German House Rebuild - Project Showcase - Page 115 - DIY Chatroom Home Improvement Forum
Like Tree6Likes
Old 07-17-2011, 11:49 AM   #1711
look how far you've come, nicely done
The older I get the better I was
Old 07-17-2011, 01:38 PM   #1712
Dorf dude...
shumakerscott's Avatar
Rewards Points: 1,186
I got going on the sub floor beams today. The laser sure makes it easy. I'm using old key cards as shims. You can fine tune it very easily with them. Plus they don't squeak or rot. Here are a few pic's, dorf dude...
German House Rebuild-img_0006.jpg   German House Rebuild-img_0007.jpg   German House Rebuild-img_0008.jpg   German House Rebuild-img_0010.jpg   German House Rebuild-img_0009.jpg
Today is only yesterdays tomorrow, Now get to work!
shumakerscott is offline   Reply With Quote
Old 07-18-2011, 11:48 AM   #1713
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
During all those pages I completely forgot you had a 2nd story on there LOL.
CoconutPete is offline   Reply With Quote
Old 07-18-2011, 02:55 PM   #1714
Dorf dude...
I got quite a bit further with the sub floor. I ran out of room now I have to clean up all my junk before I can proceed. I hate cleaning up. Working is much more fun. If you look close you can see the laser in the back corner. What a great tool! My magic number is 64cm at the top of the beam. They are getting further with the street in front too. Here are a couple pic's, dorf dude...
The Following User Says Thank You to shumakerscott For This Useful Post:
Amazingglazier (04-14-2012)
Old 07-19-2011, 08:13 AM   #1715
Custom User Title
Rewards Points: 252
Is that pex for radiant heat running under the beams?
no1hustler is offline   Reply With Quote
Old 07-19-2011, 10:08 AM   #1716
Dorf dude...
No, It's the electric cables for my down stairs recessed lights. The only heat source upstairs will be a wood burner. It will draw fresh outside air. I'm going to rely on convection heat from the radiant in the down stairs slab. No insulation will go in between the floor beams and the ceiling. I want the heat to rise and get circulated with my ceiling fan over the stair case. Thanks for following, dorf dude...
Old 07-19-2011, 03:09 PM   #1717
Dorf dude...
I almost got the first section finished tonight. 2 beams left. I have a little fine tuning to do on a couple beams but it's looking great. That 40 buck laser level is paying for it' self that's for sure. Next section is the staircase landing. Here are a couple pics. dorf dude...
Old 07-19-2011, 05:21 PM   #1718
concretemasonry's Avatar
Rewards Points: 2,570
Dorf dude -
Thanks for good photos from the new camera - the photos are great and even distant areas show up well. I have always used Canons and bought my first one about 40 years ago just a few hundred miles south of you.
Also thanks for opening up a new chapter with the second floor.
The other Schu - Dick
concretemasonry is offline   Reply With Quote
Old 07-20-2011, 12:20 AM   #1719
Dorf dude...
Lighting can be very important. Placing a lamp in the wrong place can really suck. I had this light on the edge of the cross beam. It looked good and in the proper place. That is until I turned it on and tried to watch TV. It would glare at you. I moved it 1 ft back and now the wall blocks the light and it works as it should. The hole left in the beam is unnoticeable. You really have to look ahead with somethings. dorf dude...
Old 07-20-2011, 12:41 AM   #1720
cocobolo's Avatar
Rewards Points: 5,480
That should work well Shu...we have a similar setup in the new house. Wood stove(s) downstairs and a ceiling fan at the top of the high master bedroom ceiling, and it works like a charm.
And we only need to run the fan on the lowest speed...it draws about as much power as a 13 watt CFL.
Just an old guy messin' with bits of wood...and old cars!
...the friendliest thread on the site! Come on by.
cocobolo is offline   Reply With Quote
Old 07-20-2011, 12:43 AM   #1721
cocobolo's Avatar
Every time I see pics of that lovely old stone and brick with the ancient beams it makes me drool.
Absolutely beautiful, and something you could not duplicate today.
Old 07-20-2011, 09:45 AM   #1722
What are the plans for the appearance and materials in the new found space that did not exist 400 years ago in the original haus?
What will the space be used for?
In this new space you have the opportunity to work on a smooth, even and plumb surface for the walls, since they were built by a good mason using square materials. Are you going to incorporate some of the same stone?
How about the ceiling? Smooth and clean or wood or a texture accented with wood beams added?
This is a new chapter in the book. That may be written as it unfolds.
Old 07-20-2011, 01:47 PM   #1723
Dorf dude...
Dick, It will be written as it unfolds. This floor I'm on now will be the Pool Room. The wood stove will be here too. The ceiling is what is there now, the open beams, that's finished. I need to put some lighting in. I might have to get creative on that one. The wires will probably have to come in from outside. I'm leaning towards sheet rock with sub construction on the walls. A coat of stucco to top it off. Not perfectly smooth though. I will add some highs and lows. This is subject to change. I've got a few ideas kicking around. Need to drink beer with my buddy and talk about it. Thanks for following, dorf dude...
Old 07-21-2011, 09:56 AM   #1724
i used to install billiard tables and a good thing to try and remember is the heavier(thick slate, heavy timber in the frame) the better the play of the table
Old 07-21-2011, 10:37 AM   #1725
Dorf dude...
I already have the table. It is made by Connelly, 7ft. Here's a pic from when it was set up in my apartment. This should be the last time moving it. It is very heavy, the top is 3 pieces even they are quite a handful. dorf dude...
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 10:04 AM
replumbing an old house simonfrog Plumbing 7 01-30-2012 05:45 AM
German House shumakerscott Project Showcase 10 11-28-2010 01:09 PM
Complete AC installation in Old Capitol Hill Row House jacko10 HVAC 0 09-18-2007 06:42 PM
