Downstairs Washroom Renovation - Project Showcase - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree1Likes
Old 01-31-2013, 07:24 PM   #16
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 740
Got a look at the drain and vent pipe routing in the wall.
I'm no expert but I think it looks OK.
2" out of the floor from the toilet and shower to a 1-1/2" where the 1-1/4" from the sink joins in. The 1-1/2" then goes out and up into the upstairs bathroom wall where it joins into a 3" stack and out the roof.
Thanks for looking,
Pugsy.....my project: Total House Rebuild Bungalow to Two Story
123pugsy is online now   Reply With Quote
Old 02-02-2013, 08:29 PM   #17
123pugsy's Avatar
Rewards Points: 740
I got the toilet removed and the last of the drywall and insulation off.
I then removed the supply lines and cleaned and extended the vanity drain to its new location.
I got the wires and supply pipes for the vanity rerouted and roughed in.
Old 02-03-2013, 08:53 PM   #18
123pugsy's Avatar
Rewards Points: 740
I got the sub floor ripped out and started digging out the drain pipes from the shower and toilet.
The shower drain was 2". They had it reduced to 1-1/2'' ot the top of it.
Chunks of clay tile buried in the ground. I find stuff buried everywhere I dig on my property. I used the jackhammer to break them into bits to get them out.
Of coarse I didn't realize that I was at a "Y" intersection. I guess that's why all the pros around here tell us to hire experts. I sure hope I didn't crack anything. I will be having my buddy Kall come in to run the new pipes. He's a master plumber. He's calling a guy to scope all the drain pipes first.
Here's a pic showing all the pipes and where they are/were from and where they go.
Old 02-09-2013, 12:06 PM   #19
123pugsy's Avatar
Rewards Points: 740
New drain lines mocked up ready for gluing.
Thanks to the guys in the plumbing forum for answering questions regarding this run.
Old 02-09-2013, 07:50 PM   #20
123pugsy's Avatar
Rewards Points: 740
I got the pipes all glued up, tested for leaks and then layed down on a bed of sand.
I also got the concrete down today. Tomorrow I need to move a wall as the shower base is alot bigger than I first thought.
Old 02-13-2013, 08:36 PM   #21
123pugsy's Avatar
Rewards Points: 740
I finally lost it with the strapping on the block wall. It was at so many planes that the drywall screws would pop right thru if I left it. I got the strapping all torn down, insulation up and new 2x3 strapping started.
This shot shows a problem that would bite me when it was time for the 2 storey addition. Since the floor joists will be cut back to make room for a brick ledge and the new sill plate will be pretty much flush with the inside of the block, I had to rip out the top board from the window.
Old 02-18-2013, 07:18 AM   #22
123pugsy's Avatar
Rewards Points: 740
I finished the strapping over the foam board. I also got the plumbing done and the pipes insulated.
Thanks for looking,
Old 02-18-2013, 09:22 PM   #23
123pugsy's Avatar
Rewards Points: 740
Yeah!
Finally feels like I'm getting somewhere.
After furring out the crooked walls for a bunch of hours I got the drywall done.
Start the mud tomorrow.
Old 02-23-2013, 02:24 PM   #24
123pugsy's Avatar
Rewards Points: 740
Mudding going slowly. I'm still using too much. I think I'll never learn....
I decided to cut the tiles while the mud was drying. I lucked out and got three walls with exactly half tiles. Not much cutting re'qd.
Old 05-05-2013, 09:22 PM   #25
123pugsy's Avatar
Rewards Points: 740
I got everything primed and painted.
Then the tile fun began......
By the time I got from one wall to the other , I was buttering the tiles about 1/2". Of coarse it helps to know what you're doing so next time I will know to use some self leveling. I decided to use some dry pack in this case. I just hope it wasn't a mistake...
Tiles down and grouted along with shower and toilet.....
Old 05-05-2013, 09:29 PM   #26
123pugsy's Avatar
Rewards Points: 740
A couple more pics. Huge improvement on toilet space.....
After furring out the wall, I came about 1/2'' shy of code on the wall side of the toilet. No big deal though.
Old 05-05-2013, 09:42 PM   #27
123pugsy's Avatar
Rewards Points: 740
Vanity and towel bars installed temporarily. Tiles should finally be arriving soon. All these pics were taken about 7 weeks ago. I was going to wait til I was done but thought this thread was due for an update....
The vanity mirror was too "thick" so I hung it over the toilet and used a mirror over the sink. The cupboard will be needed if 6 of us will be living off one washroom during the 2 story renovation....
New door, from the hallway side. You can see the light and fan switch back outside of the washroom....
I seen this casing design on a thread here and had to copy it. I think it came out great.....
The washroom is too small to take a full pic of the door even. I believe its about 36 square feet......
I just got the window changed and the finish carpentry done this weekend....
Now, if the tiles ever arrive I can finish this project so I can move forward with my drawings and submit for permit.
Thanks for following along,
The Following User Says Thank You to 123pugsy For This Useful Post:
gma2rjc (09-10-2016)
Old 05-17-2013, 09:09 AM   #28
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
Wow, what a difference. Nicely done.
CoconutPete is offline   Reply With Quote
Old 05-17-2013, 09:45 AM   #29
Amateuralex's Avatar
Rewards Points: 270
Really cool thread, looks fantastic, thanks!
Amateuralex is offline   Reply With Quote
Old 05-17-2013, 10:14 AM   #30
123pugsy's Avatar
Rewards Points: 740
Thanks guys.
Well, Ive been waiting 8 or 9 weeks for tiles. I called the store and was told they were discontinued. Just gotta love the morons working for these places....
upstairs zap fried downstairs tv!! AnnieRee11 Electrical 3 11-05-2012 12:17 PM
My First Bathroom Renovation...Help Needed! JadRutherford Building & Construction 29 07-27-2012 07:49 AM
Heat working downstairs, but not upstairs, though fan comes on. Mister M HVAC 15 11-22-2011 07:03 PM
Basement Renovation Planning: Help! navi_jen Plumbing 0 06-16-2010 10:41 AM
Downstairs renovation: Study/sitting room skwpt Project Showcase 13 10-04-2007 05:04 PM
