Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > Project Showcase
Old 11-03-2010, 01:23 PM   #76
RST
DIY Homeowner
First Home, Many Projects
What he said!!! ^^^^ Most utility companies will send out someone at no cost to inspect potential leaks.
You should also call an HVAC company to "service" (basically clean and inspect) the furnace and replace the filter. Should be $70-$100 if nothing's broken. This will give you peace of mind and your furnace will run more efficiently, saving you utility dollars. It's a good idea to have the service done every year in the northern U.S. - maybe every other year in your area.
RST
RST is offline   Reply With Quote
Old 11-03-2010, 03:41 PM   #77
Maybe it was just a weird smell. I was just searching online and everyone was calling it gas smell. It did go away, so I'm just making sure it was because of first time turning it on. I'm on natural gas, I believe since I don't have a propane tank for sure. Does anyone know any good sites for nice small house projects? House still looks plain to us inside and outside.
Dinggus is offline   Reply With Quote
Old 11-03-2010, 04:40 PM   #78
Custom User Title
thisoldhouse.com is one of my favorites. I also have a subscription for their magazine.
no1hustler is offline   Reply With Quote
Old 11-03-2010, 05:38 PM   #79
Thank you, I'll look into it.
Old 11-07-2010, 07:12 PM   #80
Awesome website no1hustler, thank you!
Has anyone ever installed Ethernet ports throughout the house? I'm just wondering because I would like to hook up my TV to the internet, but my internet is in my man cave.
Old 11-09-2010, 03:27 PM   #81
Punk
TuscolaMatt's Avatar
You can use powerline type adapters (I use THIS one)
They're not cheap - but they have plenty of throughput and will save trying to physically wire it all up through your attic...
Visit the
TuscolaMatt is offline   Reply With Quote
Old 11-09-2010, 03:40 PM   #82
Thanks, I'll look into it. I was thinking of just wiring it under the house, would that work?
Old 11-09-2010, 04:26 PM   #83
Punk
if you can find a way to route ethernet cable - then I'd say that would be the best way...
Visit the
Old 11-09-2010, 04:33 PM   #84
Do you know of a howto?
Old 11-09-2010, 06:26 PM   #85
Punk
the professional way would be to install a couple ethernet receptacles (Lowes might have these) - one in the living room and one in the man cave. wiring these using a standard ethernet cable is fairly straight forward... You would then just run a jumper from your router to the new wall receptacle and then in the living room plug the tv into it's own receptacle...
Visit the
Old 11-11-2010, 12:19 PM   #86
Like this?
Old 11-11-2010, 07:04 PM   #87
Punk
Yup - that would work just jiffy (assuming your TV is internet capable of course). Plugging into the remote box (on the tv end) would be the same as plugging it into the router...
Visit the
Old 11-11-2010, 07:21 PM   #88
I'll be buying an AppleTV first generation put Boxee on it. That way I can cancel TimeWarner Cable since they are expensive and I can get my TV shows for free!
Old 11-20-2010, 10:05 PM   #89
I'll be putting the smart house networking aside right now. Got a huge problem, we have 2 puppies that are almost house trained, but it seems their piss has ate away the glue under our plastic tiles and are lifting up, so now I have a new project and would like to lay down wooden floors, how would I do so?
Old 11-21-2010, 06:04 AM   #90
Punk
I ordered solid bamboo florring from Ifloors.com - this has been the greatest flooring I've ever had. I've got pictures of my livingroom remodel here:
http://www.polarsoft.net/remodel/
It hasn't been updated in quite a while...I'll have to add more pics soon. Anyway, you can see the flooring about 3/4 of the way down. After shipping, I paid around $2 a sqf...
Visit the
Need advice on remodeling/renovating a prefab (mobile) home countrylifemom Remodeling 47 03-20-2013 10:48 AM
Condensation on fiberglass window frame creamaster General Discussion 11 01-05-2012 08:42 PM
History of Lomonaco's Iron Concepts & Home Decor John Lomonaco Introductions 0 11-08-2009 11:39 AM
How to optimize thermostat settings (2 heating systems same home) rossl56 HVAC 1 11-26-2008 04:39 AM
Insulateing a Home Rifeman Building & Construction 9 08-31-2007 05:28 PM
