Cupboard/bookcase - Project Showcase - DIY Chatroom Home Improvement Forum
Old 01-12-2011, 12:00 PM   #1
rditz's Avatar
cupboard/bookcase
I posted this in the carpentry section, but not getting any feedback, so I thought I would try here..
I wanted to make use of the space underneath a set of stairs. So what I came up with was a combination of closet type storage and a bookcase/shelving beside a desk that will have a computer and be a home-office type of workspace. I cut the corner of the shelving (you can see in the picture) for better access.
http://i243.photobucket.com/albums/f...z/SAM_0208.jpg
the question is regarding the top of the shelving.. I think I should cut it to mimic the shelves below. My wife thinks it should be a squared off top. (keep in mind when looking at the picture that it all still needs to be trimmed out and the gaps/spaces will be hidden).
looking for opinions/thoughts on what I have built so far.
thanks
rod
rditz is offline   Reply With Quote
Old 01-12-2011, 12:45 PM   #2
Experienced
Jackofall1's Avatar
Looks great, when are you going to build the matching desk.
Old 01-12-2011, 12:49 PM   #3
rditz's Avatar
Jack.. thanks... what did you think of what I did for the top of the shelf part?? I am looking for opinions on whether this looks good or if it looks odd..
no matching desk, if you look at the picture, you will see the old desk my wife wanted.. she had me buy an antique chair that is so hard, my butt hurts after sitting in it for an hour or so...
rod
Old 01-12-2011, 12:52 PM   #4
Experienced
Jackofall1's Avatar
I don't know, seeing how its already up and fabbed I wouldn't mess with it, maybe some finish trim on it would help.
You can trim that out when you put the railing for the stairs up.....
Old 01-12-2011, 12:57 PM   #5
rditz's Avatar
Yes it does need to be trimmed and the storage spaces to the left will have doors. the shelf top has not been screwed on yet and the entire unit can still be pulled out.. all pending a final decision on the top. I promised my wife i would get opinions before i trimmed and stained.
rod
Old 01-12-2011, 01:06 PM   #6
Experienced
Jackofall1's Avatar
Alright heres what I think I would do with that, cut the right side flat on a line even with the left side, then cut the top across that plane, it would be a bias cut, then mount it appropriately, making a top shelf, say for one of those nice plants, easy to care for.
Old 01-12-2011, 01:08 PM   #7
rditz's Avatar
you are the second to suggest that
Old 01-13-2011, 06:54 AM   #8
the Musigician
DangerMouse's Avatar
The top part would blend right in if you use the same color of paint as is on the walls.
DM
Old 01-13-2011, 07:13 AM   #9
rditz's Avatar
the cabinet will be stained with a cherry stain it will blend more with the stairs.
there is still Oak trim and doors to go on.
rod
Old 01-13-2011, 07:50 AM   #10
Old School
cabinetman's Avatar
It's a clever idea for storage and will look good. I think I would initially have squared off the top of it at the height of the window trim. But since it's together, maybe just cut it straight across at the height of the left side. I don't know what weight you'll be putting in there, but I would have used some thicker sheet stock. It's moot now, and will likely serve you well.
cabinetman is offline   Reply With Quote
Old 01-13-2011, 07:55 AM   #11
rditz's Avatar
thanks... the material is 3/4" vanier plywood good both sides. I routered out 3/8" for my shelves... I don't expect to stand on the shelves, but they should hold everything that I need to put on them (mostly computer stuff and some books..)
my thought on the top was to carry my line from the shelves where I cut the angle straight up, so that if you had a straight edge it would all line up.. the top is not fastened yet and I can still move the unit in and out...
I realize that ultimately the choice comes down to me, but I am trying to get a consensus between my opinion and that of my wife.
appreciate your input.
rod
Old 01-13-2011, 08:11 AM   #12
Old School
cabinetman's Avatar
rod
That's what I was referring to.
