First Home, Many Projects - Project Showcase - Page 11 - DIY Chatroom Home Improvement Forum
Old 10-09-2011, 09:09 PM   #151
The wife and I decided to get laminate flooring in living room, kitchen and hallway. I just ordered this:
http://www.homedepot.com/Flooring-La...atalogId=10053
Wife thinks it looks to yellow, so I ordered a case to see if she'll like it in person, if she doesn't then she can just return it. If she does, I'll order enough to do the areas we want and have it done when I come home.
Dinggus is offline   Reply With Quote
Old 10-12-2011, 07:40 PM   #152
Well, as we were training our dogs to not use the hallway as a toilet, wife said it started smelling after all these months, and lifted up the flooring to see the damage, and here it is:
So, for a temporary use, she bought some deodorizer paint and going over the area and then covering it up with a rug until I come home.
How do I replace it?
Old 10-12-2011, 10:04 PM   #153
The wife did this today:
Old 10-12-2011, 10:36 PM   #154
Rewards Points: 956
is that stained mess from the pet peeing???!
federer is offline   Reply With Quote
Old 10-13-2011, 12:01 AM   #155
Yes, we didn't know it was that bad.
Old 10-13-2011, 06:48 PM   #156
Thadius856's Avatar
Rewards Points: 504
Part of the stained mess is going to be from the glue in the lick-n-stick tiles.
In past years, the adhesives were thick, strong and (I believe) oil-based.
Now they're water-based and thinner. As a result, animal urine can easily re-liquify and thin the adhesive. Part of the discoloration is the adhesive soaking through the wood.
At some point, they would have started to float around like lilies on a pond.
Thadius856 is offline   Reply With Quote
Old 10-13-2011, 06:49 PM   #157
I'm going to replace the flooring, shouldn't be to hard.
Old 10-13-2011, 06:50 PM   #158
Thadius856's Avatar
Rewards Points: 504
Not too difficult.
Flooring still scares the bejebus out of me, mostly because the material cost causes a little sticker shock.
Old 10-13-2011, 06:51 PM   #159
It's expensive for a board?
Old 10-13-2011, 06:56 PM   #160
Thadius856's Avatar
Rewards Points: 504
Board? Like... sheeting to repair the subflooring?
Not really. You'll need a circular saw, some skill and a whole lot of balls. You pretty much locate the joists/stringers it sits on and cut down the center of them, then cut a new piece to fit in the hole and nail it back down. Don't use your best saw blade, because chances are you're going to find a nail or two. Also be sure to set the blade depth just enough to get through the subfloor to minimize damage to the stringers/joists.
Unless you've got slab-on-grade. In which case I'm not sure what board you're referring too.
Old 10-13-2011, 07:00 PM   #161
Thadius856's Avatar
Rewards Points: 504
BTW... Air Force vs Army is Nov 5 on Versus.
I hope you get to see it on the Army's equivalent of AFN over there.
I'm sure we'll get stomped, but then again, I thought Navy was going to roll right over us too.
Old 10-13-2011, 07:28 PM   #162
Yeah just a sheet to repair the floor. Should I just remove the soiled spot, or the whole sheet?
Wife tried to pry it up yesterday, but she couldn't. I told her just get a sledge hammer and smash in between nails, lol. But she said she'll wait for me to come home.
I don't really watch football, but I've heard the Army sucks.
Old 10-13-2011, 11:22 PM   #163
Thadius856's Avatar
Rewards Points: 504
Either method for removal works. I tend to prefer sawing the damaged portion and using a long pry bar. The advantage to smashing it to bits is that it will fit in a standard curbside trash bin for disposal, but the disadvantage being that you'll have to retrieve the bits from the crawlspace or you'll be attracting rodents, termites, etc.
If it's not warped or damaged, you might be able to spray it (carefully!) with a mixture of bleach and water to neutralize the odor. I'm sure there's commercial products, probably marketed under the Kaboom! brand name, that would also do the trick. The only problem is that you'll have to wait for the wood to dry out before you can cover it back up.
Edit: Just finished the taping and first coat of mud. It wasn't nearly as hard as I'd expected from all the "OMGWTFHELP!!11!" posts on the web.
Old 10-14-2011, 12:27 AM   #164
Dorf dude...
shumakerscott's Avatar
Rewards Points: 1,190
Whoa there! Do not smash it out with a hammer. You will need to cut it out so that you have a straight edge to match up to. That was bad advice. dorf dude...
Today is only yesterdays tomorrow, Now get to work!
shumakerscott is offline   Reply With Quote
The Following 2 Users Say Thank You to shumakerscott For This Useful Post:
cocobolo (10-14-2011), no1hustler (10-14-2011)
Old 10-14-2011, 12:29 AM   #165
Thadius856's Avatar
Rewards Points: 504
He would have a straight edge where the sheet ended, mid-joist.
Need advice on remodeling/renovating a prefab (mobile) home countrylifemom Remodeling 53 03-29-2015 08:15 PM
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 07:42 PM
History of Lomonaco's Iron Concepts & Home Decor John Lomonaco Introductions 0 11-08-2009 10:39 AM
How to optimize thermostat settings (2 heating systems same home) rossl56 HVAC 1 11-26-2008 03:39 AM
Insulateing a Home Rifeman Building & Construction 9 08-31-2007 04:28 PM
