Fireplace Makeover - Project Showcase - DIY Chatroom Home Improvement Forum
Old 12-31-2008, 09:39 PM   #1
Home Imp./Remodeler
Fireplace Makeover
I recently completed a fireplace makeover project for one of my customers and thought it might be helpful to others considering such a project to see how I did it.
http://s487.photobucket.com/albums/r...ce%20Makeover/
If you click on each photo, a larger version will come up with a short description at the bottom.
The customer wanted granite slabs for the hearth & surround, an oak mantel and drywall overmantel. The existing fireplace & raised hearth was brick with floor to ceiling chimney.
Dan V. is offline   Reply With Quote
Old 01-01-2009, 12:04 PM   #2
Registered User
Termite's Avatar
Beautiful work Dan. Looks a heck of a lot nicer than it did.
One question though. Is that cast stone trim for the mantel and on the sides? It looks like it was applied over the granite tiles...How did you do that?
Old 01-01-2009, 12:28 PM   #3
Home Imp./Remodeler
Are you asking about the stone around the firebox itself? Those 3 pieces are also slabs of Black Galaxy granite. I cut 3 identical pieces of HardiBacker and screwed them to the firring channel around the firebox. Then I set the stone slabs onto that with modified thinset. I did this the day after I set the hearth slab, so the added weight of the surround pieces wouldn't push the hearth slab down.
The unfinished pics show that better. The finished ones are after I cleaned and painted the inside of the firebox and the surround is difficult to see.
Old 01-01-2009, 09:00 PM   #4
Registered User
Termite's Avatar
I meant the white surround moulding and the mantle. Assuming its some sort of cast material? Wood can't be that close to the firebox and I'm always looking for a good solution to that problem.
Old 01-01-2009, 09:43 PM   #5
Home Imp./Remodeler
Actually, that is wood trim. The pieces came with the mantel kit that the customer wanted. Code here states that wood has to be at least 8" from the firebox opening and they are 8.25" away. As I said, it's hard to see in the finished pics, but there are 3 9" wide granite slabs for the header and legs of the surround.
Old 01-01-2009, 10:23 PM   #6
Registered User
Termite's Avatar
Gotcha. Funny how codes differ depending on which code is being used. Here the mantle has to be 12" above the firebox opening and the wood on the sides can only project 1/8" for every inch away from the firebox opening between 6" and 12", meaning that something 9" away from the firebox can only project 3/8".
Very nice job, thanks for posting it.
Old 01-03-2009, 10:20 PM   #7
That's awesome... I was wondering how one would attach sheet rock to a fireplace! I have a fireplace that was painted horribly and needs a little TLC!
justin2009 is offline   Reply With Quote
Old 01-05-2009, 04:55 PM   #8
Home Imp./Remodeler
Justin,
If your local codes allow it, use wood firring strips. I had to use the metal firring channel you see in my pics. A good solution and easy to attach to the brick as long as you have a hammer drill and tapcons. The only issue I had was trying to find the stuff. I wound up having to order it from a specialty building supply company (Allied).
If you wind up doing it, feel free to PM or email me with any questions.
Old 01-06-2009, 07:41 AM   #9
Originally Posted by Dan V. View Post
Justin,
Will do. We have a kitchen and bathroom remodel to start and finish first, so it might be a while before we get to the fireplace.
I'm intimately familiary with the tapcons, having installed pine flooring over my slab. I think I went through about a case of those things!
Beautiful work and I'll keep the firring strips in mind when we get to the fireplace!
Thanks!
Old 01-26-2009, 11:55 PM   #10
Hi Dan, nice work. I am about to start a simliar project. I am pulling out a wood burning insert fireplace and replacing it with a direct vent gas unit. I am going to drop the unit down to the floor instead of it sitting on a raised hearth. I too will be using black granite for a surround. Two questions....1) The floor is concrete slab. Can I put the Granite hearth directly on the concrete slab or should I put down plywood or microboard and then put the granote on top of that? What type of adhesive should I use to attach the Granite? 2) I couldnt tell from the pictures, what type of edge was on the granite slab used for the hearth? Thanks.
SeminoleMike is offline   Reply With Quote
Old 01-29-2009, 09:55 PM   #11
cocobolo's Avatar
Rewards Points: 5,832
Dan: That's a very classy installation.
And in case you're still wondering, the reason that it's still too short is because you have only cut it three times. The rule clearly states it must be cut four times. KCTermite told me so.
Bet I catch it for THAT.
cocobolo is offline   Reply With Quote
Old 01-30-2009, 09:07 AM   #12
DIY Rookie
Send a message via AIM to jpfreak33
Very nice, gives me some ideas if I can convince the wife to let me cover up our brick. Looks great!
jpfreak33 is offline   Reply With Quote
Old 01-30-2009, 11:15 PM   #13
Union Electrician
goose134's Avatar
Nice job. Looks great!
goose134 is offline   Reply With Quote
Old 02-10-2009, 01:34 PM   #14
Nice installation
Is that for a fireplace - wood stove?
Or do they have gas heat
I'm redoing my fireplace
I was originally going to do beige tiles on the facade & the hearth
Then I changed to just the facade & go with a dark hearth
After seeing yours its exactly the look I want
Old 02-14-2009, 08:53 AM   #15
Rewards Points: 150
Send a message via AIM to Bocolo
Dan,
Great job. What did you use to clean and paint the inside of the firebox? Thanks for your time.
Bocolo is offline   Reply With Quote
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 06:12 PM
convert wood fireplace to gas fireplace brisk Building & Construction 3 06-19-2008 08:17 AM
Possible to build direct-vent fireplace? DIYerself General DIY Discussions 3 12-22-2007 10:07 PM
Brick fireplace makeover 'Andyman Remodeling 2 12-14-2005 10:22 PM
