Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > Project Showcase
Old 09-28-2011, 09:38 PM   #1
Concrete countertop issues
I am currently making my own concrete counter top. The first thing I've done is poured a tester piece (precast) I am now in the acid staining part of my pre project, my question is should I polish then stain or stain then polish?
slushyjennen is offline   Reply With Quote
Old 09-28-2011, 09:39 PM   #2
Stain then polish.
OhioHomeDoctor is offline   Reply With Quote
Old 09-29-2011, 09:15 PM   #3
But you can polish first,then use powered colored dye,the dye will penterate the polished top where stain won't on a closed surface.use acetone with dye.it will dry on contact.for first time i would use stain then polish.you may do a second coat of stain as your polishing might take away some of the stain as you polish your perfect on testing on sample top first.good luck,ken.
we all no alot but can only do a little-----an
kchunt is offline   Reply With Quote
Tips For Pouring Concrete? Root issues? Thoughts? kronic24601 Building & Construction 5 02-14-2011 07:52 AM
basement reno concrete - water issues Tony2000 Flooring 2 01-11-2010 09:42 PM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 05:53 PM
Filling sunken living room w/ concrete Q's phil. Building & Construction 5 07-10-2009 01:03 PM
concrete issues kindrngentlr13 Building & Construction 15 06-28-2008 10:39 AM
