#1 |
Fireplace Remodel - ongoing
Going to eventually mount a flat panel above (yes, I know, not recommended... please no comments, I have weighed the cons and am still doing it). The fireplace has yet to be used in the last 5 years. Eventually I will convert it to a vented gas log that is not rated to heat the room.
To date: Washed/scrubbed/wire brushed the firebox about 8 times before rolling on the high heat paint. Removed the old mantel and 3 courses of brick in an effort to lower the new mantel placement which will also allow for a lower TV mount. Running HDMI cable and 18-3 for the IR repeater I want to install. Going to pull some Cat5e also just to have it along with some line for future pulls JIC. Tile installed. Had to build up the hearth a bit to ensure my opening would fit the stock door I wanted and reduce the door overlap of the tile (I want to see that beautiful tile). Next step is to grout and begin the wood work. I am going to face it with 1/2 ply that I can paint and then use 1x to create a raised panel look. I have never done this before so it should be interesting. Any helpful input would be appreciated...any known gotchas... |
#2 |
few more pics
#3 |
CooL! Keep the pictures coming on your progress. My fireplace is in dire need of a facelift. I love the work you've done so far.
#4 |
Thanks Ivy.
Made a little progress this weekend and did a test fit of the TV. Going to leave it up all week to determine if I like it. |
#5 |
Looks GREAT and the TV looks good up there. You are giving me inspriation to start my redo.
#6 |
Newbie Bill
Looking great. I'm going to follow this thread to see the outcome.
So what (and how) did you put directly onto the brick (right around fireplace opening) and on the hearth in order to install the tile? Are you going to tile around the front/side of the hearh too?
Bill A DIY Noob that knows just enough to be dangerous. |
#7 |
It's looking good. I'm looking forward to seeing more pictures.
#8 |
Thanks everyone. This is becoming a weekend only project so updates will be delayed.
This week I really am just trying to get used to the height on the TV. The couch is 15ft away so the angle isn't bad at all. I am starting to like it. More research during the Thursday Night preseason football game is required. Maybe tonight I can test the IR repeater too. If all goes well then on to the mantel and trim. I believe I have picked out the mouldings and trim profiles I am going to use. |
#9 |
Well, not much completed this past weekend but it is starting to take shape. It took alot of time makingsure everything was level. My 4ft level isn't cuttin it.
#10 |
Xtreme DIY'r
Looks good, much better then what was there
I have an unfinished fireplace remodel Waiting for some rainy or cold days to finish |
#11 |
That's going to look great. Keep up the good work!
#12 |
Lumberyard had the pencil moulding I wanted. On to the mantel now. I am probably going to span the windth of the fireplace and wrap the sides. Turn the mantel into the wall. This will seperate the bottom and top. Hope it comes out. I see it my head but to be honest, I am guessing at it. I cannot wait to get it painted (actually I can, painting sucks).
#13 |
Good work !! Can't wait to see the finished product.
A picture is worth a thousand words. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#14 |
and it continues...
Going to start filling and sanding this week. |
#15 |
Had a new addition to the family this past week so EVERYTHING is on hold.
I did get the HDMI runs terminated in the basement as well as the IR repeater. Moved the cable box, hooked it up and it is F'IN SWEET. Just point the remote at the little sensor to the right of the TV and MAGIC.... |
| Display Modes | |
| Fireplace remodel -- need advise & suggestions | mwehnes | Building & Construction | 12 | 06-28-2009 10:36 PM |
| Fireplace Remodel - Insulation around chimney | GeauxCajuns82 | Building & Construction | 3 | 01-19-2009 05:30 PM |
| New project: removal of old fireplace-replace with a new fireplace! | MrShadetree0222 | Building & Construction | 14 | 10-16-2008 07:12 PM |
| Help with an old fireplace remodel | Atomikk | Building & Construction | 3 | 10-15-2008 03:44 PM |
| Fireplace Surround Remodel | baksdak | Project Showcase | 5 | 03-06-2008 01:28 PM |
