DIY Jacuzzi And HotTub - Project Showcase - DIY Chatroom Home Improvement Forum
Old 07-18-2014, 02:23 AM   #1
Rewards Points: 14
Talking
DIY Jacuzzi and HotTub
DIY Jacuzzi and HotTub:
- frame: from wood
- pump: 1100W
- heating: wood
- light therapy: RGB led with dimmer
- size 900L
asbarmarta is offline   Reply With Quote
Old 07-18-2014, 03:12 AM   #2
Rewards Points: 14
some pictures about my DIY jacuzzi
Old 07-18-2014, 03:13 AM   #3
Rewards Points: 14
short video about the building:
Old 07-18-2014, 09:28 AM   #4
Roofmaster
Rewards Points: 2,172
Nice. Add a hand rail before you get sued. LOLOL
Old 07-18-2014, 10:38 AM   #5
Rewards Points: 77
Looks really nice! As far as your bench goes, why didnt you put the bench under the liner? How did you protect that wood so it wont be destroyed sitting in that tub like that?
patented is offline   Reply With Quote
Old 07-21-2014, 07:05 AM   #6
Rewards Points: 14
the bench is painted with wood oil. The most important is, that the bench should be in water every time. In this case the banch does not contact with oxygen.
Old 07-22-2014, 05:39 AM   #7
Rewards Points: 14
video about the light therapy:
Old 07-22-2014, 10:37 PM   #8
Rewards Points: 276
Where is the wood stove (heat source)?
Jim F is offline   Reply With Quote
Old 07-23-2014, 01:25 AM   #9
Rewards Points: 14
Wink
heathing
the wood stove is the near of the jacuzzi. I attached some pictures. 2,5 meter copper pipe is wound in the stove.
Old 07-31-2014, 02:29 AM   #10
Rewards Points: 14
Old 07-31-2014, 09:56 AM   #11
Roofmaster
Clever guy. I think I would move the wood ladder like feature a little farther from the flame though.
Old 08-01-2014, 06:11 PM   #12
Rewards Points: 276
Wouldn't the tub be more relaxing if the jets were underwater?
Old 08-01-2014, 06:23 PM   #13
Rewards Points: 402
Very cool. So what was the white stuff you put between the wood and the liner? Something to act as a cushion?
Where did you get the liner?
taylorjm is offline   Reply With Quote
Old 08-13-2014, 09:00 AM   #14
Rewards Points: 14
the white stuff is: geotextile
softer feeling
Old 08-13-2014, 09:04 AM   #15
Rewards Points: 14
"Where did you get the liner?" --> I found a company, which is making big pools for adventures. They had residuals. But you can buy this anywhere
Tags
hot tub , jacuzzi , spa
Insulation around a HotTub / Jacuzzi Kronie Plumbing 1 02-11-2011 12:55 PM
