Garage Cabinets Phase 1 - Project Showcase - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-27-2009, 10:29 PM   #16
jackie treehorn's Avatar
Rewards Points: 174
Originally Posted by vladbayer View Post
This looks amazing! What kind of finish did you use for non-laminated surfaces? How does it compare to the melamine? I am in the process of building cabinets for my garage, but canít find melamine sheets (except for 16Ē wide white sheets at Lowes/HD). Just wondering how I could achieve similar look using plywood.
It's 3/4" melamine, I actually ordered it through the special order desk at the depot. I can't remember what brand it was, call around to specialty lumber shops, they maybe able to get it in smaller quantities, I had to order a minimum amount when I built them.
Originally Posted by GBR in WA View Post
It was three months ago....... If he does answer, I want to know if he changed the furnace filter yet? They require 30" clearance in front (this case where the pantry and sink are) and 12" to the side. Hope the outlets are on GFCI's or special circuit GFCI at the panel, at least the two that are 3' to the sink. Nice job on the construction end though!
Be safe, Gary
Furnace filter is upstairs inside the house, unless there's multiples, but I pulled off both panels on that side and saw nothing of the sort. The tall cabinet has feet and is screwed into the other cabinet and the wall so I can pull it out if I want/need. As for the GFCI's there's two feeding the whole garage, I think one per side??
jackie treehorn is offline   Reply With Quote
Old 12-29-2009, 01:15 PM   #17
Registered User
Rewards Points: 5,216
Cool, that's why pictures sometimes don't tell the whole story.... Glad you are safe!
Be safe, Gary
Seeking garage cabinets shelving plans/help Robert131 Building & Construction 3 08-18-2011 08:23 PM
Want to add a single phase Subpanel to three Phase Main meglomachinist Electrical 19 09-10-2009 04:46 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 03:57 PM
Newbie DIY garage cabinets boba7523 Building & Construction 5 08-18-2008 09:03 AM
Garage Cabinets tband Building & Construction 2 09-15-2007 02:21 PM
