Front Entryway - Project Showcase - DIY Chatroom Home Improvement Forum
Old 04-29-2013, 06:19 PM   #1
Front entryway
So we bought a house with an awesome view that needed a lot of work. This was the entryway... pink tile (note how the patters of the "random" tile match up too often):
I bought a 40 inch mosaic rock off eBay for about $250 (shipped from Lebanon). I had to raise the mosaic to fit the slate rock.
The slate was $2 a square foot and I selected the horizontal pieces for the center section and the flat black pieces for the next layer. There isn't a square piece in it.
I found some 18 inch pieces at Home Depot and used them for the corners to break it up. This picture was take just after the gloss sealer was put on.
The 8' door (new) I found on Craigslist for $200. It was short and I had to add about an inch and a half to the bottom of it and switch hinge location.
While it seemed like this took forever, after a few months the gloss has dumbed down and it looks more flat now. The segue to the new wood floor adds drama. If I were to do it again, I would use a triangular trowel, as the square one left way too much adhesive (which oozed up) to pick out with a razor blade (took me a week). When you use black grout, all of the white adhesive needs to be removed or it will show through.
GregsBarn is offline   Reply With Quote
Old 04-29-2013, 07:52 PM   #2
Rewards Points: 327
that looks awesome...
Two Knots is offline   Reply With Quote
Old 04-29-2013, 07:57 PM   #3
Rewards Points: 89
Nice job.
REXAMUS is offline   Reply With Quote
Old 04-29-2013, 09:03 PM   #4
Thanks. My Bosch jigsaw with a diamond blade cut the round edges. The edges are scalloped, which breaks up the uniformity of the pattern. Trying to nail all the 90 degree angles is too hard, so if you add an abstract edge to it, it doesn't have to be perfect. Note the sections that make up the ring around the mosaic are not all the same size... they don't have to be. There's both a circular pattern and a square one, so when entering the house, your eyes go to the floor first.
By the way, the mosaic is made up of over 15,000 pieces of rock. The time it takes to make one of these so intricate must be staggering.
Old 04-29-2013, 09:27 PM   #5
funfool's Avatar
Rewards Points: 534
I love it, I can just imagine how many hours it took to complete .... but worth it.
funfool is offline   Reply With Quote
What to do about a Damp Crawl Space under front porch? vpr80 Building & Construction 9 04-11-2012 08:32 PM
Help with paint colour for the garage and front door syndicate1 Interior Decorating 7 07-25-2010 06:08 PM
Drying time and painting a front door gramps416 Painting 1 05-17-2010 11:01 AM
Front Cement Steps / Porch Leaking bschwarz Building & Construction 2 04-14-2009 10:46 PM
Adding new Front Porch, need opinions MeraleeCrowl Remodeling 1 11-05-2008 12:47 PM
