01-27-2013, 07:15 PM
#1
MEASURE ONCE, CUT TWICE
Downstairs Washroom Renovation
01-27-2013, 07:17 PM
#2
I peeled off some wallpaper and after spraying with water, the glued paper below scraped off easily. Of coarse under that is a layer from  . There's no design on it, they just left the glue layer and papered over that. It took aboout an hour to scrape off only a foot of this entity.
Anyone got a good method to romove this stuff?
01-27-2013, 07:22 PM
#3
The floor appears to be up about an inch and a half. Not sure why this is, perhaps something to do with the drains or vents.
I pulled the shower out and found the drain installed with some goop around a 1-1/2'' copper pipe.
Is this how a shower drain is supposed to be installed?
I will post updates as I proceed.
01-27-2013, 07:31 PM
#4
Showers need a 2" drain. Sure hope you do not have to meet any codes in your area.
Not even close to being enough clearance for that toilet.
01-27-2013, 08:13 PM
#5
Thanks Joe.
I need to move the drain for the shower, so I'll look into the 2''. I like to do stuff to code, not necessarily pull permits for each thing.
I'll also be getting a smaller vanity and swing the toilet 90*
I just checked and saw a 1-1/2" copper pipe coming out for venting of the 3 fixtures. Is this big enough?
Proposed:
Existing:
01-28-2013, 07:18 PM
#6
The Following User Says Thank You to 123pugsy For This Useful Post:
01-28-2013, 08:13 PM
#7
I got the layout figured out to meet code and still come out with a larger vanity than I have now.
01-28-2013, 08:44 PM
#8
That shower drain looks like someone threw a wax toilet seal in between the inside and outside. Someone did some crazy work there. Good luck with rest of it, hopefully that's all you find wrong.
01-28-2013, 09:00 PM
#9
Oh yeah. Everything the PO did is cobbled together. I love the way he installed the dimmer switches by stripping off some insulation, wrapping another wire around the bare spot and hitting it with black tape.
Ya just got to know the drains will be whacked.
01-30-2013, 04:47 PM
#10
looks like you got your work cut out for you there. If you want to remove wallpaper I have found using liquid fabric softener and water, works like a charm, soak the wall have a smoke and then it should come off easily. I would also recommend installing insulation for sound purposes. Also I would use cement board for the shower area unless you are going to install a standing shower kit. Will look forward to seeing your progress.
01-30-2013, 07:56 PM
#11
Thanks fixrite.
I've got an easier way to take down the paper and that's by rocking right over it.
I am using a stand up kit but I will use the green wallboard any way.
Anyhow, I got the light switch box moved to the inside of the washroom as it was outside before and it rubs me the wrong way having it there.
The wire was a bit short so I ran it over to a j-box in the laundry room and ran it back. I installed a double box so I can wire in the new fan.
01-30-2013, 08:09 PM
#12
DOH!
The switch box ended up back out in the hallway. Too close to the shower.
Next order of business was getting the fan installed.
Tight fit. Just made it.
Wired up and running.
Just the fun part of the fan install left. "Drilling" a 4-1/4'' hole thru the wall beside the dryer vent.
01-30-2013, 08:54 PM
#13
I always use solid piping for my ducting as it doesn't get clogged with lint, same as my dryer. Just something to think about for next project. The bathroom fans I install I usually buy ones that are motion activated so I have no need for a switch. They are on always but on very low, works like a dream.
01-31-2013, 05:40 AM
#14
Thanks fixrite.
I prefer hard pipe as well. The run of the flex is only 3', so no worrys. Its pulling steam only. This washroom will only be used during the house renovation. After that there will be two new full baths upstairs and its likely the shower will never be used again.
01-31-2013, 06:48 PM
#15
PUGSY
My project: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
