Custom Kid Wood Playland - Project Showcase - DIY Chatroom Home Improvement Forum
Old 07-29-2009, 10:47 AM   #1
I started this project about 2 weeks ago. I decided I could use materials left over from building the house and build a custom playland a lot nicer, sturdier, and cheaper than the ones you buy from Lowes, Wal-Mart, or online. I figure I will end up with around $300-$400 in it, but it will be a lot better than the ones you buy for $1200-$2000. The entire structure is bolted together for easy disassembly so I can sell it when the kid outgrows it.
Here are a couple of in-progress photos. I hope to finish it within the next week or so.
johndeerefan is offline   Reply With Quote
Old 07-29-2009, 11:03 AM   #2
RippySkippy's Avatar
Looks good, make sure to add some padding to the top of the interior on the exterior doors, when they get bigger nothing hurts more than smacking your head. Where did you get your post brackets for the swing extension. Great member name by the way!
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 07-29-2009, 11:07 AM   #3
That looks good
I bought a used set off Craigslist for $75 & bought new swings
I like that it matches the house
Going to have a skylight?
Old 07-29-2009, 11:13 AM   #4
Thanks for the compliments. I bought the bracket from http://www.swingsetsource.com/backya...cketsystem.cfm It wasn't cheap, but it only took about 30 minutes to put together the entire beam assembly. Of course, I used my front end loader on my little tractor to help hold it up and keep it level. I would recommend this bracket to anyone wanting to build a kids swing set.
No plans for a skylight, I just haven't had a chance to put the green metal roofing on yet. That will probably come this weekend. I agree with the padding, I have already hit it about 20 times.
Old 07-29-2009, 11:18 AM   #5
My swingset has the same metal brackets - or close to it
We actually ended up with the fort, seperate swingset & 6x6 sandbox for the $75
Bought new swings, tarp, binoculars & sand
I like the log cabin siding
Maybe do that for a tree house when my son gets older
Old 07-29-2009, 12:16 PM   #6
Thanks for the lead on the bracket...while expensive, by the time one pays for the other stamped kind...it's not that much more...and they appear to be WAY stronger. Placing the order for a pair right now....
LMASD
Old 09-08-2009, 09:14 AM   #7
All but finished
All I lack is staining it and adding more play items as the kid grows into them. Final cost ended up near $400.
Tags
kids swing , swing set , wood swing
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Ext Paint for Interior Application? PaoloM Painting 24 04-21-2009 05:30 AM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
Exterior Door: is there a middle ground between a factory unit & a solid wood custom? pdks Building & Construction 1 04-15-2008 12:08 AM
