Drill Press Table - Project Showcase - DIY Chatroom Home Improvement Forum
Old 01-28-2013, 10:57 AM   #1
jackie treehorn's Avatar
Rewards Points: 174
Drill press table
I have this old school rockwell drill press that works pretty well other than having a steel plate for the table. I decided to make one that would be pretty functional for using hold downs etc, but for spending under 30$ & using left over stuff I'm pretty stoked.
First drawing/layout
Center will have a replaceable plug, I'm masking it off so I can bondo it to make an exact replica which I can then use to make the jig that will sit on the wall for whenever I need replacements.
Piece for jig
Final jig
Added some laminate from leftover deathstar project, a little too dark and already has built in scratches, but it's better than nothing
In place
Additional screw on leafs for bigger parts. I didn't want to always be reaching over some huge table but also didn't want to flail when drilling a cabinet door or something so I used some machine screws and t-nuts to add on extension pieces
Sacrificial plug in place
Got the fence done, I used some extruded aluminum t track and built some stop blocks too
jackie treehorn is offline   Reply With Quote
Old 01-28-2013, 10:59 AM   #2
Rewards Points: 174
Here I'm working on bulding a way to raise and lower it since someone welded the stuff together previously and they made it not square or straight, that doesn't make for nice holes.
A little test action using wire
The lift mechanism works rather well, I used replacement rollers for screen doors for the bearings, and made the tolerance between the two boxes real tight so they stay square to each other.
Old 01-28-2013, 01:05 PM   #3
Dorf dude...
shumakerscott's Avatar
Rewards Points: 1,190
This is fantastic Great job.
Today is only yesterdays tomorrow, Now get to work!
shumakerscott is offline   Reply With Quote
Old 01-28-2013, 01:50 PM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 2,110
Ok.....that rates up there in the cool and awesome factors......
How did you cut the slots....that looks like vert mill quality.
Old 01-28-2013, 03:14 PM   #5
Rewards Points: 174
Thanks guys! I wish I had a mill, just a good ol' router table was used.
Old 01-28-2013, 04:10 PM   #6
Rewards Points: 174
Found one last pic from looking at the bottom with everything in place
Drilling straight holes without drill press pomelo Carpentry 17 01-24-2012 06:47 AM
Porter Cable drill press jeffs55 Tools 6 12-28-2011 10:07 PM
hammer drill vs. rotory hammer, my results. forresth Tools 3 09-15-2011 09:08 PM
Rookie needs advice - How to remove old thinset from concrete floor? rookie floor layer Flooring 9 10-04-2009 12:01 PM
Bosch GSB 16 RE drill Coxy Tools 0 05-28-2009 01:46 AM
