Finished Garage To Home Office/work Shop - Project Showcase - DIY Chatroom Home Improvement Forum
Old 07-10-2009, 10:07 AM   #1
DIY Expert in Training!
Finished garage to home office/work shop
I took on the project of gutting my garage to turn into a home office with a small garage/work shop. The garage was a mess with old paneling at 2 of the walls, sheet metal over cinder block on the 3rd, and a loud garage door. The wiring was run on the outside of the walls and screwed to the air ducts. The air returns where too far away and not air tight so the heater was failing. I started the Monday after Christmas and just go my CO.
Things I did:
* Gutted everything down to studs/joists
* Removed wiring from electrical service box and reran inside walls
* Added 2 20amp lines and 2 15 amp lines.
* Networked, added phone lines, and added cable
* Insulated
* framed wall to cover cinderblock
* Added window
* Drywalled, spackle, paint, etc
* Layed Laminant flooring
* Doors, windows, etc.
* Custom built transition where there once was a 3" curb step
* Built rolling work station, heavy duty shelving
* Built cabinet to enclose pipes and act as a counter
* Tiles counter and side step
* Hung cabinets
Outsourced work:
* Garage door
* HVAC
Pictures in next post:
gone_fishing is offline   Reply With Quote
Old 07-10-2009, 10:22 AM   #2
Before:
Notice dryer in garage...I fixed this with my last project (laundry room/half bath overhaul)
Also notice 40 year old cabinets and green metal walls
Old 07-10-2009, 10:26 AM   #3
In progress:
Before:
Window framing:
Old 07-10-2009, 10:30 AM   #4
Completed Project:
Tiled side curb and flooring:
New HVAC soffit, custom (me) base cabinet for pipes with tiling, cabinets for storage. Wall space and outlet for future flat screen.
New entrances to family room and garage
Rear wall cabinets
Rolling work bench and heavy duty storage shelving
Garage door entrance:
Old 07-10-2009, 10:41 AM   #5
Penn State "locker" cabinet to cover electrical service and networking gear.
Counter tiling:
Better look at my rolling work bench...the awesome Mitre Saw is my Father-in-laws so it will go back.
Old 07-10-2009, 12:12 PM   #6
Rewards Points: 338
It looks great. Nice work!
gma2rjc is online now   Reply With Quote
Old 07-10-2009, 03:40 PM   #7
diy mike's Avatar
That's amazing! It doesn't even look like the same space. And nice job with the rolling work bench. That should really come in handy.
diy mike is offline   Reply With Quote
Old 07-11-2009, 04:01 PM   #8
Registered User
Rewards Points: 5,216
Looking good!! You may want to check with your local Building Department on the minimum safety codes. When you cut that diagonal 1x4 wood let-in brace for the new window, you lost the shear flow in the corner. Not that big of a deal, maybe.
The window is required to be 3' from the gas meter for safety. (fire code)
The electrical panel cannot be hidden from view. (in case of fire, the firemen couldn't find it quickly)
Install the window under the foam board with flashing over the head. Use sticky window tape- installed around/on sill, jambs, head, then window- then over bottom window flange, jambs lapping down over, finally head lapping side jambs, then metal head flashing.
You could still fix the window as I would hate to see it wreck any of your hard work done so far. When the Inspector OK's the conversion, it will go on your house's personal record with the County, and be listed as living space when you sell. It would be nice to re-coup some of the money spent!
Be safe, G
Old 07-11-2009, 04:21 PM   #9
Gbar...I passed all inspections with no corrections. I did install the window as you said but it's tough to see because of the picture. Since I did this project when my son was 3 to 10 months old most of our pictures are of him...we took very few of the in process project.
What, exactly, is a finished garage? joeyboy Carpentry 3 10-02-2015 11:27 AM
new double garage murray1426 Building & Construction 4 05-23-2009 02:11 PM
Yet another garage subpanel thread (w/ pictures!) MattOverMinder Electrical 9 07-25-2008 03:15 PM
Pay GC to construct home and finish it myself? L O N G . . . Badfish740 Off Topic 9 07-27-2007 09:44 AM
