Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > Project Showcase
Old 07-11-2009, 09:08 PM   #1
Newbie Bill
Deck repair, oops replace, oops new patio door thread
Hey Gang,
Well today I started to pull the nails on a few 2X4 deck boards to replace the rotten ones.
Like all DIY projects, as you get into it, you uncover more work than what you originally planned for. There seemed to be a lot more rotten boards than I originally thought. As I pulled the rotten ones off, guess what else was starting to show some rot. Yes the joists and especially the end joist. OK no biggie, deck is only 12X17 it won't cost me a fortune to redo the whole thing and this time with pressure treated lumber (at least for the joists etc). Maybe we would even be able to change the layout a bit.
I can't find any photos of the deck "Before" the start of the project.
But here is where the deck is right now.
It is amazing what one can do in an hour with a skill saw.
deck-repair-oops-replace-oops-new-patio-door-thread-dsc01917.jpg   deck-repair-oops-replace-oops-new-patio-door-thread-dsc01915.jpg
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 07-11-2009, 09:19 PM   #2
Newbie Bill
Now like all DIYers, it is important to have your "Tim the Tool Man Taylor" moments. Here is mine.
I was using the skill saw to trim the decking along each joist to ease removal. I was right in front of those lovely patio doors.
Well I got too close to one of the nails and Zing.... Thwack!!!. Hmmm, I says to myself, what was that.
I look up at the patio door directly in front of me and the window on the left looks just fine. As I am standing there I hear this crackling noise, you know, the sound tempered glass makes. Well, I look at the pane on the right and HOLY Cow Batman, I now know where that nail head went.
The one pane on the right hand side of the patio door had shattered. Oh man, I can't believe I did that.
I didn't take a photo of the window, I just taped up some plastic and pulled it all down.
Here is the biggest piece of the patio door pane that remains and below that is some fragments I couldn't get out.
So my deck repair is now a deck replacement and most likely a patio door replacement as well.
I am living up to my signature at the bottom.
deck-repair-oops-replace-oops-new-patio-door-thread-dsc01916.jpg   deck-repair-oops-replace-oops-new-patio-door-thread-dsc01913.jpg
Bill
Old 07-13-2009, 03:51 PM   #3
Dorf dude...
shumakerscott's Avatar
Bill I don't want to say anything that would sound pathetic but "Sh!t Happens" and "Sometimes when it rains It pours" I hope your done with the special moments and things go back together without a hitch. dorf dude...
I look pretty young but I'm just backdated
shumakerscott is offline   Reply With Quote
Old 07-13-2009, 04:42 PM   #4
Newbie Bill
Thanks Dorf Dude,
I too hope we are done with the "Special Moments". But I am sure there will be more "special things" uncovered as we progress.
So we are now looking at some different design options and what kind of decking we want (cedar, composite, etc).
That $50 repair job is getting more expensive by the minute. And I haven't even looked into whether I should just have the sealed unit replaced on the patio door, or do I just replace the whole door.
I'll keep you all posted.
Bill
Old 07-13-2009, 09:30 PM   #5
Newbie Bill
OK, here is the "Clean slate" so to speak. I will be rebuilding using the existing ledger board and placing my beam over the existing concrete pads.
deck-repair-oops-replace-oops-new-patio-door-thread-dsc01918.jpg   deck-repair-oops-replace-oops-new-patio-door-thread-dsc01919.jpg
Bill
Old 07-13-2009, 09:33 PM   #6
Newbie Bill
First job is to re-grade the ground under the deck. It slopes towards the house.
The next job is to deal with this mess. These are a couple of fresh air intakes for the furnace. They failed to put the flashing over the top of these areas so I will add some to go over the lip of the intake flange (not sure if that is the correct terminology).
deck-repair-oops-replace-oops-new-patio-door-thread-dsc01922.jpg   deck-repair-oops-replace-oops-new-patio-door-thread-dsc01923.jpg
Bill
Old 07-14-2009, 12:11 AM   #7
Will you be getting a permit for this? If so, the existing hangers will not work other than for a 9'1' span to the bearing beam at 24" o.c.
As you are at 4 risers or more, you will need a handrail, at least on one side. Joist spans included in the article.
Here is the 2006 deck code to be safe: http://www.awc.org/Publications/DCA/DCA6/DCA6.pdf
Your ledger board is only nailed on, it should have bolts as per web site, above.
