Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > Project Showcase
Old 08-25-2008, 01:16 PM   #1
Security Systems Expert
Foyer wall finished
I put a small ( 8' x 4' ) wall in beside our front door, to make a foyer of sorts. This wall has a portal in it that has an arched top. I used four layers of 3/4" particleboard between the studs to form the inside of the arch, as you can see in this photo album along with a shot of the final result.
http://www.diychatroom.com/members/thevampire-28076/albums/foyer-wall/
This gave me the base to lay my 3/8" draywall against. I cut a strip of drywall the correct length and for the part that made the arch, I scribed the back of the drywall every 1.5" and snapped it on the scribe mark. This allowed the drywall to form around the arch. ( I couldn't get the drywall to bend by wetting it. It would always break. ) This piece was fitted in and wedged by the piece going across the bottom of the portal so that it was "forced" up into the arch and held in place. After all the cementing, sanding and painting ( and cleaning ) everything is finally finished! Thanks to the people here that answered my questions!
TheVampire is offline   Reply With Quote
Old 09-01-2008, 08:31 PM   #2
Drywall and Painting Pro
Sir MixAlot's Avatar
Foyer wall finished
Nice job!
Checkout some of
Sir MixAlot is offline   Reply With Quote
Old 09-02-2008, 10:40 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Foyer wall finished
Looks great!
- Build Well -
Foyer Wall Tapestry Boatnuts Interior Decorating 5 02-08-2011 10:54 AM
Window frame not flush with finished wall Stubbie Carpentry 9 06-24-2008 03:38 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
