Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > Project Showcase
Old 02-08-2012, 04:50 PM   #1
Blues Hockey Fan
cprice12's Avatar
Detached Shed/Workshop
Did everything myself...well, with the help of a few budies & family members at times.
It's 22'x17', on a concrete slab, vinyl siding & house wrap, keyless entry lock, three windows, architectural shingles, two attic vents, soffiting, etc. The house wrap wasn't really necessary, but I decided to put it on after a friend of mine had some leftover from some construction he was doing, so I figured what the heck.
Here's some photos of the process:
Photo Gallery
I'll have to add a finished outside photo, as the last photo in that gallery doesn't show the painted trim around the overhead door and the weather stripping.
Still a lot of work to do on the inside as I am currently wiring lights and outlets, need to build more shelving, etc.
I'm also going to rock the area in front and connect it with our rock driveway...and probably put a slab in front of the door.
Interesting hiccup in the process....
Not even 24 hours after I finished shingling, a 120mph wind tornado came through and we lost part of the roof on our house, and had a decent number of shingles ripped off the workshop roof...along with the west facing wall being pushed in a couple inches.
cprice12 is offline   Reply With Quote
Old 02-08-2012, 05:17 PM   #2
Busy DIYer
picflight's Avatar
Very good, excellent job. I really enjoyed looking at all your pictures.
picflight is offline   Reply With Quote
Old 02-08-2012, 05:21 PM   #3
Blues Hockey Fan
cprice12's Avatar
Thanks!
I enjoyed working on it. It was the biggest project I've ever taken on and it was a lot of fun. Nice feeling of satisfaction as well.
Made a few mistakes...but nothing major...that's how it goes. It was a good learning process.
I'm just glad the tornado didn't rip it all down.
Old 02-08-2012, 08:29 PM   #4
Super Moderator
I'm envious---nice shop with plenty of light--
You nearly got to build that twice!!! I've never seen a wall pushed in like that--
You must have that anchored well to the slab---
Old 02-08-2012, 09:35 PM   #5
Disabled wood vet
titanoman's Avatar
You need outriggers and I never put gable studs flat.
And I don't see any strongbacks.
That would have tied the wall into the rest of the building.
May have something to do with why some of the damage occurred the way it did.
titanoman is offline   Reply With Quote
Old 02-08-2012, 10:38 PM   #6
Blues Hockey Fan
cprice12's Avatar
Outriggers...yes. Probably. We built the overhang, screwed it together and screwed it to the gable...then the roof decking tied it in.
Not the best way, but it was either that, or notch out the gable and lay the outriggers flat because the gables were the same size as the rest of the trusses.
The gables were tied into the top plates with L brackets and they were bent, but they held. It was the two top plates fanning apart and pulling out the nails.
I have since lag bolted the top plates together and also put up an 8' long 45 degree angled 2x4 on each corner for support at the top plate against the top plates on the side walls. It's not going anywhere again.
The gable studs came flat from the manufacturer...so we put them up that way.
Great point. I may put some in. Thanks for the tip. But with the extra supports I have already put in since the storm, it might not be necessary. Could only help though.
Do you attach them to each truss, or just at the ends? I imagine it would be much stronger if it is attached to each truss.
How long would you make the strongbacks?
And how would you tie them in?
Old 02-08-2012, 10:53 PM   #7
Disabled wood vet
titanoman's Avatar
Put two in, from gable to gable (same length as the building) and nail each truss straight (on layout).
All you need are rat runs (2x4's), not strongbacks because I didn't realize they were trusses.
Other than that, looks real good.
Old 02-08-2012, 10:58 PM   #8
Blues Hockey Fan
cprice12's Avatar
Easy enough.
Might do that this weekend.
Thanks!
Old 02-08-2012, 11:01 PM   #9
Disabled wood vet
titanoman's Avatar
Originally Posted by cprice12
Easy enough.
Thanks!
You're welcome.
Wiring a detached garage from another detached garage? bhawghead Electrical 7 05-25-2011 01:54 AM
Need help planning an electrical service upgrade to detached garage PaulTurner Electrical 2 04-05-2011 04:43 PM
wiring 100A to detached garage snowman Electrical 4 11-28-2009 05:53 PM
Definition of Detached house vinny General Discussion 2 06-01-2009 01:08 PM
Standby generator connected via detached garage? vsheetz Electrical 22 04-04-2009 03:44 AM
