First House - Guttin Her And Doin It Right! - Project Showcase - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-05-2013, 08:46 PM   #16
The north 39'x26' has a 4' crawspace under neath of the flooring.
Water + gas is coming in from the 2'x12' mark.
4"x8" Support Beam runs at the 14' vertical mark.
Im planning to build the 1st lvl concrete slab up with 2"x4" and the 2nd lvl concrete slab build it up with 2"x6" to the same lvl of the 1st lvl slab. That would give me enough room to run 3/4 or 1/2" lines to the garage for the wash sink out there. Which will give me a 7'6" ceiling. Only reason I am raising the floor is I would prefer to have a wood floor base to lay my flooring over + coldness of the concrete in the winter + room to run my hot/cold supply water lines to the garage.
I would love to put the kitchen/living room in the south side of the house. The only issue is the draining of the sink+dishwasher as well as a low ceiling in the living room/kitchen wouldn't seem right.
DukeLewis87 is offline   Reply With Quote
Old 04-05-2013, 08:47 PM   #17
Update: Currently demoing outside walkway from side of house. Removing all fascia and soffit and replacing before the installation of the new gutters as well as down spouts
Old 04-05-2013, 09:02 PM   #18
I altered the 2nd bathroom , Master bathroom and Furnace/Water Heater Room.
Not yet added. Sliding Glass door at the 26' vertical 20' to 24' Horizontal for access to the ground level deck with working built-in firepit+sitting area+grill.
6x8 Mud Room
15x12 Kitchen
22x14 Living Room
6x10 Public Bathroom
4x6 Furnace/Water Heater Room
Father's Room:
14x14 Master Bedroom
6x12 Master Bathroom(Might change the design of it)
Daughter's Room:
12x12 2nd Bedroom
My Wife and I's Room
18x12 3rd Bedroom
*Very large compared to other rooms, however my wife and I would have extra furniture pieces to be adequate for are daily tasks*
Old 04-05-2013, 09:07 PM   #19
Concrete slab portion. *2nd + 3rd Bedroom*
As for the heat/ac duct issue, am I able to run my supply lines threw the attic and down threw a top plate to the bottom and have a wall bottom register?
Old 06-28-2013, 05:28 PM   #20
Rewards Points: 83
Hats off to you.. Nice to see people working wood and lumber. Looks great.
Keep us posted.
Ralph Coolong is offline   Reply With Quote
Old 07-03-2013, 03:59 PM   #21
Well hello everyone. I think im alive but barely after alot of stress with this project.
We came up with a floor plan that is set in stone, but reversed completely. Livingroom/Kitchen will be down by the garage now. I will upload the new sketch and more pics soon.
But I just took a pic today of the 2 concrete ugly ass rooms that were next to the garage or ust to be right.... These will be the livingroom/kitchen.
Old 07-03-2013, 04:03 PM   #22
What has been done to the above picture.
All 5 exterior walls replaced. The 2 closest to the garage were moved back 4" to give the ceiling a bit more support. But in order to do that we had to replace over 50 block. The block that the orig walls were sitting on had very little to none mortar.
The wall that was between the two rooms was taken out. More of an open concept kitchen/living room concept.
Ceiling joists replaced in the smaller concrete room of the 2.
Old 07-03-2013, 04:15 PM   #23
Rest of the house which I do not have pictures of atm. Sort of a quick list of what i've done to give you all an idea.
Exterior:
-Siding Removed
-Old windows removed
-Old gutters/soffit/fascia/fascia board Removed
-New soffit/fascia/fascia board/gutters
-New 3/4 OSB Installed over exterior outside walls 167' around house(Excluding garage)
-HouseWrapped
-New PVC Trim + Fiber Cement 7.25" siding
-New Construction 30"x54" 6 windows
-New Octagon windows installed bathroom windows.
-5 Exterior walls completely rebuilt
-75% existing window holes/walls had to be rebuilt in 24x36 area
This concrete room floor structure is my first solid inside project.
I haven't got to far in the 3 months I don't think but seeing as im doing all the work myself + working a day drywall hanging/finishing job.
Atleast 400 hours i've put into it.
