Deck Rebuild - Project Showcase - DIY Chatroom Home Improvement Forum
Old 08-20-2012, 03:45 PM   #1
Rewards Points: 77
Deck rebuild
This is the deck I was redoing this summer. It was the ugly purple monster when we bought the house. I took it down to the frame and build it back up. I reused some of the old 2x6's for the decking. Close to finished. Just need to put the latte around the bottom and trim it out. Then let it dry for a while and then stain it.
Deck rebuild-image-2763123335.jpg   Deck rebuild-image-208396331.jpg   Deck rebuild-image-921244891.jpg
asbury park is offline   Reply With Quote
Old 08-20-2012, 03:47 PM   #2
Rewards Points: 77
The dog enjoying the sun.
Deck rebuild-image-1109589231.jpg   Deck rebuild-image-1144449481.jpg   Deck rebuild-image-683942450.jpg   Deck rebuild-image-1281182307.jpg
Old 08-20-2012, 03:49 PM   #3
Rewards Points: 77
More progress
Deck rebuild-image-529175413.jpg   Deck rebuild-image-239926511.jpg   Deck rebuild-image-567040772.jpg   Deck rebuild-image-3150998464.jpg
Old 08-20-2012, 03:51 PM   #4
Rewards Points: 77
Just about done. Need to put up the lattice and the trim.
Deck rebuild-image-23347738.jpg   Deck rebuild-image-3308610983.jpg   Deck rebuild-image-3006709881.jpg   Deck rebuild-image-408418555.jpg
Old 08-20-2012, 03:53 PM   #5
Rewards Points: 13,732
Where's the post where the railings will be near the wall?
May want to rethink those steps. Looks like the riser heights are way off.
What in the world would make someone think purple was a color to paint a deck? Sanding all the paint off will be fun.
Old 08-20-2012, 03:59 PM   #6
Rewards Points: 77
yeah, first step is a little low to the ground. i'm ok with it.
Old 08-20-2012, 04:33 PM   #7
robertcdf's Avatar
Doesn't look like the framing meets code at all, and the steps are of course wrong, being "ok with it" will not be a very good defense if a lawsuit ever ensues as a result of someone falling.
Just saying
robertcdf is offline   Reply With Quote
Old 08-20-2012, 04:46 PM   #8
Rewards Points: 77
Just saying
had it inspected when i bought the place. met all the codes here.
Old 08-20-2012, 05:31 PM   #9
robertcdf's Avatar
A home inspector is not qualified to make structural inspections. You can't have beams attached to the side of posts.
Old 08-20-2012, 06:36 PM   #10
Never did see any joist hangers.
Are those just 2 X 6 joist.
Since you chose to lay the 2 X 4's horizontal for the bottom rails your going to have to add blocking under the middle of the long runs or it's going to sag.
Is there any support in the middle? Looks like I can see just a single 2 X 6 where it should have been a double. May just be the picture.
Boy I bet you hate us now after going to all that work.
Old 08-20-2012, 06:55 PM   #11
Civil Engineer
Rewards Points: 4,782
I presume you posted this to show your work, and the deck looks very nice. So does the dog. I am guessing you felt that no permit was required since you were rebuilding an existing deck, not constructing a new one, and perhaps that is the case in your town. In my town, total reconstruction such as you did would require a permit, and you would need to comply with the deck code, which in my town is International Residential Code 2006. Obviously your town could be different.
As has been pointed out by others, your method of construction is far from compliant with current code, at least with IRC. So while the deck looks very nice, I would caution anyone else on this site who observes this not to assume they can build in this manner. Always check with the building inspector first to see if a permit is needed, and what codes must be adhered to.
Old 08-20-2012, 08:51 PM   #12
Rewards Points: 77
Joe, yes there is support in the middle. Nah, I don't hate you guys for setting me straight. I was guessing there would be an issue or two that someone would find. That is probably why you guys do what you do and I do what I do. That is obviously not build decks for a living. And, it is something to learn from. That being said, I do feel the deck is safe. That is my main concern.
Deck Staining Nightmare steven994 Painting 6 04-06-2014 09:10 PM
Pergola over existing deck cpfullback Building & Construction 0 08-04-2011 11:36 AM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
Deck Rebuild Ideas philly529 Building & Construction 5 04-20-2009 03:30 PM