Change to 16"o.c. joists with Z-Max hangers (triple zinc plated), so you can span farther with the same size boards.
http://www.strongtie.com/products/co...rs/LUS-HUS.asp
Vinyl siding removes easily with a zip tool so you can replace the flashing/and the ledger. The ledger looks to be fir, not p.t. wood.
Now is the time to add wiring for any accent lights on steps or under fascia.
As you are in cold country, I would protect new footings from frost heave in this article- footings with sonotubes, gravel under and as backfill, wrapping the sono's with plastic, etc. http://books.google.com/books?id=1gg...num=3#PPA31,M1
Be safe, G
GBR in WA is offline   Reply With Quote
Old 07-14-2009, 11:47 AM   #8
Newbie Bill
Thanks for all that information G,
I'm looking into the permit stuff now.
The old deck was built with 16" OC so the way I read that document, if the joists are Southern Pine I can span 10'6" and if it is Fir, Larch, Hem-fir then only 9'3". I think the pressure treated wood here is Spruce, so I'll assume it falls in the 9'3" category.
Is the fir ledger board OK as long as I add some bolts?
Bill
Old 07-14-2009, 01:49 PM   #9
Check with local Inspector on this. They may have a website on decks for your locale. Be safe, G
Old 07-14-2009, 02:10 PM   #10
Newbie Bill
Just checked on-line for some information from our county.
Allowable span for Spruce joists: 2X8@16"OC, AS = 11'0"
Footings: They seem to allow concrete pads 24"X24" minimum 4"thick. No details on the piling depth if we go that route.
Ledger, no info on that. I will have to call.
Thanks again GBAR.
Bill
Old 07-14-2009, 02:25 PM   #11
Newbie Bill
Here is the proposed new deck.
Note: I couldn't figure out how to draw railings down the stairs so those are absent but not forgotten.
Bill
Old 08-28-2009, 06:40 PM   #12
Newbie Bill
OK, here is an update to my deck project. It took us a long time to decide what kind of decking material we wanted. Ipe topped the list but it is pricey to get shipped up here. So we found another hardwood called Angelim Pedra. It was a much cheaper hardwood. Should arrive next week.
You can see a small piece of Pedra near the patio doors.
Since I didn't have the decking yet, I took my time with the frame.
Here is an updated photo of the deck.
Bill
Old 08-29-2009, 12:26 PM   #13
With the new pressure treated wood, make sure the hardware that is used is compatible, otherwise it will corrode. I don't know if the old joist hangers are okay to use.
Ron
Old 08-29-2009, 04:07 PM   #14
Newbie Bill
Hey Ron,
I used those simpson's joist hangers, hurricane ties (I think that is what they are called), and the 22.5 angle brackets. All were rated for pressure treated wood.
I have to admit I did use 4 of the old flimsy joist hangers to attach a couple of my cross braces. I am not too concerned if those corrode.
Bill
Old 08-30-2009, 01:48 PM   #15
Are you going to redo the decking on the lower deck with the 'Pedra' hardwood?
derf36 is offline   Reply With Quote
More On This Topic
Everyone knows to close the door behind them in the winter. But sometimes that isn't enough. General wear and tear on your door can create gaps that let cold air in and cost you money. Fixing these is relatively easy, and a little time and money spent to... Read More »
Hi. I'm Mark Sullivan for Expert Village and today we're going to show you how to change the lock on your commercial steel door. This is a steel door with glass panes in it and we have a double cylinder deadbolt lock, which means that there is a lock... Read More »
There are many areas in the average home that are subject to drafts and air leaks. Whether it's dropped ceilings and window frames or air ducts or furnace flutes, chilly homes in the winter are unfortunately the norm. Air infiltrates into and out of your... Read More »
Hi, I'm Bob Street with Houdini Home Repair on behalf of Expert Village. In this clip, we will carry the beam up the ladder, clamp and shoot the nails. It's bad when your help don't show up, you've got to use a camera. Are you ready? How you feeling? You... Read More »
A single pane window is really the worse part of your house because energy is flowing through this single pane like there is nothing. You could put a newspaper there and it would be, a normal newspaper, would be a better insulation than a single pane... Read More »
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
Average price of deck and patio in Northern VA? Bimerman General Discussion 2 05-12-2007 11:23 AM
staining my patio deck Morry Painting 3 07-26-2006 04:37 PM
add roof to patio deck elfyperz Introductions 1 05-17-2006 06:37 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
