Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > Project Showcase
Old 10-06-2009, 04:03 PM   #1
Default dr. awsome's house remodel
The wife and I purchased out first home last April. It's located near the University of Utah in Salt Lake City. The home was build in 1896 and was in good structural condition but in a desperate need of a face lift. I'll be posting pictures of the work we have done over the next few days. Hope every one is ok with me showing off my handy work.
Dr. Awsome is offline   Reply With Quote
Old 10-06-2009, 04:27 PM   #2
Old 10-06-2009, 04:45 PM   #3
When we bought the house the front room and the master bedroom looked horrible. From what we could tell there was at least 5 layers of wall paper over plater and lath. We had one month overlap between buying our house and having to be out of our apartment so we decided to tackle those two areas first since they would be the most difficult to do after we had moved in.
We recruited quite the army of people to help. We were able to have about 7 people helping us on the first day. With that much help we were able to peal off the wall paper (it turns out there was 11 layers) remove any loose plaster and hang 23 sheets of drywall with a first coat of mud. It was a long hard 13 hour day.
The father in law and his contractor starting to put up some dry wall.
More dry wall in the front room.
My parents helping out
getting closer to a finished look
In the bedroom all the plaster came down with the wallpaper.
More in the bedroom
With the new drywall
Close to 10:00 PM on day one.
More at the end of day one, and my poodle standing guard of his new home.
Sanding some mud
Old 10-06-2009, 04:46 PM   #4
More sanding
Front room after primer
The final color
Old 10-06-2009, 05:07 PM   #5
Great job, well done. Like the colour scheme as well. You didn't fancy putting the lime plaster back then?
stuart45 is offline   Reply With Quote
Old 10-06-2009, 05:17 PM   #6
Nope, not a fan of the plaster. We wanted a perfectly clean and smooth look. I don't have the skill or time to do that with plaster.
Since we have moved in we've also gutted and redone the kitchen and dinning room. Currently we are working on ripping out the back yard so it will be ready for plants in the spring. I'll post more pictures when I find them.
Old 10-06-2009, 05:29 PM   #7
A wise choice, lime plaster is hard to use if you are not used to it. A lot of our old houses are Listed buildings and English Heritage make you replace the old lime plaster again. Luckily my house is old but hasn't been listed yet. It's actually a criminal offence to alter a listed building without their consent, and carries a prison sentence.
Old 10-06-2009, 05:35 PM   #8
My home is in a historic district. I read the rules and regulations very carefully before I started to do any work. In there rules they have lots of buzz words that would easily scare someone who doesn't know what they are doing, but in the end all it says is the home has to look like it would fit in the original era from a street view. Other than that it's up to the home owner to make it fit there needs.
Old 10-06-2009, 07:06 PM   #9
Extreme DIY Homeowner
Scuba_Dave's Avatar
Moved to Project showcase forum
Looks like you have a big project
DIY Chatroom Moderator
Not a Pro or for hire, I have enough to do on my own house, Just Look !!
http://www.diychatroom.com/f49/house-renovation-ongoing-37438/
Old 10-07-2009, 02:15 PM   #10
DIY Apprentice
tripflex's Avatar
pictures don't work...
scratch that...had to use firefox running through my proxy server, our stupid filter at work blocked the pictures...ugh
"How else am i supposed to build my tool collection and owe home depot lots of money? That's why I DIY"
2,200 SQ ft 3/2 Lake house with in-ground pool: http://picasaweb.google.com/tripflex
Help us help you by posting pictures with your question!!
tripflex is offline   Reply With Quote
Old 10-08-2009, 02:22 PM   #11
I found some of the pictures of my kitchen remodel. When we moved into the house the kitchen was functional but horrifying all the same. The cabinets were old and built into the house. The stove was blocking some of the cabinets so they couldn't be used. At one point the PO painted the cabinets to try and make them look better. I guess he didn't know you can't paint over laminate and the paint was peeling off. The laminate flooring had some tares and it was obvious some water had seeped into the sub floor. We started by trying to do simple changes to help the aesthetics but ended up taring the whole thing out and starting from the ground up. It took almost half a day to pull out the old cabinets with my hammer after finding some used cabinets online.
Once the cabinets were out we started on the flooring. The old laminate came out nice and easy but we found a wonderful surprise under it. Who ever had laid it down had also put in a new sub floor of particle board that had got wet. We ended up pulling out the sub floor an putting in a new one.
Underneath we found the original floor from when the addition was made.
On the left you can see the rough plumbing for the new sink. We moved it from looking at a wall to looking out into the back yard. A much needed improvement.
We decided on a black and white linoleum.
Walls primed
The wife choose the paint color and it turned out to be too dark for the space. Plus when we painted the wall we discovered the PO didn't know how to mud or texture. We're not sure which they were going for.
We ended up having to skim the entire room with a few coats of mud to get it smooth again.
This is the color we ended up going with.
Old 10-08-2009, 03:14 PM   #12
Scuba_Dave's Avatar
Very nice change - I like the floor & the wall color
I has 12 layers of flooring at my last house - what a mess
Kitchen was one of the 1st things I did at my last house, 1st was the bathroom
Old 10-09-2009, 04:12 PM   #13
what did you use to cover the black and white tiles, seems like a light green sheet of some sort....
sbmfj is offline   Reply With Quote
Old 10-09-2009, 04:15 PM   #14
The flooring is a sheet linoleum and the green sheet you can see while we are painting is just a painters tarp.
Old 10-10-2009, 10:23 PM   #15
great job..can't wait to see more pics !
kimber is offline   Reply With Quote
More On This Topic
With the push to go "green," many companies are answering the call. Contractors are among the companies as well as people using eco-friendly products in building and remodeling. Kitchen cabinets are among those items available in eco-friendly terms. Use... Read More »
Yes, it is possible to build a debt-free home. From log homes, earthen homes and stick built homes, you can build a home and remain debt-free. Concentrate on the basics to start with, then add finishing touches as you can afford it. Here are some ideas... Read More »
We're back in our room and now we've got, mostly finished, drywall and a coat of primer paint and we chose this orange primer color because we're going to come over it with a caramel color. Drywall, mud, tape, sanding and a coat of primer always over... Read More »
So the first thing that you want to think about when you are doing any sort of construction or repair on your house or whatever is safety. For this job the only things that we are going to need for safety are good pair of gloves because of the scraping... Read More »
People are now living to be in their upper eighties, and beyond. This rise in the senior population is bringing the need for safe, accessible bathrooms to the foreground. No one wants to think their elder parents are facing hygiene hardships. Many... Read More »
Trane XR12 1.5 ton-Too small for my house? Badfish740 HVAC 7 09-23-2009 07:48 AM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-11-2009 12:09 AM
replumbing an old house simonfrog Plumbing 5 05-29-2009 07:44 PM
Some walls rattle in my house if hit with something, I will explain inside posting zincmann Building & Construction 4 11-10-2008 05:05 PM
Re-siding house jdig Building & Construction 5 04-10-2007 11:15 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
