Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > Project Showcase
Old 04-27-2011, 01:35 PM   #16
Kerry-All Pouch creator
Woodsmith's Avatar
Send a message via MSN to Woodsmith
Deck Build
Check with the paint shops...I'm not sure if clear coats have an ultraviolet inhibitor to keep the sun from bleaching the wood.
Woodsmith is offline   Reply With Quote
Old 04-27-2011, 02:01 PM   #17
Custom User Title
Deck Build
Good point. Thanks for the tip!
no1hustler is offline   Reply With Quote
Old 04-27-2011, 04:30 PM   #18
Moderator
kwikfishron's Avatar
Deck Build
Hope your going 16”OC for your 5/4 Cedar.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is offline   Reply With Quote
Old 04-28-2011, 09:11 AM   #19
Custom User Title
Deck Build
Yes, definitely going 16"OC.
Old 04-30-2011, 08:12 PM   #20
Deck Build
Looks like you've got a great start! Keep us updated!
MegaMagma39 is offline   Reply With Quote
Old 04-30-2011, 08:26 PM   #21
Custom User Title
Deck Build
Today we worked on it for almost 12 hours. Here is the progress. I'll post an end of day picture tomorrow when there is more light. Sorry for the crappy cell phone images.
Two of my brothers and my dog.
Brother and his family.
I'm really happy with the cedar that I got.
Old 05-02-2011, 08:37 AM   #22
Custom User Title
Deck Build
A couple more progress pics. The decking takes a long time to screw down so it doesn't look like much progress. It also took a while to get the cuts the way I wanted them on top of the candle wall.
Old 05-02-2011, 08:50 AM   #23
Civil Engineer
Deck Build
Just curious. I could not tell from the photos, but are you directly burying the PT posts for the deck? Around where I live, the code requires that the posts be supported on a concrete footer, and they have to be placed on a standoff bracket, usually galvanized, to reduce rot potential. I suppose if you used direct burial rated PT my BI might allow direct burial, never did check.
Also, in my town, the beams are required to be installed on a notched post, they can't be bolted directly onto the post. This means that the minimum post size is 6x6, not 4x4, which of course adds somewhat to the cost. I couldn't tell if your posts were notched, but they do look like 4x4.
Differences in local code interpretation I guess. The deck looks very nice, I llike the cedar.
Old 05-02-2011, 10:02 AM   #24
Custom User Title
Deck Build
Thanks, yes, its all about the codes. The posts are sitting on concrete and the posts do not need to be notched. The code office is very lax since the deck is less than 30" from grade. I did not use direct burial rated PT. I did however put a preservative on the posts. I actually had to go back and brush another couple inches on some of the posts because I didn't put enough on originally to get up to grade.
Old 05-02-2011, 10:29 AM   #25
Coconut Pete's paella!
CoconutPete's Avatar
Deck Build
Looks good! I feel you on the decking screws - We spent a TON of time putting those d@mn things in.
CoconutPete is offline   Reply With Quote
Old 05-04-2011, 08:54 AM   #26
Custom User Title
Deck Build
The Following User Says Thank You to no1hustler For This Useful Post:
shumakerscott (05-07-2011)
Old 05-11-2011, 08:53 PM   #27
Custom User Title
Deck Build
Old 05-12-2011, 12:40 AM   #28
Stuck in the 70's
Blondesense's Avatar
Deck Build
Nice!!!
Blondesense is online now   Reply With Quote
Old 05-22-2011, 01:53 AM   #29
Deck Build
wood.
n0c7 is offline   Reply With Quote
Old 05-22-2011, 09:24 AM   #30
Woodsmith's Avatar
Deck Build
People complain about the extra time and cost (especially the time) to use screws instead of nails when they build a deck, but when you have to replace a board for whatever reason (accidental damage, rot- not likely with cedar), you will be sooo glad you used screws!
Ground level deck - screws or bolts? rsmith0399 Building & Construction 9 01-11-2012 01:53 PM
Cedar deck help mickbiv Building & Construction 5 09-08-2010 10:56 AM
Deck Staining thread but I am desperate- please help mickbiv Painting 3 09-08-2010 01:28 AM
Deck layout advice for working around AC unit atesgoral Building & Construction 0 05-21-2010 04:01 AM
DougFir Deck - Stain Before or After build? mntnvew Carpentry 14 04-15-2009 08:33 PM
