Garage Cabinets Phase 1 - Project Showcase - DIY Chatroom Home Improvement Forum
Old 09-14-2009, 04:34 PM   #1
jackie treehorn's Avatar
Rewards Points: 174
Garage Cabinets phase 1
I "started" these during the winter, and after my deck I finally got back to finishing them up which really consisted of organizing. I didn't use any fancy material, just 3/4 melamine, I'm not a cabinet maker by any means either. Here's the mess I started with, you can see why I needed cabinets desperately.
sheets cut down into numbered pieces
Fast forward to two cabinets being together and fitted for counter top
Counter top being laminated
Drawer pieces
First drawer, made it extra deep for air nailers etc
Outlet on side of cabinet since I covered one of them up
jackie treehorn is offline   Reply With Quote
Old 09-14-2009, 04:35 PM   #2
Rewards Points: 174
I made the upright cabinet 8 feet tall because ripping 10 inches off a full sheet of wood is no easy task, after I got it in there I'm gonna need a step stool to put anything in it, a bit too tall even for me.
Put a plug on the exterior for easy access.
Old 09-14-2009, 04:35 PM   #3
Rewards Points: 174
The upper cabinet before pic:
The Door handle locator jig
Old 09-14-2009, 04:36 PM   #4
Rewards Points: 174
The three year "temporary" cabinet I had in there, the drawers are empty cause I was putting all the stuff into a container for now
That same container and all it's contents after falling onto the floor
the only build pic of the bench
the James bond like stealth lawnmower hideaway
The adjustable foot in the pic is only temporary, and I replaced it with a piece of hdpe plastic.
I was all excited to build a big bench and cabinet there, but when I got out the tape measure I realized the lawn mower would block my under stair storage. So I decided why not make a bench that covers up the lawn mower, throw in a couple drawers and call it good.
A pic of the upper storage with all the doors on
Old 09-14-2009, 04:38 PM   #5
Rewards Points: 174
Frame for peg board
Used the silver pegboard, figured it matched better.
Wired in power for the compressor inside the cabinet:
Put one line on the end of the cabinet
and put the other going to a reel on the other side of the garage:
I've realized the error in my ways and now will change out the pipe, I've heard from people the pipe likes to explode after time
Old 09-14-2009, 04:43 PM   #6
Rewards Points: 174
Storage bins galore, wife even labled them
My top drawer, I decided to split it in two, sort of. The top is for my smaller flat hand tools etc, I can either slide it towards the back, or pull the whole thing out and take it with me etc.
Prepare to bend neck 90 degrees. I have no idea why I didn't rotate this pic, but this is what the normal drawer height is, The very bottom drawer holds all my air nailers and circular saw
That's all I have for now, hopefully I'll get around to phase two of the cabinets this winter, but the recession may slow me down
Old 09-14-2009, 05:00 PM   #7
You have way too much spare time on your hands
I think you need one more ATV
So do you build cabinets or something as a professsion?
I noticed all the jigs etc on the wall
I'll be using old cabinets for my garage, have 3 sets already - big garage
Old 09-14-2009, 05:12 PM   #8
What font best represents jealousy? I'd like to be using that font right now.
Nice looking project you have there. The mower storage is so very clever that I may some day borrow the idea!
KAdams4458 is offline   Reply With Quote
Old 09-14-2009, 05:44 PM   #9
Newbie Bill
Rewards Points: 518
Wow, that is an awesome "Man Cave".
And it was only a 1 beer job. Unless you store your empties in one of those swanky cabinets.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 09-14-2009, 08:40 PM   #10
Rewards Points: 174
I only have one atv, the other is a buddy of mines, I don't do cabinets for a living thats for sure, I own my own company making vehicle specific subwoofer enclosures out of fiberglass for cars, hence all the jigs etc. If you wanna see some of my auto work, go here. As for spare time, it went from building deck to doing garage cabinets to adding the bbq area and now where I am currently. (which is no project on hand and driving myself bonkers)
Borrow away, that's what the forums are for is to share stuff and ideas etc.
The rest is in the fridge from my other thread
Old 09-14-2009, 09:24 PM   #11
Knucklez's Avatar
Rewards Points: 930
ya that's really great. would love to see some custom fiberglass speakers with ground effects as a nice sound system addition to your man cave.
Knucklez
"if you can't be handsome, at least you can be handy" -Redgreen
Knucklez is offline   Reply With Quote
Old 09-16-2009, 04:36 AM   #12
Tigwldr's Avatar
Nice work, what did you use on the cut edges of the black melamine? Just regular black paint?
Tigwldr is offline   Reply With Quote
Old 09-16-2009, 11:30 AM   #13
Rewards Points: 174
Just some edging from these guys. It's a peel and stick, I originally doubted it's sticking ability but that was four years ago on a different set of cabinets and it's still on, so I had no problems deciding to use it on these
http://www.fastcap.com/fastedge.aspx
Old 12-27-2009, 05:31 PM   #14
This looks amazing! What kind of finish did you use for non-laminated surfaces? How does it compare to the melamine? I am in the process of building cabinets for my garage, but can’t find melamine sheets (except for 16” wide white sheets at Lowes/HD). Just wondering how I could achieve similar look using plywood.
vladbayer is offline   Reply With Quote
Old 12-27-2009, 07:51 PM   #15
Registered User
Rewards Points: 4,920
It was three months ago....... If he does answer, I want to know if he changed the furnace filter yet? They require 30" clearance in front (this case where the pantry and sink are) and 12" to the side. Hope the outlets are on GFCI's or special circuit GFCI at the panel, at least the two that are 3' to the sink. Nice job on the construction end though!
Be safe, Gary
Seeking garage cabinets shelving plans/help Robert131 Building & Construction 3 08-18-2011 08:23 PM
Want to add a single phase Subpanel to three Phase Main meglomachinist Electrical 19 09-10-2009 04:46 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 03:57 PM
Newbie DIY garage cabinets boba7523 Building & Construction 5 08-18-2008 09:03 AM
Garage Cabinets tband Building & Construction 2 09-15-2007 02:21 PM
