First Home, Many Projects - Project Showcase - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-28-2010, 07:30 PM   #16
1. How?
2. Those are the energy saving ones?
3. Already do.
4. How do I know? The house was built in 1977.
5. I'm not sure if I have one, all I know is the thermostat is an old one that has a little adjuster leveler on the side, ha!
Dinggus is offline   Reply With Quote
Old 08-30-2010, 12:26 PM   #17
Custom User Title
Rewards Points: 252
Originally Posted by Dinggus View Post
1. How?
3. Already do.
1. Real easy: http://www.ehow.com/how_4435452_adju...er-heater.html
2.Yes, the funny looking ones.
3. You can also plug things into power strips and just turn them completely off when you aren't using them. That will stop the "phantom" power loss.
no1hustler is offline   Reply With Quote
Old 08-30-2010, 05:24 PM   #18
Thanks, I was thinking about going that route, only thing I'd need to be actually plugged in the living room is the DVR. My Man Cave would just need modem, router, and computer to be plugged in. Everything else in my house could just use a power strip.
The light bulbs I bought are like twist looking ones. I did have a question about 4 light bulb fan, if I only have 1 screwed in, would the 3 empty ones still draw power?
Old 08-31-2010, 11:45 AM   #19
Custom User Title
Rewards Points: 252
It will not.
Old 09-01-2010, 06:55 AM   #20
I was just making sure. Also would an outlet controlled by a light switch draw power if it's not switched on? And if I upgrade my thermostat to a new one would that help as well for my electricity bill? This is what I have.
Old 09-01-2010, 08:35 AM   #21
Custom User Title
Rewards Points: 252
The outlet will not draw power if the switch is off. The circuit is not complete until it is turned on.
You can save power if you install a programmable thermostat. That way you can set it so it turns the the heat/AC when you aren't actually home. They are pretty cheap and easy to install.
Old 09-01-2010, 08:38 AM   #22
Thanks for the answer, is there a way I can hook up another outlet to a switch? I like that idea of being about to cut power on or off.
So a thermostat advantage is only to time?
Old 09-01-2010, 10:50 AM   #23
Custom User Title
Rewards Points: 252
You can probably hook up another outlet to a switch or add another switch but I can't comment on it much more than that. I have very limited knowledge on running wires.
I believe that is one of the biggest advantages with a new thermostat. Perhaps newer models can check room temperatures better. I know mine isn't very accurate and I'll be changing mine out before it gets too cold.
Old 09-01-2010, 03:45 PM   #24
Okay thanks! Well supposedly our house is 97 degree's very time.
Old 09-03-2010, 08:02 PM   #25
I also want to look at getting products that are Energy Star Qualified, correct?
http://www.lowes.com/pd_225410-37422...oduct_rating|0
Or would this be fine, even thought it's not Energy Star Qualified.
http://www.lowes.com/pd_39500-74493-RTH6300B1005_4294821951_4294937087?productId=31344 43&Ns=p_product_rating|0&pl=1&currentURL=/pl_Programmable%2BThermostats_4294821951_429493708 7_?Ns=p_product_rating|0
Old 09-04-2010, 03:17 PM   #26
Well, I'm still replying in hopes people help. I ended up buying this:
http://www.homedepot.com/webapp/wcs/...ctId=202024248
The home depot clerk told me the wires will be labeled, and just remember what their label was and connect it to the new thermostat. Here's the issue, there are no labels on mine. The instructions say ignore wire colors, there should be a identification next to the terminal screw which I do not see.
Edit: Guess there are 2 face plates to the mount, removed it and now I got it to work!'
Old 09-07-2010, 11:51 AM   #27
Custom User Title
Rewards Points: 252
Looks good. I'd say anything you get would be an improvement over your old one.
Old 09-07-2010, 12:24 PM   #28
Yeah. It's nice, I'm using the energystar setting what they recommend for summer. Once I'm done working on my truck
I plan on checking out my water heater to see how old it is.
Old 09-10-2010, 10:55 AM   #29
Rewards Points: 490
My heat bill was $131 a month, year round on the budget plan with the gas company.
I did the following and lowered it to $61 a month, year round.
1. Sealed the attic and added cellulose insulation from R-19 to about R-58.
2. Sealed the seams on all exposed heat ducts and furnace.
3. Replaced several older windows. Still have 5 to go.
4. Replaced drafty front door.
5. Gaskets on all electrical outlets in walls.
6. Sealed and insulated rim joists in basement.
7. Installed a draft blocker in the dryer vent to keep cold air from coming in. That made a huge difference. There used to be cold air flowing in from the dryer vent.
8. Still have to insulate the heat ducts that have been sealed.
There are more things, but I can't think of them right now.
I won't use CFL bulbs in my house, but I noticed a drop in my electric bill when I plugged all of of my computer stuff into a power strip and turn the power to it off every night and when I'm not using it during the day.
During the colder months, I turn the dial down a little bit in my refrigerator.
The navy blue paint on your walls looks great.
gma2rjc is online now   Reply With Quote
Old 09-10-2010, 11:10 AM   #30
$61! I'm hoping that most of the bill was due to a turn-on fee since it was my first bill.
1. How do I know if my attic is sealed and if I need insulation? The wife said when she looked up there, it was insulated, but when we first moved in, the house would get up to like 97 degrees.
2. What do you use to seal these heat ducts?
3. I've been told my windows are the energystar ones, double layered?
4. Couldn't I just buy the weatherstrips?
5. What's a gasket?
6. Don't have a basement.
7. Where did you get this draft blocker?
8. Heat ducts are the air vents?
Why won't you use the CFL bulbs? I plan on buying this:
I think I'll find it very useful, in the living room all I need on is the DVR so our shows record. In my Man Cave, all I need on is my internet and computer. The xbox, TV, printer, paper shredder can be plugged into this.
Thanks, I we like them as well. Once we fill the living room up some more, I'll take some updated photo's.
Need advice on remodeling/renovating a prefab (mobile) home countrylifemom Remodeling 53 03-29-2015 08:15 PM
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 07:42 PM
History of Lomonaco's Iron Concepts & Home Decor John Lomonaco Introductions 0 11-08-2009 10:39 AM
How to optimize thermostat settings (2 heating systems same home) rossl56 HVAC 1 11-26-2008 03:39 AM
Insulateing a Home Rifeman Building & Construction 9 08-31-2007 04:28 PM
