German House Rebuild - Project Showcase - Page 134 - DIY Chatroom Home Improvement Forum
Like Tree11Likes
Old 01-09-2012, 12:05 PM   #1996
Dorf dude...
shumakerscott's Avatar
Rewards Points: 1,190
Originally Posted by cocobolo View Post
Oh yes indeed, it makes perfect sense.
I think that most - if not all - wood stoves made in Canada have provision for the induction of outside air into the combustion chamber.
As you say, burn air from an outside source and leave the heated air inside.
If for any reason it isn't possible to introduce an outside air source directly to the wood stove, then a good alternative is to use an air to air heat exchanger. These little gadgets are about 70% efficient and go a long way toward saving your heated air from escaping.
I was looking at air to air heat exchangers as I was building. I decided to wait and see how my air quality fared once I moved in. So far so good. As homes become more and more air tight you need a stove that burns from a fresh source. Here they still sell lot's of stoves that burn inside air. I really had to hunt this stove down and of course not pay through the nose for it. I'm cheap that way. dorf dude...
Today is only yesterdays tomorrow, Now get to work!
shumakerscott is offline   Reply With Quote
Old 01-09-2012, 12:16 PM   #1997
cocobolo's Avatar
Rewards Points: 5,788
Shu, many thanks for posting that pic. Now I see how it works.
For some reason I thought the outside air might have come in wrapped around the chimney in a double chimney type of affair. And actually, that might be a good idea, and it would definitely pre-heat the air, which in turn makes for better combustion.
Of course, there would then need to be some fabrication inside the top of the wood stove itself to separate the incoming air from the exhaust.
I'm still working on that...
Just an old guy messin' with bits of wood...and old cars!
...the friendliest thread on the site! Come on by.
cocobolo is online now   Reply With Quote
Old 01-09-2012, 12:20 PM   #1998
cocobolo's Avatar
I have another question for you about that stove...it looks like it is of some sort of double wall construction...yes?
Is the whole inside done out in firebrick or refractory?
And how thick would you say the metal is? Thanks.
Old 01-09-2012, 12:45 PM   #1999
Dorf dude...
The inside is fire brick lined, about 1" thick. The outside metal is about 5mm on the tops and 3mm on the sides. Your lucky I was lazy tonight and didn't light a fire. Here's a pic of the inside. It makes the exhaust do an "S" so it 2nd burns it. You can see the air holes along the front edge. This also helps keep the glass clean and create a complete combustion. Really a great stove for about $650. I stole it. dorf dude...
Old 01-09-2012, 01:02 PM   #2000
cocobolo's Avatar
Now that is very nice. Over here they use fire bricks, but several on each surface. That idea of having just a single piece brick would work way better. We need to replace ours all too often, doubtless because of their small size (still an inch thick) but the edges will wear away from the daily cleaning out etc.
Old 01-10-2012, 07:58 AM   #2001
Rewards Points: 43
I found some of the posts from earlier in the thread showing the fresh-air intake within the chimney:
Many gas water heaters in this area use the concentric round metal vent like this:
I like your stone work for a heater like you have though.
flamtap
flamtap is offline   Reply With Quote
The Following User Says Thank You to flamtap For This Useful Post:
cocobolo (01-10-2012)
Old 01-10-2012, 04:38 PM   #2002
Hardcore DIY'er
Amazing work DD, spent the last 2 days at work reading the whole thread. You have done some amazing work on that place. Love it and keep it up man.
EvilNCarnate is offline   Reply With Quote
Old 01-13-2012, 11:31 AM   #2003
Also just finished reading the entire thread. Very interesting, and you've achieved a lot.
I had a similar project albeit on a significantly smaller scale - I bought an office and converted it into a flat. (Changed the layout and replaced almost all interior walls.) Some of your earlier pictures brought back that strange "oh my god how will I ever make this livable again" feeling I had when I'd removed the old walls. I think you are better in dealing with this than I am, but anyway, I'm glad I got that phase long behind me.
Thank you so much for sharing your project with us, and I'm looking forward to your future updates.
-Stefan
stefanmuc2k is offline   Reply With Quote
The Following User Says Thank You to stefanmuc2k For This Useful Post:
shumakerscott (01-13-2012)
Old 01-13-2012, 02:01 PM   #2004
Dorf dude...
Where you at?
Old 01-14-2012, 03:45 PM   #2005
I'm in Bavaria too, in Munich.
Old 01-20-2012, 02:38 PM   #2006
Dorf dude...
I'm glad to see some new projects being posted. I'm just too lazy at this time. Being gone for 3 months took all the wind out of my sails. Very hard to get motivated at this time. I say sorry to all that have been following. I will get back at it, just not tomorrow. Well maybe a little something.... dorf dude...
Old 01-20-2012, 02:54 PM   #2007
cocobolo's Avatar
Originally Posted by shumakerscott View Post
Very hard to get motivated at this time. I say sorry to all that have been following..... dorf dude...
Not to worry Shu...it's the weather over our way that takes all the motivation away. So we understand where you're coming from.
Old 01-20-2012, 04:29 PM   #2008
Ole Wood Worker
BigJim's Avatar
Rewards Points: 302
Everyone has to take a break once in a while or burn out, you deserve a break.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 01-21-2012, 12:36 AM   #2009
DD....take a break, enjoy some time to yourself...everyone needs it every now and then. The house can wait a week or two.
jtitus07 is offline   Reply With Quote
Old 01-21-2012, 02:27 PM   #2010
Dorf dude...
When I put my little wall in I never sealed it. The post was reclaimed and had worms in it. I sprayed it with Bleach and Borax last year. I finally got around to sealing it. The post really darkened up. I also hung up my old Broad Axe. It has a date of 1919 stamped on it. I bought it at a yard sale in 1985 for $30. Here are a couple pic's. dorf dude...
German House Rebuild-img_0010-2-.jpg   German House Rebuild-img_0012-2-.jpg   German House Rebuild-img_0011-2-.jpg
The Following User Says Thank You to shumakerscott For This Useful Post:
avengerki (11-18-2013)
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 09:04 AM
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
German House shumakerscott Project Showcase 10 11-28-2010 12:09 PM
Complete AC installation in Old Capitol Hill Row House jacko10 HVAC 0 09-18-2007 05:42 PM
