German House Rebuild - Project Showcase - Page 79 - DIY Chatroom Home Improvement Forum
Like Tree11Likes
Old 10-02-2010, 02:07 PM   #1171
cocobolo's Avatar
Rewards Points: 5,952
Whoever cut that flooring around the tile where your stove is sitting sure did one crackerjack of a job. That is extremely well done.
cocobolo is offline   Reply With Quote
Old 10-02-2010, 03:28 PM   #1172
Dorf dude...
shumakerscott's Avatar
Rewards Points: 1,190
We don't do half ass work if we can avoid it. Always try for the best! I have a problem with the shower but will work it out in the end. So I hope. Getting there and thanks for following. dorf dude...
Today is only yesterdays tomorrow, Now get to work!
shumakerscott is offline   Reply With Quote
Old 10-02-2010, 03:29 PM   #1173
Dorf dude...
Campbell did that of course!
Old 10-03-2010, 01:23 AM   #1174
Dorf dude...
Yesterday while we were working we got "Inspected" by the nice neighbor. Campbell told him we were short 1 beam for the end of the short wall I want to put in. He spent the whole day going around the village looking and found one. I just have to go and get it and bring American ice cream. How's that for a trade? Today I plan on doing more grouting and take a shot at my shower again. More pic's later, dorf dude...
Old 10-03-2010, 08:44 AM   #1175
Rewards Points: 147
Do they have Italian eis parlors near you?
I'm not surprised my wife's village is like that too.
Hurriken is offline   Reply With Quote
Old 10-03-2010, 10:22 AM   #1176
Dorf dude...
Today I mounted the ceiling fan to circulate the warm air around. Campbell came by and we went to the old sandstone quarry looking for rocks. My house is built from stones from here. It is getting overgrown but they took alot of rock from this area. The mushrooms are loving the current weather. Here are some pic's. dorf dude...
German House Rebuild-858.jpg   German House Rebuild-860.jpg   German House Rebuild-859.jpg   German House Rebuild-862.jpg   German House Rebuild-861.jpg
Old 10-03-2010, 11:06 AM   #1177
jlhaslip's Avatar
Rewards Points: 2,098
Why is the ridge still being supported with the jacking post?
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 10-03-2010, 11:31 AM   #1178
Dorf dude...
There will be a wood support beam next to the chiminey in the future. The weight of the roof tiles calls in to question if the beam can support all that weight. The metal beam is just temp until I get the permanent beam in. dorf dude...
Old 10-03-2010, 12:27 PM   #1179
cocobolo's Avatar
Shu...if your rafters land on the outer walls and there is something tying the opposite walls together, you shouldn't need a support for the ridge beam. The weight would be transferred to the outer walls and thence to the ground.
If there are short pony walls where the rafters connect to your outer walls, then you would definitely need some extra mechanical help.
Could you post a pic showing from the ridge beam down to the top floor?
The fact is that usually there is practically zero download on any ridge beam. All the load gets dumped lower down. You only need something to prevent the walls from wanting to push apart. In many cases, collar ties do a good job.
Old 10-04-2010, 10:10 AM   #1180
Dorf dude...
If you go back to around page 6 you will see the "Ring Anchor" There are 5 pieces of re-bar drilled into the neighbors house. He wasn't home when I did that. We poured a pad on top of the Gable wall and it all got connected with concrete. I understand the physics but my roof weighs tons, literally. I actually want a beam next to the chiminey. I like beams. Thanks for the input. I'm off sick this week which actually works out ok. I can pack up things in my apartment and get my kitchen broken down.
The copy/paste works great. I open up 2 DIY web pages and just import them from my previous posts. Great tip.
Old 10-04-2010, 10:18 AM   #1181
Dorf dude...
Originally Posted by Gunship View Post
Shu....WOW man you have been busy, I haven't checked on here in a while so it took me a while to see all the progress you have made AMAZING!!! Anyway I leave sunny Florida tommorow afternoon for Germany! Yep I'm coming back to JMRC for a couple of weeks, I sure hope you are working the exercise cause I want to see your place in person. Maybe give you a hand if Chris gives me a day off. Anyway hope to see you in a day or two. Matt
Thanks for the call. I will get together with you while you are here and give you the big tour. shu
Old 10-04-2010, 11:38 AM   #1182
cocobolo's Avatar
Hi Shu: I went back through your early posts and I see that there is nothing tying the top of the two outer walls together.
So you should have something to keep the ridge up without putting outward pressure on the top of those walls.
Be a good guy - if the wood is vertical - it's a post. If it's horizontal - it's a beam!
So what you need is a very husky post. Personally, I might even be inclined to add some collar ties as well.
Old 10-04-2010, 11:55 AM   #1183
Dorf dude...
Ok, I need a wooden upright support in the middle. Aren't concrete and cement the same thing too? The rafter beams are spiked and bird mouthed on both ends. The roof dude felt that I only needed 1 middle support. The beams that are on top of my walls are bolted into the Ring Anchor. The rafters are spiked into them. This is pretty standard build for here. Yes I need a beefy "Post" in the middle. The post at the neighbors wall is well anchored to keep it from bending. dorf dude...
The Following User Says Thank You to shumakerscott For This Useful Post:
BigJim (10-04-2010)
Old 10-04-2010, 12:00 PM   #1184
cocobolo's Avatar
Is there any steel in your outside walls? If so, that may be OK, but I still agree that you need a husky post in the middle there.
Old 10-04-2010, 12:23 PM   #1185
Dorf dude...
Just the 5 re-bar's in the Ring Anchor, 3 going up the peak. This place is only stone and mortar, Lyme mortar at that. dd...
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 09:04 AM
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
German House shumakerscott Project Showcase 10 11-28-2010 12:09 PM
Complete AC installation in Old Capitol Hill Row House jacko10 HVAC 0 09-18-2007 05:42 PM
