...
BigJim (11-10-2010), cocobolo (11-10-2010), scoggy (11-12-2010)
Old 11-10-2010, 11:52 AM   #1339
E-lec-tri-city
Rewards Points: 150
Send a message via ICQ to brons2 Send a message via AIM to brons2 Send a message via MSN to brons2 Send a message via Yahoo to brons2
How much heat do these lights create?
Would they be good to use in a can light that comes in contact with insulation?
brons2 is offline   Reply With Quote
Old 11-10-2010, 08:10 PM   #1340
" Euro " electrician
frenchelectrican's Avatar
Not very much heat AFAIK as long that product is listed to use in the recessed luminaires.
Merci.
Marc
Old 11-12-2010, 12:09 AM   #1341
Rewards Points: 186
Congratulations
DD, was on one of my sojourns around the province, and on the day I thought you would be moved in, pulled over on the almost deserted summit at 6000 feet, and under a clear sky and a "gazillion' stars, next to the snow clad Rockies, I toasted you and your completion, and I swear the stars twinkled a bit brighter!!
Good on you! Why a mud room, are you into "clay" also? Have you generated ideas for your shop yet?
Cheers
Scoggy:thu mbsup:
scoggy is offline   Reply With Quote
Old 11-12-2010, 12:41 AM   #1342
Dorf dude...
No heat to speak of. You can touch them and they are just slightly warm. You can't do that with halogen or compact floresent.
Old 11-12-2010, 02:56 AM   #1343
Dorf dude...
Yesterday didn't go according to plan. On Wed night I decided to find the ladder with my toe. That's why I bought a battery operated LED night light with motion sensor. I got the driveway light up and that was a disaster too. I have some holes to fill in. It also has a motion sensor. I had some fine tuning to do becase of the trucks driving by setting it off. Here are a couple of pics. dorf dude
German House Rebuild-21.jpg   German House Rebuild-22.jpg   German House Rebuild-23.jpg   German House Rebuild-19.jpg   German House Rebuild-20.jpg
Old 11-12-2010, 04:47 AM   #1344
Ouch and I've been there a few times myself. Last time I ended up on the floor.
With the interior of my home undergoing what seems like constant demolition over the past two years I just can't manage to get everything cleaned up and out of the way every night. The result are accidents waiting to happen.
My solution was the same as yours. I bought 2 battery operated motion lights. No more walking into or onto tools and material I didn't get moved the night before. I also picked up a couple LED plug-in night lights that come on at dusk. Now even the areas that are not under construction get illuminated.
Shamus
Shamus is offline   Reply With Quote
Old 11-12-2010, 10:55 AM   #1345
cocobolo's Avatar
Rewards Points: 5,832
Yesterday didn't go according to plan. On Wed night I decided to find the ladder with my toe. That's why I bought a battery operated LED night light with motion sensor. I got the driveway light up and that was a disaster too. I have some holes to fill in. It also has a motion sensor. I had some fine tuning to do because of the trucks driving by setting it off. Here are a couple of pics. dorf dude
Shamus has the "Ouch!" part right!
Shame about the holes outside, but that shouldn't be too hard to fix.
Trouble is - it's just one more thing to do.
Hope the toe heals quickly.
Just an old guy messin' with bits of wood...and old cars!
...the friendliest thread on the site! Come on by.
cocobolo is offline   Reply With Quote
Old 11-12-2010, 04:12 PM   #1346
Rewards Points: 276
That toe looks broken to me but there really isn't much they do about a broken toe anyway unless it's really bad. Generally keep protective footwear on and prevent re injury.
Jim F is offline   Reply With Quote
Old 11-15-2010, 02:02 AM   #1347
Dorf dude...
It was a very busy weekend. My toe appears to not be broken, getting better. On Sat I cut the opening for the roof window, aufsteigfenster. The instructions got very confusing for the finishing trim ect... I covered the hole and Campbell said he'd be over to finish it on Sun. He has put lots of them in. We have 2 main brands of windows here, Velux and Roto. I will never buy another Velux. The Roto's come way more assembled and much easier to install. Just a word of advice if you were buying one and had a choice. I also got my satelite mount in, dish installed and I now have TV. The pic's don't show the dish, that will be in another edition. The weather here has been so nice, 17C, we were working in t-shirts, unheard of for the middle of Nov in Germany. Here are a few pics of the weekends progress. dorf dude...
German House Rebuild-24.jpg   German House Rebuild-25.jpg   German House Rebuild-26.jpg   German House Rebuild-27.jpg   German House Rebuild-28.jpg
Old 11-15-2010, 02:09 AM   #1348
Dorf dude...
Here are a couple pics of the satelite mount going in. Not enough room in my last post.
German House Rebuild-29.jpg   German House Rebuild-31.jpg   German House Rebuild-30.jpg
Old 11-15-2010, 08:27 AM   #1349
jlhaslip's Avatar
Rewards Points: 1,564
looking good.
Nice to have that roof access...
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 11-15-2010, 10:02 AM   #1350
cocobolo's Avatar
It was a very busy weekend. My toe appears to not be broken, getting better. On Sat I cut the opening for the roof window, aufsteigfenster. The instructions got very confusing for the finishing trim ect... I covered the hole and Campbell said he'd be over to finish it on Sun. He has put lots of them in. We have 2 main brands of windows here, Velux and Roto. I will never buy another Velux. The Roto's come way more assembled and much easier to install. Just a word of advice if you were buying one and had a choice. I also got my satellite mount in, dish installed and I now have TV. The pic's don't show the dish, that will be in another edition. The weather here has been so nice, 17C, we were working in t-shirts, unheard of for the middle of Nov in Germany. Here are a few pics of the weekends progress. dorf dude...
I hear you on the Velux. Excellent product, but IMO overpriced and - as you so rightly say - hard to install.
Last time I did skylights, I had 1 opening Velux and 3 brand X's to do. The Velux took longer to install than the other three combined.
17C????? Last year we were discussing temps and it was warmer here than over there. We have snow in the forecast for the latter part of this week! It's 7C here as we speak.
I like that flashing on your satellite mast...is that some sort of rubber or vinyl to match the roof tiles? Or is it a tile made especially for the purpose and then sealed? Looks excellent.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 09:04 AM
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
German House shumakerscott Project Showcase 10 11-28-2010 12:09 PM
Complete AC installation in Old Capitol Hill Row House jacko10 HVAC 0 09-18-2007 05:42 PM
