-   Project Showcase (http://www.diychatroom.com/f49/)
-   -   Drill press table (http://www.diychatroom.com/f49/drill-press-table-170357/)
jackie treehorn 01-28-2013 11:57 AM
Drill press table
I have this old school rockwell drill press that works pretty well other than having a steel plate for the table. I decided to make one that would be pretty functional for using hold downs etc, but for spending under 30$ & using left over stuff I'm pretty stoked.
First drawing/layout
http://img.photobucket.com/albums/v2...e/IMG_4857.jpg
Center will have a replaceable plug, I'm masking it off so I can bondo it to make an exact replica which I can then use to make the jig that will sit on the wall for whenever I need replacements.
http://img.photobucket.com/albums/v2...e/IMG_4858.jpg
Piece for jig
http://img.photobucket.com/albums/v2...e/IMG_4860.jpg
Final jig
http://img.photobucket.com/albums/v2...e/IMG_4861.jpg
Added some laminate from leftover deathstar project, a little too dark and already has built in scratches, but it's better than nothing
http://img.photobucket.com/albums/v2...e/IMG_4866.jpg
In place
http://img.photobucket.com/albums/v2...e/IMG_5818.jpg
Additional screw on leafs for bigger parts. I didn't want to always be reaching over some huge table but also didn't want to flail when drilling a cabinet door or something so I used some machine screws and t-nuts to add on extension pieces
http://img.photobucket.com/albums/v2...e/IMG_5838.jpg
Sacrificial plug in place
http://img.photobucket.com/albums/v2...e/IMG_5839.jpg
Got the fence done, I used some extruded aluminum t track and built some stop blocks too
http://img.photobucket.com/albums/v2...e/IMG_5849.jpg
jackie treehorn 01-28-2013 11:59 AM
Here I'm working on bulding a way to raise and lower it since someone welded the stuff together previously and they made it not square or straight, that doesn't make for nice holes.
http://img.photobucket.com/albums/v2...e/IMG_5871.jpg
http://img.photobucket.com/albums/v2...e/IMG_5873.jpg
http://img.photobucket.com/albums/v2...e/IMG_5877.jpg
A little test action using wire
http://img.photobucket.com/albums/v2...e/IMG_5879.jpg
http://img.photobucket.com/albums/v2...e/IMG_5906.jpg
http://img.photobucket.com/albums/v2...e/IMG_5905.jpg
The lift mechanism works rather well, I used replacement rollers for screen doors for the bearings, and made the tolerance between the two boxes real tight so they stay square to each other.
shumakerscott 01-28-2013 02:05 PM
This is fantastic:thumbsup: Great job.
ddawg16 01-28-2013 02:50 PM
Ok.....that rates up there in the cool and awesome factors......
How did you cut the slots....that looks like vert mill quality.
jackie treehorn 01-28-2013 04:14 PM
Thanks guys! I wish I had a mill, just a good ol' router table was used.
jackie treehorn 01-28-2013 05:10 PM
Found one last pic from looking at the bottom with everything in place
http://img.photobucket.com/albums/v2...e/IMG_6116.jpg
