Current House - Stairs - Project Showcase - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-16-2012, 10:10 AM   #16
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 740
Originally Posted by JulieB View Post
Would you mind letting me know what isn't to code so he can change it before he goes any further?
Julie
The riser step can not go to a point. It needs a 6" flat end on it. One of your risers has the flat end, can't tell if its 6" though.
123pugsy is online now   Reply With Quote
Old 11-16-2012, 01:43 PM   #17
Ole Wood Worker
BigJim's Avatar
Rewards Points: 190
Julie, the winder tread, or the one on the landing at an angle, needs to be full width at the assent/descent line, which is 12 inches from the inside edge of the hand rail. What ever the width of the rest of your treads are, the winder needs to be the same width at the assent/descent line.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 11-16-2012, 02:21 PM   #18
123pugsy's Avatar
Rewards Points: 740
Whoops, I should have said winder stair.
Old 03-25-2013, 09:25 PM   #19
Flooring...
Do you know what flooring that is and if so, could you tell me how it held up? Is it handscraped?
maxandmil is offline   Reply With Quote
Old 04-09-2013, 02:22 PM   #20
I'm most interested on how this is going to be resolved. He does good work for sure though.
stamandster is offline   Reply With Quote
Old 04-09-2013, 02:38 PM   #21
Amateuralex's Avatar
Rewards Points: 270
Very ambitious and impressive.
Amateuralex is offline   Reply With Quote
House gets too Hot at night furthermore HVAC 14 09-22-2015 12:09 PM
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 10:04 AM
anchoring concrete stairs to the house amakarevic Building & Construction 2 06-14-2010 04:25 PM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 03:28 PM
Unfused connectors MELTED House wires WHAT TO DO??? jamiedolan Electrical 63 02-12-2009 07:01 PM
