First DIY Project---Window Casing---WIP - Project Showcase - DIY Chatroom Home Improvement Forum
Old 07-23-2008, 12:02 AM   #1
First DIY project---Window Casing---WIP
Before
After
Thanks for everyone's advice. There are still some inperfections. We are still learning while we are doing it.
chinese_lover is offline   Reply With Quote
Old 07-23-2008, 06:02 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Very nice job for your first time out.
Keep up the good work and thanks for posting the pics.
- Build Well -
Old 07-24-2008, 05:41 AM   #3
Well done, it looks great!
JohnDIY is offline   Reply With Quote
Old 08-01-2008, 12:59 AM   #4
Rewards Points: 518
Looks alot better. Enjoy trying to line up and hide your mitre cut gaps and getting everything to sit flush together? That was my first experience.
n0c7 is offline   Reply With Quote
Old 08-01-2008, 07:23 PM   #5
Knucklez's Avatar
Rewards Points: 930
look'n good.
what i found works great to hid the gaps, or gaps that might form after wood acclimates to your room, is to squish some flexible polyfil into the crack. this stuff can also be painted, so its good to do this before you paint the trim.
also, you can squish some into your nail holes to hide it. flexible polyfil is sandable, but you really don't need to do it if you rub it in with your thumb and clean up excess with a damp cloth.
available from HD comes in little hand size tubs.
Knucklez
Knucklez is offline   Reply With Quote
Old 08-02-2008, 10:48 AM   #6
Rewards Points: 150
Very nice. Enjoy the time you spend admiring your work.
It takes less time to do a thing right than it does to explain why you did it wrong.
-Henry Wadsworth Longfellow
beer_geek is offline   Reply With Quote
Oak casing to a vinyl jamb extension on a new window? Dustball Carpentry 13 04-14-2010 12:06 PM
window casing stool help? Images posted chinese_lover Carpentry 12 07-23-2008 10:04 AM
Correct way to install aluminum window casing? DavesHammer Remodeling 7 01-16-2008 01:39 PM
Window Casing around Vinyl Windows tcoshea Building & Construction 3 11-28-2007 10:52 PM
Window Casing?? james Building & Construction 5 06-28-2005 02:54 AM
