Don't Have A Tool? DIY It - Project Showcase - DIY Chatroom Home Improvement Forum
Old 10-05-2014, 09:56 PM   #1
World's Tallest Midget
Mort's Avatar
Rewards Points: 550
I've been doing some woodworking lately, and it turns out I needed a scratch awl. I didn't have one. But what I do have is a log and a carriage bolt.
So to work I went. I measured out about halfway down the bolt to turn the handle, drilled a hole down the middle, and bolted her in there. Afterwards, all it took was a few minutes on the bench grinder (wasn't perfect, could probably use a jig), and you've got your very own awl.
So for a 28 cent carriage bolt, I've got a homemade tool that looks cooler than a store bought one by a mile. I liked it so much I made a few more.
Mort is offline   Reply With Quote
The Following 2 Users Say Thank You to Mort For This Useful Post:
cleanlymaid (11-17-2014), gma2rjc (10-07-2014)
Old 10-05-2014, 10:38 PM   #2
Rewards Points: 1,446
Nice creation. I would just have grabbed an ice pick.
Is the carriage bolt a harder one than the usual grade?
ED
de-nagorg is offline   Reply With Quote
Old 10-05-2014, 10:41 PM   #3
Mort's Avatar
Rewards Points: 550
Nope, just your average grade 5. Small town, stuff tends to cost more here. And I don't have an ice pick either.
Old 10-07-2014, 10:25 AM   #4
Rewards Points: 85
Nice!
Here's your next project...
http://woodgears.ca/bandsaw/homemade.html
spiragui is offline   Reply With Quote
Old 10-07-2014, 12:34 PM   #5
Ole Wood Worker
BigJim's Avatar
Rewards Points: 3,208
Man, those do look good, way to go, I like them.
New members: Please consider adding your location to your profile.
If you aim at nothing, you will hit it every time!
Jim
BigJim is offline   Reply With Quote
Old 10-07-2014, 12:52 PM   #6
Rewards Points: 1,922
I made one long time ago from a small no good hard round shank screw driver but it won't hold a candle to yours. In fact it's really ugly.
Have you ever chucked in a variable speed drill to grind? Run the drill lefty loosie.
SeniorSitizen is offline   Reply With Quote
Old 10-07-2014, 01:35 PM   #7
Ole Wood Worker
BigJim's Avatar
That is a great idea, I hadn't thought about that, thanks for the tip.
Jim
Old 10-07-2014, 02:36 PM   #8
Thanks BJ
I didn't elaborate but I've been known to grind a point on the opposite end of some projects, put the point in a center hole in a piece of wood to steady the operation with mu other hand. I suppose we could call it a red neck tail stock.
I also often plunge grind, depending on the situation. Need an end threaded? You can take it down to to within the tolerance of a gnat's a$$. Please don't ask how close that is. Probably a local or even possibly a family term.
Sorry Mort about the almost hi-jack.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
BigJim (10-07-2014)
Old 11-16-2014, 02:15 AM   #9
Rewards Points: 29
........................and I thought that I was overkill!!!!!!!!!!!!!!!
jeffs55 is offline   Reply With Quote
Old 11-16-2014, 09:01 AM   #10
r0ckstarr's Avatar
Originally Posted by spiragui View Post
Nice!
Then build the panto-router after that.
r0ckstarr is offline   Reply With Quote
Old 11-17-2014, 11:00 PM   #11
Cleaner
Rewards Points: 24
Pretty innovative! Of course you still need a bench grinder and carriage bolts.
cleanlymaid is offline   Reply With Quote
convert cordless tool to corded? jason41987 Tools 14 12-03-2012 10:49 PM
Clamping tool or Oscilating tool for a DIY'r-you can only pick one which would it be? whataboutj Tools 12 11-29-2010 08:12 AM
Review: Harbor Freight Oscillating Tool Tedstor Tools 0 07-13-2010 03:24 AM
Need Help with re-design ttwiss Remodeling 21 05-08-2010 11:27 PM
Fein's Multimaster Tool...don't let the price scare you! CrossWorks Tools 13 04-18-2009 07:39 PM
