First Home, Many Projects - Project Showcase - Page 13 - DIY Chatroom Home Improvement Forum
Old 11-15-2011, 08:03 AM   #181
Can anyone recommend me a good underlayment for laminate flooring?
Dinggus is offline   Reply With Quote
Old 11-15-2011, 12:27 PM   #182
Dorf dude...
shumakerscott's Avatar
Rewards Points: 1,186
I used cork, worked ok. dorf dude...
Today is only yesterdays tomorrow, Now get to work!
shumakerscott is offline   Reply With Quote
Old 11-15-2011, 06:30 PM   #183
Thadius856's Avatar
Rewards Points: 504
When I think of cork, the sound of it squeaking as it comes out of a wine bottle comes to mind.
Would it be safe to say it doesn't do that as an underlayment?
Check out my on-going Project Thread!
Current Project: Whole House Data Wiring
Back Burner: Drywall Patching
Planning: Kitchen Reno
Thadius856 is offline   Reply With Quote
Old 11-16-2011, 01:43 AM   #184
HomeDepot floor specialist recommended:
http://www.homedepot.com/webapp/wcs/...64&R=100093264
Now, do subflooring's need like a vapor barrier or anything? Just incase water gets spilt on the floor or something? Can't have my subflooring getting ruined.
Old 11-18-2011, 01:19 AM   #185
Thadius856's Avatar
Rewards Points: 504
I have no idea, but I usually got out of my way to do the exact opposite of what the Big Box employees recommend.
I've one every gotten one knowledgeable associate at HD, compared to three that were extremely helpful today at Ace.
Old 11-18-2011, 01:25 AM   #186
Dorf dude...
Here's a link for cork.
http://www.amazon.com/AcoustiCORK-Fl.../dp/B002Q7BX10
Old 11-18-2011, 05:10 AM   #187
The associates around here are pretty helpful.
Originally Posted by shumakerscott View Post
Thanks, I'll look into it. Does it get stapled down or just lay it down?
Old 01-16-2012, 12:05 PM   #188
Came home for R&R and the wife was able to get our new flooring installed for $150 to do the living room and part of the hall way, and I must say I will never buy flooring from Lumber Liquidators again. The new flooring is from HomeDepot, around the same price and it seems like it's better quality, there's definitely no echo and it looks good.
The guy was able to replace where the dogs decided to destroy with their urine.
Now, I was able to convince myself we might as well buy brand new cabinets, because it looks like ours is just custom built or just extremely old. Our main cabinet is all in one, and right now Home Depot is having 20% off on cabinets, plus my 10% for military, so I should only spend around $850 on new cabinets. The wife and I also decided we'd paint them instead of staining them. So my question is, whats the best way to mount base and wall cabinets? I'd love to get this done ASAP before I leave, so all the wife needs to do is order the counter top.
Old 01-16-2012, 01:20 PM   #189
Thadius856's Avatar
Rewards Points: 504
Best way? Don't know.
Mine were mounted on two furring strips that were bolted to the studs, then space between the back of the last cabinet was covered with a piece of moulding.
I'll be replacing them with customs later this year, so I'm interested to hear the best mounting method as well.
Old 01-16-2012, 02:17 PM   #190
I've seen people just screw in 2x4's under the cabinets and then remove the old ones.
Like what JohnSC did:
Old 01-18-2012, 08:50 PM   #191
Looks awesome!! Just make sure you use the energy-efficient light bulbs wherever you can. They will make a bigger difference than most people realize... also, it looks like your thermostat is set at about 80 degrees? Is that why the ac kicks on when its over 80 degrees? Lastly, I noticed that you plan to potentially add a fence in you front yard... some areas have rules about the size or placement of fences.. before you put one up you may want to check with local ordinances and permit requirements
NaviCat is offline   Reply With Quote
Old 01-18-2012, 08:55 PM   #192
Thanks for the tip. Unfortunately my kitchen still looks normal, I was using that photo above as an example on how I think you're suppose to hang cabinets.
Old 01-23-2012, 02:53 AM   #193
Trying not to have to replace my whole laundry room dry wall, and I watched to patch that hole I accidently made, so I cut a square out:
Did I do it right?
Old 01-23-2012, 12:36 PM   #194
Thadius856's Avatar
Rewards Points: 504
Bottom looks great.
Clean up the vertical cuts with a razor knife. You want a straight line, more or less.
Putting the new piece in will be a lot easier if you square up the top cut a little more.
Edit: What's screwed into the other side of the wall? I don't see any anchors... if it's at all heavy, it might end up on the floor soon.
Old 01-23-2012, 12:54 PM   #195
The other side is just a board, nothing heavy.
Need advice on remodeling/renovating a prefab (mobile) home countrylifemom Remodeling 53 03-29-2015 09:15 PM
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 08:42 PM
History of Lomonaco's Iron Concepts & Home Decor John Lomonaco Introductions 0 11-08-2009 11:39 AM
How to optimize thermostat settings (2 heating systems same home) rossl56 HVAC 1 11-26-2008 04:39 AM
Insulateing a Home Rifeman Building & Construction 9 08-31-2007 05:28 PM
